Question about PfaFF Hobby 4260
Pfaff tiptroni6122, the thread loops up on the bottom of material
When I checked the for the problem, found that the needle was being grazed by the hook in the bobbin, can I fix this or will the the hook and race have to be replaced.
  • charleu Feb 05, 2009
    thank you, I agree with you about the machine, bought the machine in 1997, do a lot of sewing and my repair man said this would be the best machine for me and it has been, will take to the shop, thank you again
  • suestott Feb 25, 2009
    My Pfaff 2025 makes a clicking sound and tension needs to be set at 7 for a decent stitch, but there is sometimes looping on the bottom and inconsistent tension. I do a lot of quilting and do not want to spend the money taking to the shop. I have cleaned, oiled, changed needles and thread. Would appreciate advice. Thank you.
    New Friend:
  • 186 Answers
Sounds like the hook timing is off. You don't need a new hook but you may need a new position finger. If you are unfamiliar with working on sewing machines then it needs to go to the shop. This is a great machine and is worth keeping up. Pfaff doesn't make the all metal hook anymore which is a shame.
good luck!
Posted on Feb 05, 2009
My sewing machine shark euro-pro 361 is jammed. Needle will not move. What do I do
See if you can remove the bobbin from the machine. Most likely the bobbin and upper threads are entangled and have trapped the needle. You can remove the presser foot and loosen the needle from the needle bar (as though you are going to remove it). Then if you get a small pair of scissors in there and start nipping thread pieces and removing them with tweezers, you may be able to loosen it up.
Jan 16, 2017 | Euro-Pro Sewing Machines
How would I secure the hook and race so they don't move after they're clipped in?
Your repairman is what's wrong! The bobbin case I believe is what you are talking about. (I hope you didn't remove the race)
1. Anyway the bobbin case has to be snug so it doesn't move clockwise or counter clockwise. If it moves the needle will crash . If your machine is an older one the truth is the same.
2. The bobbin case cannot be allowed to spin. See adjustment!
3. Before you start sewing again clean the feed dog real good.
4. Before you put the bobbin in the bobbin case (on top of race) put a drop of oil on the race.
5. Replace the needle. This is important.
If you still have a problem your machine probably needs to be timed due to the needle crashing before.
Feb 23, 2015 | Sewing Machines
My needle will not depress down to the bobbin case. i have tried and retried many times inserting the hook race and hook with no luck. the needle will go down w/o the hook race but never after i&
Make sure you are inserting the bobbin into the case correctly. Some bobbins thread pull towards you , while some pull to the rear and then forward.
Nov 17, 2014 | Sewing Machines
How do I get Singer zigzag 457 to stop hitting the needle on the bobbin housing?
the sewing machine is out of time & needs to be retimed at a
sewing machine repair shop.
here's a link for a free manual
http://www.singerco.com/uploads/download/5d6ce627c00cb91c477d4703f1b704aab08a72c8.pdf
Sep 11, 2012 | Singer Sewing Machines
My mother has a bernina 1008 and now that we have taken the bobbin casing out to clean it won't catch when threaded. Any ideas?
Are you threading the bobbin case correctly - the bobbin should rotate clockwise when pulling the thread out under the tension spring. Are you ensuring that the bobbin case is firmly clicked back into position when replacing it. Check your needle is OK. Did you remove the hook from the hook race when cleaning out - have you oiled the hook race ?
Jan 22, 2012 | Bernina Sewing Machines
The needle shaft wont go up or down when I step on the foot pedal and I cannot turn the wheel to try to do it manually.
If you can not turn the handwheel at all there is a bind in the machine somewere. The most comon place that this will happen is in the hook/bobbin/race area. Follow these steps and it may fix your problem.
Remove needle and bobbin case.
We need to open the race and remove the hook. (The race is the black round part that the bobbin goes inside.)
On the left part of the race there is a small steel clip that you push to the left and it should fall open.
Then remove the hook, it may have fallen out alreay. (It is just right behind the race.)
Clean out that area and make sure there is no broken needle/lint/ ect.
Test to see if handwheel is moving freely with the parts out.
If so lubricate the hook and put it all back together. Should be ready to sew.
Hook needs to be lubricated every 2-3 bobbins
If this does not fix it probably will need to take it in for repair.
Also check to make sure your bobbin winder is not on (I dont think that is it but ill mention it).
Hope this helps
Apr 05, 2011 | Bernina Virtuosa 150
Can't reassemble shuttle hook and shuttle race
the hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Kent
Mar 16, 2009 | Baby Lock BL1556
I am attempting to check to see .. if the RACE for my Brother XL-6562 has sustained some damage (the smaller point broken, perhaps) -?- Long story short: the needle had fallen down into the machine; I...
Be sure you didn't put the bobbin in the bobbincase upside down.
I hope you mean the plastic hook that sits in the metal race is damaged because they are cheap and easy to replace. Also if the tip is damaged at all, even a nick or a burr the thread will catch on it. If its a plastic one replace it with a new one from where you bought the machine or check with a real sewing machine dealer or repair person. Unless you can smooth it out by polishing it or using a very fine emery paper (for a metal one) it needs a new one. The thread will only keep catching on it. The hook is inexpensive. The race that the hook sits in is probably metal is an inexpensive part but an expensive fix.
Good luck.
Jan 10, 2009 | Brother XL-6562 Mechanical Sewing Machine
My brother PE-400 sewing quit sewing
The "race" on your machine needs adjusting. Remove the bobbin cover, bobbin, & case. What you have left is the race, it moves when you turn the large wheel on the top right of machine. The needle also moves up and down. There is a hook on the race that catches the needle thread. Try moving the race to the line up with the needle. It may take a couple of trys but it should do the trick. Also clean any threads that may be caught on or arround the race. Hope this helps!
Jan 02, 2009 | Brother Disney PE-400D Computerized Sewing...
Sewing Machines Logo
242 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
