Question about GE Refrigerators
GE MDL:TBX25ZLB Top Freezer Refrigerator Freezes up
I take the unit apart and the coils are solid ice. I defrost it with a hair dryer and put it back together. In less than a week it's froze up again. A friend told me it needs a defrost kit. Is this correct? If so, do I need the defrost heater and the thermostat or just the heater?
  • 4 more comments
  • muller_je Feb 10, 2009
    Thanks for the info. I found the timer and turned it clockwise as instructed. There was a loud click and the refrigerator turned off. It appears to have melted some of the ice but not all so after about 2 hrs I tried the procedure again. For some reason the timer will not click as before and the refrigerator continues to run. Suggestions?
    Thanks. You were correct, I must have turned the it to fast. I turned it slower this time and it did go into defrost mode. The refrigerator did turn back on but some time between 45 min and 1.25 hours. I check at 45 min and it had not turned back on yet. I checked again 30 min later and it was running. The coils are completely frozen, evenly across the entire freezer. I think the melting I say early may have been from the unit being turned off. I don't see any measurable evidence that the ice is thawing in the freezer. I purchased the defrost heater and defrost thermostat. I got the part numbers from the GE website and then order them through a discount parts house. I only hope the timer isn't bad also.
    Okay, I just took the unit apart and it does appear the heating unit is turning on (glowing orange) when I turn the timer to engage it. The bottom set of coils are cleared so the unit must be defrosting. The top set are still frozen so it probably just needs to cycle a few time to thaw them. Now my question is: Why isn't the unit defrosting automatically?
    One other thing I should add. I purchased the Defrost heater and the Defrost thermostat. When I was sizing up the effort to replace these (if need be) I noticed the Thermostat has a wire connecting to the defrost heater and a wire connecting to the plug for the Ice maker. I removed the Ice Maker some time ago (I don't recall if this is when my icing issue started). Could I have created an open circuit and rendered the Defrost Thermostat useless by doing so?
    Also, I just defrosted the freezer with a hair dryer. Needless to say the inside of the freezer was warm when I finished. Just for the heck of it, I plugged the Refrigerator back in, the coils started to get cold and frost a bit, I then started the defrost cycle (to make sure I didn't damage anything while defrosting) via your suggested method above. This time the heater did not come on (glow red or orange). Could this be due to the thermostat sensing the warm temp in the freezer and hence blocking the defrost heater from engaging? If so, I would guess this would be a good indication that the defrost thermostat is operational and doesn't need replaced.
  • muller_je Feb 13, 2009
    Well I known the defroster wasn't kicking in before because when I manually defrosted (with a hair dryer) as there were no signs of the defroster working. I can see when I engage the defroster manually (turning the defrost timer) it definitely shows signs of it defrosting. I think the automatic process of engaging the defrost cycle is the problem. I will try to see if I can locate a replacement for the defrost timer.
    How ofter should the refrigerator enter the defrost cycle? Once a week? Once a day? etc.
    Thanks for all your help. I couldn't have figured this out without your shared knowledge.
  • 1,543 Answers
You need either a WR51X314 defrost heater, or more likely a WR9X413 defrost control (defrost timer) for your TBX25ZLB. Unfortunately, these part are listed as "No Longer Available". Next time you want to defrost it, find the defrost control at the back of the refrigerator section, very near the temperture set knob (the one that goes from 1-9). You will most likely have to pull the knob off and remove the cover to find the visible part of the defrost control timer. It is a round flat looking plastic part, usually black or white, smaller than a dime, with a groove in it which you can turn with a flat blade screw driver. Turn it slowly clockwise (they usually make a clicking noise as you turn them) until it makes a rather loud click. Now if the refrig was running, it will stop and turn on the defrost heater. If the heater is good, it should begin to glow red and heat until the frost melts or the timer advances back to the run position (usually about 30 minutes). (if there is lots of build up on the freezer, it will most likely take longer than 30 minutes of defrost heater operation to melt it all. You can help it with your hair blower, if you think you need to. ) All this will help to eliminate the defrost heater itself as the problem. A larger parts store may have a defrost control timer left in inventory, or be able to suggest a generic defrost control which you can use. In the mean time, you can defrost your refrig manually this way once a week or so for 45 minutes, then manually advance the timer again to the run position. (If the defrost control timer is bad, it usually will not advance itself back into run) Send a comment with how things turned out or if you have any other questions. Please don't rate this, as anything but a Fix-Ya lowers my score.
