Motherboard keeps beeping and doesn't turn on, anymore. I've tried replacing the Power Supply unit and it still hasn't solved the problem. I can't locate the original manuel which gives all the error codes corresponding to the beeping sounds. Please help.
  • 2,404 Answers
Have you tried reseating the memory? Sometimes that can cause weird problems when its not in the slot all the way.
Posted on Feb 04, 2009
    President:
  • 2,110 Answers
Try changing the RAM ...
My Acer Aspire M5100 get power but will not turn on
Does the CPU fan come on ?
Does the power lead that plugs into the cpu fan on the motherboard supply the required voltage ?
This one is a bit harder and once you check it you most likely need to apply thermal paste - but is there sufficient thermal paste between the CPU and the heat sink on the CPU ?
Does the power supply box in the tower case have its fan spinning when power on ?
Is the motherboard bent ?
I have seen this one - poor installation with different sized mounting screws. When motherboard gets hot the motherboard went faulty.
Some motherboards need a rubber insulator under the screw maybe there is a short under one of the mounting screws !
Mar 12, 2017 | Acer Aspire M5100 AM5100-U5313A AMD...
My wii went off after a thunderstorm and doesn't get on anymore, can I do something to fix it? I've already changed the battery inside but nothing cheanged.
First make sure the circuit is live - Are there other things on that circuit? Do they work? If not, check that the breaker hasn't tripped, and reset it if necessary. Next, check that that specific outlet wasn't damaged. Plug something else into it. Does it work? If not, the outlet needs to be replaced. Also plug the Wii into another outlet. If it works, this also confirms the original outlet has been damaged. If the Wii still doesn't power on, the power supply has probably been damaged. Unless you can replace it yourself, it probably isn't worth having it repaired.
Apr 21, 2012 | Nintendo Wii Console
The printer doesn't switch on anymore
Most likely dead. Also FYI 99.9% of inkjet printers are not economical to repair. Just replace them.
Jan 09, 2012 | HP Photosmart C5180 All-In-One InkJet...
I drive a 1989 Prelude that can't go a week without experiencing some electrical problem that keeps it from starting up. When I turn the key, a distorted beeping sound is all that comes out of it....
forget that ,, replace the ignition switch, hondas are known for ignitions going out, your intermittent supply of power is from the switch itself
Sep 09, 2011 | 1989 Honda Prelude
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
No beep,no boot
make sure you seated the 24pin power supply and the 2nd power supply firmlly if not replace your power supplyif still dont work your MBoard is damage
Sep 22, 2009 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
My T6528 is not booting at all, I tried everything; changing the
Might be your RAM too !
Remove all memory modules and turn ON.
If there are some beeps, than we found the problem!
Replace the Memory module with a new one.
If you have more than one memory module, try to boot with one and then with others, one by one.
If (when) you get normal boot, then tha's it. Replace the broken RAM memory module with antoher.
You may also to try to put your memory module to antother (your friend's machine) to find if it is OK.
Regards
Mar 25, 2009 | E-Machines Computers & Internet
Pavilion a350n begins start, HDD and CD activity for 10-15 seconds then activitystops. No video and no beeps. Cannot get to BIOS as it does not boot that far. Motherboard?
Dissamble PC. Carefully clean every component with a wind blower. Use soft cloth if required. Assemble them one by one. Try to power on. If it does not solve, replace BIOS battery with new one and try with another working power supply. Still have problem, replace motherboard. Keep informing.
Feb 19, 2009 | HP Computers & Internet
MD or power supply?
if the power supply fan is working when you turn on the pc ,it probably is not the power supply,
and is most likely a motherboard problem ,if you have the ability to install another video card that you have (or a friend may have), this may solve your problem.
i am not sure what you mean when you say "my system unit automatically turn on after i turn on my AVR "
good luck
Terry
Mar 10, 2008 | Asrock 775i65GV Motherboard
Blinking Power LED ... no other action
Hi switchblade, Some of this will seem basic or even a rehash of what you?ve already done but please keep an open mind. The one thing I?ve learned over the years is never assume anything especially when things aren?t working like they?re supposed to. -The first thing I would do is to check each screw, card, connector and component you installed to make sure nothings being shorted out or is improperly connected. Common occurrences are screws touching capacitor or other component leads. -Check the power connectors to make sure everything is connected correctly and that all the contacts are still mounted in the plastic connector correctly. -Check the output on your power supply and verify it?s rated for your motherboard. It?s possible that whatever caused them to replace the motherboard could have been caused by a defective power supply or vice versa. -Make sure the motherboard is correctly grounded to the chassis per your instructions. Typically the mounting screws touch a grounding plane on the motherboard and in turn ground that to the chassis. If your using plastic mounting studs that might be a problem. -Verify the power switch is working correctly. -Make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. -Try a more basic known good video card, a PCI if you have one. -Again whatever problem caused MSI to warranty replace your motherboard could have damaged your processor or memory. I would have expected a beep code but if you?ve gotten this far without resolving your problem we?re running out of possibilities. -If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
Jan 06, 2007 | MSI K8MM-V Motherboard
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
