Question about Smeg 23 in. SA435X Electric Cooktop
Smeg SA435 - spark and loud sound
I switched my SA 243 top right burner (large one) on and was boiling some vegetables. There was a loud sound and a spark came out of the plate and the circuit break tripped.
i switched the hob off and tried to switch on the circuit breaker but the spark happened again.
what do you think happened and what is the solution
    Novelist:
  • 222 Answers
Hi gud day,much better call an electrician to check ur main power & the outlet of ur unit.if ok i think the problem is inside the unit,open wire or have a ground inside coz of over using the item that may coz of the wire is melting.tnx
Posted on Feb 22, 2009
  • gerbee gomez Feb 22, 2009
    hi gud day,much better call an electrician to check ur main power & the outlet of ur unit.if ok i think the problem is inside the unit,open wire or have a ground inside coz of over using the item that may coz of the wire is melting.tnx
One burner ignitor does not work
Try cleaning the burners by boiling them in degreaser like soda crystals. Burnt food can act as an insulator to the current for the spark which is grounded through the burner. If that doesn't work, you need to left the top of the hob to check the wiring underneath.
Oct 29, 2015 | Kenmore ELITE 790 30 FREESTANDING DUAL...
One of my igniter in my smeg gas cook top does not spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 30, 2011 | Smeg 23 in. SE64 Gas Cooktop
My smeg cooker is brand new! after cleaning it - one of the rings will not ignite properly, it clicks so gas is coming through but no flame! any sugestions?
Brand new means you have a warranty, get the service agent to check.
I have found that you can easily place the wrong burner cap on the incorrect burner ring(the smaller burner caps).
Could also be dirt or water in burner ring or the burner jet(use needle to clear jet).
Are sparks coming from all ignitors? You might have damaged the spark plug.
May 01, 2010 | Smeg 23 in. SE64 Gas Cooktop
Ticking sound on the gas top after burner is off. How do I stop?
Remove all the burners and thoroughly clean in warm to hot soap and water. Do the same for the burner seats on the cooktop.
Dec 21, 2009 | KitchenAid Cooktops
Suddenly I hear a constant 'clicking' sound from the Maytag csg7000 cook top which I am not using right now. It's like it's trying to ignite by itself. What could be a problem?
usually this is a problem with one or more of your ignitor switches, they are found below the selector switches, below the top, if you take off the selectors you might even be able to see them,
these are what sends voltage to you ignitor, from the spark module, one one goes bad, they all tend to spark, because light one light all....
http://www.appliancepartspros.com/part_details.aspx?part_id=4101545
this link wil take you right to the part i suggest,
as well as be able to order it
since this happens alot after a boil over i would start with one of the front two burners,,,, you can order one and keep replacing them with the next till the clicking stops
Nov 04, 2009 | Maytag 30 in. CSG7000 Gas Cooktop
Ignitors keep making ticking sound, all burners turned off, won't go in lock position, and one burner will not ignite gas despite constant ticking
Probably a spillage or boil over has clogged the burner and some of the liquid has dampened the shank switch mounted on the burner post. Get a shop vac and clean the burner. Wait a day or 2 and see if the switch stops. OR disable the ticky ticky by removing the bottom drawer and looking for the spark module. Remove one of the hot wires and tape it up. Light the burners like granny does with a match. LOL
Jul 17, 2009 | GE 30 in.Profile JGP945 Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
Jul 17, 2008 | GE 30 in. JP340 Electric Cooktop
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
Smeg 23 in. SA435X Electric Cooktop Logo
183 people viewed this question
Top Smeg Cooktops Experts
Timllfixit
ray gallant
marlin siecinski
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
