SOURCE: Teac R2 clock radio--Cannot set the clock.
Press and hold the CLOCK ADJUST button for more than 3 seconds.
"SET" and "CLK" appear alternately in the display.
Turn the MULTI JOG knob to adjust time.
Press the CLOCK ADJUST button again to finish.
SOURCE: Lost our manual. Can't unset auto on clock radio.
This should keep you from goin crazy anymoe.please remember to vote
http://www.timexaudio.com/pdf/T307_IB56281_07.pdf
Testimonial: "Thanks. Appreciate it."
SOURCE: Lost my owner's manual for my TIMEX T307S clock radio.
You can download the user manual from this link
SOURCE: i have lost the operating manual for a technika
I HAS SAME PROBLEM BUT FOUND THE ANSWER. PRESS STANDBY AND TURN UNIT ON, THEN PRESS ALARM BUTTON, DISPLAY SHOWS ALARM 1, PRESS SELECT BUTTON DISPLAY SHOWS FM/DAB/BUZZ, PRESS LEFT/RIGHT BUTTONS TO SWITCH BETWEEN WAKE UP OPTIONS, THEN PRESS SELECT AGAIN, DISPLAY SHOWS OFF, PRESS LEFT/RIGHT BUTTON TO TOGGLE BETWEEN ON/OFF LEAVE 'ON' SHOWING, PRESS SELECT AGAIN DISPLAY WILL SHOW ALARM TIME, USE LEFT/RIGHT TO SET HOUR THEN PRERSS SELECT, USE LEFT/RIGHT TO SET MINUTES TEHM PRESS SELECT AGAIN, DISPLAY WILL NOW SHOW SMALL ALARM CLOCK IN DISPLAY WINDOW, THIS MEANS ALARM IS NOW SET.
