Question about Kenmore 46462 Front Load Washer
Kenmore Model 501-40002 Front Load Washing Machine
On the quick cycle the machine freezes at the 9 minutes with the drum rotating back and forth endlessly. No warning lights come on. Our first new machine did the same thing. It was replaced, but now the replacement machine does the same thing. Otherwise the machine seems to function properly on the cycles we have used. We wonder if this might be a manufacturer's defect.
  • Anonymous Feb 14, 2009
    same problem here. I had a UE error code a while ago. I did not get this code with a full load. Only when washing a couple of towels..
  • 150 Answers
There is a flaw in the cycle (timer).Sometimes the manufacture will makes hundreds before they realize there faulty,sometimes they do this to create a demand for parts and service calls. You know what they say about lemons.You might have to replace the cycle controler.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 05, 2009
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Mar 16, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
In the Spin cycle, after 9 minuts, it will stop with a "UL".
"UL" means "Unbalanced Load" - make sure the washer isn't overloaded first or if you are doing rugs, blankets, or lots of jeans, split the load. You can also try running an empty or light load and see how the machine behaves.
If you still have the problem, you may have some issues with the drum bumpers, etc., but try the easy things first.
Jul 12, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Machine freezes at the 9 minute mark.
it might be a timer switch issue thats getting stuck. with the RPM issue thats a transmission issue. make sure the repair guy looks at the tranny for proper function
Sep 04, 2009 | Kenmore 46462 Front Load Washer
Spin cycle shakes the whole house everytime why
check first if any of the legs are not sitting flat on ground,check the roughness of bearings by placing your hand in the drum and rotate slowly back and forth,loose balance weight could also be a cause but id say it sounds like bearings
May 07, 2009 | Washing Machines
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Screeching at spin cycle
There are a few things that it could be. The simplest is the fan which blows the air across the element is impinging on the back panel. This is relatively easy to fix, the fan is usually mounted directly driven from the back of the motor and held on by a spring washer or circlip.
Remove the back panel and rotate the drum by hand, you should be able to see the plastic fan catching on the metal of the back panel. A new fan costs very little and is very easy to replace with standard household tools.
Alternatively the motor bearings could be on their way out. This is more annoying to fix - get the engineer in for it. Again rotating the drum by hand, rock it back and forth you will feel a grinding transmitted through the belt (very worn bearings) or on the motor itself.
Jan 06, 2009 | Dryers
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 46462 Front Load Washer Logo
568 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