Posted on Feb 05, 2009
  • 2 more comments
  • Carl Schulzetenberg
    Carl Schulzetenberg Feb 10, 2009
    You must have turned it a little too fast and skiped over the defrost portion of the cycle that second time. Just try it again, very slowley. Did the refrigerator go into "run" by itself a half hour or so after you did the defrost? Also, you said it was solid ice at first,.... was it an even coat of ice, or only in one part, like only on the right side, right bottom?
    Obviously the defrost heater is OK, and if it turns on your defrost thermo is OK for defrost, which leaves the defrost control timer. I would also check for reasons for excessive frost build up, like the door gaskets leaking air. (look especially at the bottom of the fresh foods door for torn gasket)
    Your are correct with the thermo. The thermo needs to cool down to a certain temp before it resets and allows the defrost heater to work again. During defrost, when all the frost is cleared and there is still time left in the defrost cycle, the defrost themo warms up and turns power off to the heater so it will not add unnecessary heat to the freezer compartment. Unplugging the icemaker will not adversely affect the defrost system.
    Carl Schulzetenberg Feb 13, 2009
    Generally, mechanical defrost control timers will cycle into a 30 minute or so defrost time for every 6 - 10 hours of run time. If your refrig runs 50% of the time, you will have at least one defrost cycle per day. (as stated earlier, the max time the heater is on is determined by the defrost thermo, so even in a 30 minute defrost cycle, the heater may only be on 20 minutes, for example) It takes about 2 weeks for enough frost to build up to cause cooling issues. You should be able to get a WR9X502 defrost timer to replace the original and get your refrig back in shape. This should be a Fix-Ya for your refrigerator.
Frig stopped cooling. Light works, freezer works, can hear freezer fan. Doesnt seem like air flow is getting to fresh food area. Freezer back wall has thin line of frost on it. Model tbx18ja. I want to...
Easiest way is to push against the vertical portion of the ice tray holder until it slides
off the buttons which are inserted into the top of the freezer compartment.
These models sometimes had issues with defrost timers (which I just replaced one today) and Defrost termination thermostats (which is clipped on to a tube behind freezer panel).
Make sure the freezer coils are not frozen up solid, if so use a hair dryer to defrost them
and make sure the vent is not iced over.
Model and serial are in the lower compartment on the left wall. In case you need to go to
the appliance parts store.
Hope this helps.
Aug 02, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
Hi, my GE refrigerator has ice developing on the rear wall of the freezer, and things in my crisper drawer are freezing solid,please help!!!!
Unplug refrig. Empty all food from freezer side and remove shelves from freezer. Remove back metal cover from inside freezer. Melt frost with a hair blower. Examine defrost heater at very bottom of the coils you defrosted. If heater coil inside glass tube is broken, replace defrost heater. (note: replacement may look different, but insturctions included with replacement address that) If heater is not broken, replace the small white pencil shapped sensor at the top of the cooling coils.
Dec 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer saection is freezing up causing the refridgerator to get warm, I defrost and this works for 2 weeks. What would you look for?
remove the rear panel inside the freezer in there will be the evaporator coil,if its covered in a layer of solid ice then defrost it with a hand held hair dryer,then with the power shut off to the unit unplug the defrost heater underneath the coil and test for continuity,if this checks good then test the defrost thermostat on the top of the evaporator coil,you will need to put this on a piece of ice or cool it to below to make the contacts touch otherwise it will show open(bad) if this shows good(closed),then check for 120 volts a.c. on this circuit when is in defrost mode
Nov 19, 2010 | Magic Chef CTF2125 Top Freezer...
