Question about Makita DPC6410 64cc 12" Power Cutter
Help my work crew forgot to put two stroke oil in the mix
The engine has seized in will not turn over. Is it to be scraped or is it a Fixya?
    President:
  • 2,220 Answers
Piston and cylinder kit to fit Makita. $190.00
http://www.baileysonline.com/itemdetail.asp?item=DM+038130030&catID=
Ups saw from 64cc to 79cc weight is almost the same.
HTH
Lou
Posted on Sep 09, 2009
Heat some 2 stroke oil in a pan remove the spark plug and poor down the bore when boiling hot,now try and pull the starting cord to release the rings,be carefull not to get burned,and be carefull if the piston comes free the hot oil comes out of the bore.if you free it up replace spark plug and try and restart it.
Posted on Aug 13, 2009
    President:
  • 2,692 Answers
It is possible to fix most everything but not cost effective. Your rings likley seazed to the cylinder walls and the rod bearings seaced to the crankshaft and case. You can. of course , take it apart but that  will just further confirm  that is is now junk. You can price a shortblock and change it out.That might be cheeper than new.
Posted on Feb 04, 2009
The thing was working fine i shut it off and when i went to start it ,it doesn't turn its like its seased
well is it seized , when you try to pull to start will it turn at all , is this a 2 stroke motor or a 4 stroke motor if 2 you have to put 2+2 gas oil mix in it ,if a 4 stroke motor just gas , oil is seperate tank
Jan 20, 2015 | Homelite Garden
Honda nsr250 mc18
The NSR is a 2 stroke, so it needs 2 stroke oil as well as petrol. This is the reason they are known as "Stinkwheels". If the engine is run without oil in the mix it will seize. As the oil provides lubrication to the moving parts. You should also check the spark plugs are clean, they can oil up in a 2 stroke, especially if the engine is used a lot at low revs.
May 03, 2013 | Motorcycles
Have put straight fuel in Echo Hedgecutter is there anything I can do, it actually stopped working
does it turn over at all, if not try pulling the head cover off and giving the top of the piston a few raps with a piece of wood and a hammer. Hopefully you didnt sieze it up completely.
Mar 13, 2011 | Garden
Hi, I have a Masport 635 Lawn mower, I think it is 2 stroke, just petrol ( not mixed with oil ). I don't know anything about how to maintain mowers. But today I mowed the back yard, it went fine, then...
If it is two stroke it must have oil mixed in with it. Try pulling the cord and notice if there is any compression if not then it is the pistion and if it doesn't turn then it is seized with lack of oil.Now if it is four stroke take the plug out put it to the head and pull the cord to see if there is any spark if there is it's a fuel problem.
Jan 15, 2011 | Briggs & Stratton Briggs Stratton...
What is the fuel mixture ratio?
this will run on 50-1 mix,,but i would run it on a 40 - 1 mix unless yuou use the right 2 stroke engine oil,,if you use car engine oil mix it at 40 - 1 look at it this way,,,its a 2 stroke so it needs oil or it will seize up and reck your engine,,if you put a little more oil in it will smoke a little bit more but it will never seize up,,,mine is 20 years old now,,,time speeks dont it?
Dec 02, 2010 | McCulloch 30cc 2Cycle 180 MPH Gas Powered...
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What sould the oil Petrol Mix be 1:60 or Less
The standard mix is 32 to 1. This means 4 ounces of two stroke engine oil per gallon of gas. The lower the ratio ( like 60 to 1 ) the higher the risk of seizing the engine. Do not use motor oil, only 2 stroke engine oil.
Aug 04, 2010 | 1998 kawasaki KDX 200
What happens if you dont mix oil into the gas?
You blow up. Depends, does your bike have oil injection? Then you don't have to mix the oil in the gas, If it doesn't, then you will have to mix it in the tank. No lubrication in your engine, and I will give it about 10 mins before it seizes up from heat. And don't try to sneak motor oil in there in a pinch, because it won't work. Motor oil compared to 2 stoke oil is like 40 grit sandpaper to a babies ****. I'm talking rough. I use 2 stoke for everything, it is super lube. Hope this helps.
Mar 08, 2010 | 2004 kawasaki KLX 125 L
Possible seal failure
Gearbox oil may be getting into the crank area. Check the oil in the crank, is it motor oil or two stroke oil? If it is motor oil then you will need to split the center case and clean/re-seal the case halves. Be sure to install new crank seals. New crank bearings? If 2 stroke oil, just put a cup of gas in the crank to thin the oil, rotate the crank a few times to mix gas and oil, then just tip the bike over to dump the mix out of the case. If the bike has an oil pump, see if you can lessen the stroke of the pump. If mixing 2 stroke oil in the gas tank, Be sure to use only 2 stroke engine oil at 32 to 1 ratio. That equals 4 ounces of oil to a gallon of gas.
Nov 18, 2009 | 2000 Husqvarna WR 250
I just bought a 2 stroke 49 cc atv. Everything was working fine untill the engine just cut out. It started once or twice after several pulls of the cord but cut out soon after once again. PLEASE HELP, i...
hi mate are you mixing the bike with 2 stroke if not buy a mixing bottle with a ratio of 32/1 on ebay and buy 2 stroke and mix it up with petrol and oil if not the engine will seize also take the spark plug out and give it a clean with a wire brush and check the gap is ok and then put it in the plug cover and put the plug against the cylinder and turn the engine over and see if there is a descent spark if not replace the plug good luck
Jul 21, 2009 | Fender 2 Stroke Full 49cc ATV # ATG-47B...
Makita DPC6410 64cc 12" Power Cutter Logo
276 people viewed this question
Top Makita Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Makita Measuring Tool and Sensor Expert? Answer questions, earn points and help others
