Question about Sony VAIO VGN-FS640W Notebook
Cd rom drive not able read data cd
Whenever i insert a cd in my cd rom and dvd+r it shows as an empty cd and promts for burning option.
DVD/CD-ROM: matshita uj-840d
  • Griftorius Feb 11, 2009
    Hello, I have the same problem but I'm using a Sony Vaio VGN-NR10E/S with Vista.
    Is there a similar fix available?
    Thanks
  • 63 Answers
First Go to control panel- System icon- Hardware Tab- Device manager
Expand the CD/DVD roms- Right click on your CD/DVD drive and Uninstall it.
Now download the utility from the following link and just run it on your system.
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
It will take a quick minute to run this utility.
After this restart your computer. It should work fine
Posted on Feb 04, 2009
    President:
  • 2,110 Answers
Try to clean the dvd rom lens with a lens cleaner..
Dell Inspiron 1420 is not able to read empty cds or DVDS. My I go to properties it shows empty space as 0. When I try to burn a Cd it says " Insert a blank CD"
Stephen buddy, we need to talk. I do NOT understand anything you are trying to describe. Okay, so you installed a FRESH Operating System and now it is NOT recognizing your DVD-rom, right? Okay, restart the computer and let Windows load up fully. Check Control Panel and check your list of Devices. Sometimes, when you re-install and O.S., you may have to update the firmware or drivers for certain devices.
Feb 05, 2014 | Dell DVD-rom DVD Drive
Remove Write protection from DVD disc
1. Insert the DVD disc into the computer's DVD-ROM burner drive. Click on "Burn files to disc" from the window that automatically pops up.
2. Type a name for the DVD disc in the "Burn a Disc" box. Click "Show formatting options" and choose a formatting option.
3. Choose "Live File System" to allow files to be copied immediately to the DVD disc, much like sending data to a USB flash drive or floppy disk. Live File System discs can only be read by Windows XP or later versions. Choose "Mastered" to have files be copied to the DVD all at once. This is the standard burning method; discs can be played back on any DVD-ROM drive.
4. Click "Next" to prepare the disc. Files can now be copied to the disc using the selected method.
Sep 04, 2012 | HP Computers & Internet
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
I can't insert any cd's.
Maybe the laser eye is jammed. It tracks back and forth reading data from the disc.
You may either replace the drive or have it repaired.
I had one on my PC do the same vibrating, clicking noise. It only cost 40.00 to replace.
But for a laptop, you're looking between 60-100 dollars to replace.
You can see how much it would cost to repair first, but my guess is it would be cheaper to replace.
Jul 12, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
My cd rom won't detect blank cds
try re-installing your burning software ( nero-Roxio et,c )
Does it play a standard Music/Audio CD.
if not un-install and re-install the drive.
Are the cables to the drive connected correctly ?
Does the drive support CD+ And CD- media ?
Are the cds definately Blank, any small amount of data written to them, after failed burn attempts will not show the disk as being empty.
Mike @ Compurepair.
Jun 13, 2009 | Dell Computers & Internet
DVD ROM can play CD, but not DVD
try with next dvd which is burnt in less than 16x speed then check what happens.
Jun 02, 2009 | ASUS (E616P2) Internal DVD Drive
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Dvd fault
your laser is faulty and is only able to read cd tracks, the reason being that dvd's data is packed closer together than a cd, and when the laser is failing it can only read wider burned data tracks on cd's.
You will have to replace the drive
Sep 05, 2008 | Computers & Internet
Data are not shown
most older drives can't read multi session... you need to have a drive installed to be able to read multi session burn. there is no software tweak that can fix this... you need to replace the drive. otherwise burn the data as single session.
Jun 03, 2008 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Try to burn a cd
Hi, make sure that you have the right type of CD or DVD in the burner. From what you have written about what you drive is it is a "_" not a "+". It actually makes a difference. You may have acidently bought the wrong type for your burner and this will bring up that error.
Check your CD's and give that a go.
Oct 27, 2007 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
Sony VAIO VGN-FS640W Notebook Logo
402 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