Side by Side GE Refrigerator freezer will not defrost which allows frost/ice to build up. I have cleaned all the areas behind the unit as well as under the unit. After I manuely defrost the freezer it...
The defrost circuit has failed in your fridge. Typical failure is with the defrost heating element. To troubleshoot, you need to remove the remove the contents of your freezer section and remove the freezer back panel to access the evaporator coil. You will need a hair dryer to melt the ice on coil. The heating element is attached to the coil. Use a meter to confirm that the element is bad. Hope this helps you.
Nov 08, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
The freezer fills with water and overflows about once a week.The food is partially frozen and the ice is clear and wet. The fridge is cold and no problems but the freezer doesn't fully freeze and water...
your evaporator coil in the rear area behind the freezer back panel is frozen over with ice and the coil can no longer deliver cold air due to ice blocking the air flow from the evaporator fan,remove this rear panel,defrost it with a hair dryer,check the defrost heating coil for continuity,they go bad regularly,if not the heater coil under the evaporator coil,it may be the defrost timer in the refrigerator section of the unit that powers the defrost coil that needs replacement
Jul 25, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
Frost on back of freezer does not seem to be cool enough
Sounds like a defrost issue. The frost is caused because the defrost element heater is not working. Ice accumulates in the coils and blocks the air flow in to the freezer/refrigerator. GE refrigerators have an element heater behind that back panel under the evaporator coils. They are quite simple and inexpensive to replace. Use a hair dryer to defrost the coils to make the swap easier.
May 23, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
There is a horrible humming sound coming from the freezer. It seems to be the fan that is behind the piece of plastic in the middle of the back wall of freezer. The sticker in the freezer says MODELS...
Hard to diagnose without being there and taking it apart. Based on my experiences, I suspect the defrost drain could be restricted. The defrost water freezes in place around the fans shrould and the fan blade hits the ice buildup. If the ice builds up enough the fan blade will be stopped and possible damage the fan motor. Access fan area to inspect and defrost (hot water, hair dryer or let it stand overnight off. DC evaporator fan motor WR60X10228 est $85
Ric
Mar 09, 2010 | GE Profile Arctica Stainless Steel Top...
GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer does not freeze fast enough, icecream gets very soft. The refrigerator is set on temperature level 9 and is not cold.
Setting the control to 9 may make the freezer ice up too much to work right. You can start with a manual defrost. That takes a long time, because the ice is below the freezer liner, stuck in the coils. You'll have to move your food elsewhere, like a cooler. I always take the freezer apart to get at the coils, use a hair dryer to melt the ice. Then you can check the defrost coil, it's like a toaster element. After all that, check the defrost timer too. It's usually down by the compressor area, about the size of a cell phone. It has a small dial on it that only turns one way. Mark it when the fridge is on with whiteout to see if it moves. It moves real slowly, so you will have to wait a half hour or so.
One way to speed up a defrost is to turn the dial on the defrost timer until it clicks. Then the compressor will turn off and the defrost coil will turn on. The freezer fan should be spinning. Feel the output from the freezer fan- anything? If no flow, you're iced up. Keep checking for flow, eventually it should get cold. When you get good airflow, and maybe it's not so cold anymore, you might be defrosted without having to take the whole thing apart. You may have to turn the dial more than once, if the compressor comes back on before you're defrosted. You can help the defrost with your hair dryer thru the vents in the front of the freezer, but not too hot, you don't want to melt any plastic.
Apr 25, 2009 | GE GTS18ABSWW Top Freezer Refrigerator
Freezer freezes up causing the refrigerator side not to work
you probably have a bad defrost timer. This item will turn on a hot coil to melt the ice when it needs melted. If you coils are solid ice then the cold air cant travel to the refrigerator side to cool it. This air is moved with a fan and the ice blocks the movement. Melt all the ice with a hair dryer and put the cover back on u will be good for a bout a month and if defrost timer is bad it will clogg again.
Jan 09, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
687 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
