Question about Campbell Hausfeld 26 - Gallon Air Compressor
My campbell and housfield 60 gal wont run.. help
I bought her from a guy used and said it worked great. she is a single phase elect. 5 hp. 60 gal. i brought her home on her side all the oil ran out so i filled it up with oil, ran a 10 amp service to it and turned it on it started and ran for a minute but sounded funny like it would start the motor then stop over and over and over agianfor split seconds then stopped and never made another sound. there was no air in the system and i can hand turn the belt (seems right) . note: there was damage to one of the covers over the (compasator???) on the top of the motor no visable damage to the black tube like compasator looking thing, that im tring to figure out what it is? please help make her run!!!!!!
  • thrillbilly Feb 05, 2009
    PROBLEM
    PROBLEM UPDATE: i got it to start again but it runs for a min then it pops the reset button i have a hard time reseting it but it does reset. but continues to do this
10 AMP CIRCUIT SOUNDS WEAK. WIRE MAY BE TOO SMALL. ARE YOU SURE ITS NOT WIRED FOR 220 VOLTS AND YOUR RUNNING IT ON 110. START CAPACITOR COULD BE BAD BUT TYPICALLY WOULD LEAK OIL-LIKE FLUID IF IT WAS DAMAGED. CUTTING OFF AND ON CONTINOUSLY COULD BE THE PRESSURE SWITCH IS DAMAGED. SOUNDS MORE LIKE WRONG VOLTAGE. THERE ISNT A LOW OIL PROTECTION DEVICE.?
Posted on Mar 20, 2009
  • 3 Answers
Get a job ******
Posted on Feb 07, 2009
Dewalt radial arm saw GW1- Is it single phase or 3 phase
if the plug on the cord fits any other outlet in the house it will be single phase
if the cord is cut , then it will have only 3 wires if it is single phase
( active , neutral and ground )
if it has 4 or more wires it will be 3 phase
most saws running a 200 mm blade or around that size and used for home duty will be single phase
the phase notation will be on the plate attached to the motor of the saw
It will read voltage , amperage, watts or hp, phase and cycles
Jan 02, 2016 | Dewalt Saws
Need motor specifications
gonna guess..1.25 hp 240 volt single phase continuous operation..two speed 1025 rpm 23 50 rpm high side..gal/hr rating unknown..
Nov 19, 2013 | Emerson Pool & Spa
Sometimes IR 30 goes into a strained free wheeling state
Did you change the 3 phase motor out with a single phase motor? A 3 phase motor cannot be made to run on single phase.
Feb 02, 2013 | Ingersoll Rand - Rand Type - 30...
I have purchased Faema E98 President from Dubai. I was told that this model works on both single phase and 3 phase. I brought the electrician to fit the single phase but he didn't understand the single...
This may be useful;
http://www.home-barista.com/espresso-machines/electrical-trouble-on-faema-e98-2-president-t6943.html
There is no dificulty with single or 3 phase wiring.
Try a qualified electrician!
Mar 07, 2011 | Microwave Ovens
I have a brand new IR compressor model 2475N7.5 with a 7.5 hp 460v 3 ph motor. is it possible to convert it to a single phase power supply? or should i just exchange it? ... I ordered it thru Northern Tool...
When you google home made 3 phase converters, you will find many ways to make use of 220v single phase instead, however you are limited as to the hp that the motor will produce. If you spin the motor first then apply 220v, the motor will continue to turn at much reduced hp. You need full power to turn a type 30 pump depending on pulley combination/ setup. Best to return the unit and get one that will run on 220v single phase. It will most likely consume more power to do the same work however it would cost a great deal to install 3 phase. Most likely not even available at all. Many years ago, I worked at Sears and happened to see an electrician coming down from roof access of building. He told me that sears had a 3 phase generator being turned by a 220v single phase motor to run an air conditioning unit. He said that it worked quite well. Does not sound cost effective.
Jan 08, 2011 | Ingersoll Rand - Rand Type - 30...
I had a 242-5D on a 120 horizontal driven by a 5 hp Dayton motor. I changed to a 2475N7.5 on a 80 gal vertical with a bad motor. I want to reuse the Dayton 5 hp motor. What can I expect?
Im not sure if iv;e got this straightYou had a 242running on 120 v driven by 5 hp dayton motor You have a new 80 gal tank with a bad 7.5 v motor and want to put the 5 v motor on it What was the size of the old tank if it was 60 or more you should be ok the 5 hp will have to work harder as long as you can make it fit you may want to consider droping down the blow out valve presssre spec 10 to 15 lbs depending on the size of the old tank
Nov 21, 2010 | Ingersoll Rand - Rand Type - 30...
Ryobi electric log splitter won't return to startposautomaticaly
We have one of these splitters and the only problem has been a control valve sticking down. Oiled the valve button with silicon oil which seems to have helped. Be sure to close the bleeder valve when putting the machine away. We bought the machine from Home Depot. Use some headphones for your music! We have split rounds much larger than recommended by splitting from different sides. Hope this helps!
May 26, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
340 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
