Question about Troy Garden
Need help with replacing starter cord on Troy Bilt trimmer
I have a Troy-Bilt TB525CS trimmer which needs a new starter assembly.  It is under warranty but I now find that means nothing and I will be charged $60 to check it out and the shop tells me Troy-Bilt won't honor the warranty so it's a waste of time.  I decided to order the part and replace it myself, couldn't be that hard, I have been a mechanic for years.  Well, I got the trimmer apart and now I can't get the motor out because the flywheel is preventing me from removing the engine shroud, the red plastic shroud which covers the front of the engine.  The flywheel is about 3'' around and has a nose shaft on it.  It looks like there is an allen screw holding it onto the crankshaft, but I cant get anything to fit the screw.  Do I need a special tool to press this off the shaft?
  • Brian Mathews Feb 04, 2009
    Hi Mr. Fix-it, thanks for the reply.  I looked online for an IPB diagram and I realized I am not using the correct terminology for the parts I need to remove.  First of all, I already removed the shaft and the throttle assembly.  I also removed the clutch cover which was just a plastic housing.  What I need to remove now is the clutch drum.  The clutch drum looks like a small automtive brake drum, and it houses the centrifigul clutch.  I thought there was a screw in the center but after looking at the parts breakdown, there is no screw listed or shown on the diagram.  I don't understand how this comes off the crankshaft since I can't unscrew it, it just spins on a bearing.  Do I need some kind of puller?
  • Brian Mathews Feb 05, 2009
    Thank you again for the help Mr Fixit.  I just finished putting it back together and it works great.  I pulled the spark plug and stuck a 1/4" extension in there and used a T-20 screwdriver to remove the screw.  Then once I got the clutch drum off, I found the clutch assembly and hit it twice with a brass drift and it loosened up and came off.  I had a little trouble getting the starter return spring set correctly, but I figured out a way to get some preload on it and it pulls perfectly now.  I stowed the starter rope in the pulley and turned the white plastic disc two turns clockwise before pulling the rope through the guide collar, this way it has plenty of spring pressure to pull the rope in.  You saved the day for me!!  I couldn't see paying $80+ for the repair and I ordered the part instead.  The jerks at the saw shop were joking around that they would see me back soon after I tried to install it myself... well, I got it done myself!!
4 Suggested Answers
  • 127 Answers
SOURCE: replacing pull cord on 4 cycle gas trimmer, troy bilt
these usually are threaded counter clockwise need a pair of channel locks to hold the flywheel then with the other hand crack nut open
Posted on Jun 30, 2009
bbreton
  • 437 Answers
SOURCE: Need to change pull rope on Poulan Pro Weedeater
sounds like you are trying to remove the drum assembly; try a torx driver or a phillips screwdriver. There is a srew that hold that drum on and the bolt is in that black hole.
Posted on Sep 29, 2009
Testimonial: "read suggetions & took another look. Found a small flat blade screw driver would work. Appreciate the help"
  • 61 Answers
SOURCE: What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Posted on Apr 14, 2010
Testimonial: "Thanks for the tip, I will try that when I find out the fuel line size."
  • 202 Answers
SOURCE: How do I fix/replace the starter rope on a TB20CS
Probably no special tools needed. Take the starter assy off. Turn the recoil in the direction it will turn if you are pulling the rope. When it gets tight, hold it there and install the new rope. When it is installed, let go of the recoil and it will draw the rope in.
http://www.mylawnmowerforum.com/forum/
Posted on Aug 09, 2010
I need to know what kind of oil to put in my troy-bilt 4 cycle weed eater. I think the model num. is TB525CS, it's on the front of the weed eater right under 4 cycle.
Hi jo6616...
Use a good grade of 10W30 non-detergent oil in your weedeater.
Free answer....Please take time to rate me
May 30, 2011 | Troy Garden
How to change trimmer ine in tb525cs - troy built 4 cycle trimmer
You need to unscrew the black bumper button. I believe it is counter-clockwise. Mine was very tight and took a pair of channel lock pliers to loosen.
Jun 21, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
What size string do i need it is a tb525cs
Probably .065 to 080 line will probably do the trick .A line with 3 or 4 edges works great on everything
Oct 21, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt TB525CS Line Keeps Being Sucked into Housing
You may have wound the line in the wrong direction. Check it out. We all do it at least once...Lee
Sep 09, 2009 | Garden
Troy bilt string trimmer starter rope
you need to rotate the starter pulley up first to tension the spring.... then feed in your rope tie a not and let it retract the rope into the starter pulley
Aug 06, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Starter cord is jam.
must take the cover off, get the assembly and shoot some lubricant into it, theres a spring that binds up if it isnt lubed it will lock up
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
The starter line on my trimmer will not pull at all.
Remove spark plug to see if problem is in engine or drive unit
May 20, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
1,098 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
