if you are using word open up word select view from the drop down list select toolbars select standard ,formatting
also open up word across to the left you will see arial,times new roman,arial black next will be more to name a few of the different languages from the drop down list your documents will be read in
also next to that will be a drop down list with all sizes you can change the sizes of text
open up a document you should a number of tabs at the top of your screen you should see a number with % percentage with a drop down list which has many zoom increases
if its a web page
right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
if you need more help with this post a reply
hope this helps
also open up word across to the left you will see arial times new roman arial black next
if its a web page
hope this helps
