Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
My KitchenAid Dishwasher won't start
My dishwasher will not start. I checked the fuse box and there is power going to it. Machine just will not start. Did this happen to anyone? I don't know what to do next. Thanks for you help
  • 3 more comments
  • mythreeboys3 Feb 05, 2009
    No, nothing lights up. My brother took the bottom panel out and said there was definitely power going to the machine. Thanks
  • Anonymous Feb 12, 2009
    Same problem, the DW is getting power but t just won't turn on and all the lights are off.
  • curlhome Apr 15, 2009
    Mine won't start either. It was working fine yesterday. Today no lights will come on. I tried plugging it into another working outlet ....no dice. Is there a reset button somewhere? This dishwasher is only 6 years old and this is the third time I've had to have it worked on (different problems). I'm very disappointed in its durability, but when it works it really works.
  • Anonymous Apr 16, 2009
    POWER IN, NO WORKEE AT ALL
  • dcrosin May 11, 2010
    Does it light up at all? Take off bottom panel and open up electric junction box and make sure there is power actually getting to the machine using a tester.
SOURCE: KitchenAid 24 in. KUDI01FLSS Stainless
Open the dishwasher door, press in rapid sequence the following keys: Hi Temp Scrub, Energy Saver Dry, High Temp Scrub, Energy Saver Dry. Close the door until it latches and press the Cancel key. The machine should reset itself. It worked for me when I had the same problem
Posted on Jan 14, 2008
SOURCE: Hotpoint dishwasher BF1620 blew the main fuse
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Posted on Feb 07, 2010
  • 128 Answers
SOURCE: Kitchenaid dishwasher will not turn on or drain
Float valve is jammed.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Not working?
Check for a clog internal or external.
Scoop as much water our as you can. Open the cover on the floor of the machine. Usually just turns and lifts out or snaps out some are screwed in. Take your time and try not to force anything. Look for a clog there.
Check for clog in the drain. The dishwasher will connect to the drain under your sink and run either directly to the drain or into your disposal unit. Remove open the connections and look for a clog. Clear if necessary.
Not the clog?
Water is pumped out by the machine via an internal pump located under the base. If it fails the water will collect until it trips the float valve. First scoop out all the water from the machine and run it again. If water comes in and it runs to the point it fills again and trips the float then either the pump or timer is faulty.
Pump check.
Remove the machine. It will be held in place by screws directly into the counter top. You may have to lower it to get it out. The front feet turn with a wrench to lower.
Turn off the water supply. Run the unit again until you get to the drain cycle.
Connect a test light or voltage tester to the terminals at the pump. Check for voltage at the pump. If you have voltage replace the pump. If no voltage the timer is faulty.
Timer problem?
Some can be replaced as a unit others are integral to the control panel. Turn style can be replaced. Touch control can not.
For more help go to my more detailed tip "Dishwasher will not run. DW101 how to fix". Or click on my profile and you will find the link there.
Hope this helped you. Please take the time to rate this tip.
Thanks,
Adrian
Posted on Mar 17, 2010
  • 10865 Answers
SOURCE: Where is the fuse box on a Kitchenaid dishwasher,
There is no fuse box inside the dishwasher. The fuse box or electrical panel for your house is where you shut off the power to the dishwasher.
please mark this answer as a fixya!
Posted on Mar 09, 2009
localwonder
  • 6784 Answers
SOURCE: Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
Posted on Jun 11, 2009
Dishwasher is not turning on...no power
Make sure that the connectors in the power connector box are good. Sometimes they will burn off in the box.The door switches can go bad. the control can go bad. if a whirlpool some Amanas and kitchenaid modekls have a thermal fuse on the electronic board.
Oct 10, 2014 | Dishwashers
Kitchenaid whisper quiet plus dishwasher
It is likely the thermal fuse is cut off and will need to be reset or replaced depending on the model number of your dishwasher. Please provide actual model number in the comments.
Apr 25, 2014 | KitchenAid Dishwashers
Replaced control panel for dishwasher and it still won't run
sound like the thermal fuse on the main control board is bad. replace the fuse and it will be ok. the fuse is the white rectangle with a black, and a black w/white stripe that clips to the top of the control.
Jan 31, 2012 | KitchenAid Dishwashers
No power getting to machine
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
Dec 19, 2011 | Tecnik 18 in. TKD7000 Built-in Dishwasher
KitchenAid Dishwasher model# KUDR24SEBL1 Doesn't have power.Front panel is no longer lit up and machine does not go on when a load is ready for washing
The most probable thing that is causing the dishwasher to not start is going to be a blow fuse that clips onto the control board. This tip i wrote explains how to check that fuse.
http://www.fixya.com/support/r10341846-will
GENE
Sep 18, 2011 | KitchenAid Dishwashers
I have a KitchenAid dishwasher model # KUPDO1DLBSO, S/N FM4003050. There is no power to the control panel, no lights and won't start. It stopped in the middle of the cycle with water left in the...
what most likely is going to be the problem is a blown thermal fuse that attaches to the control panel housing. gain access to the control panel and use should see the thermal fuse,the housing for the control board is grey and this part is white.Remove the wires to it and check for contininity on it using a ohm meter set to a low ohms setting. If it turns out to be good the next thing to check is the switch(s) on the latch asm using the same method to check them as the fuse.BEFORE CHECKING EITHER OF THOSE BE SURE TO DISCONNECT POWER TO THE DISHWASHER
Good luck, i hope that i 've helped you to figure out what is wrong with your dishwasher,
Gene
Aug 06, 2011 | KitchenAid Dishwashers
Kitchenaid dishwasher kudi02ir will not start!
If the unit won't start and there are no signs of power make sure you're dishwasher is getting power. If so then likely you will need a new fuse which if you go to the link below, you can download a video to show you how to replace the fuse on your dishwasher.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/control-repair-whirlpoolkitchenaidkenmoremaytagjenn-air-amana-dishwashers/
Good luck
Mar 01, 2011 | KitchenAid 24 in. KUDI02IR Built-in...
My dishwasher won't start.
FIRST MAKE SURE YOU HAVE POWER TO THE DISHWASHER. IF IT HAS A LIGHTED PANEL AND ITS LIGHTED UP, YOU HAVE POWER. IF NOT LIGHTED UP WHEN TURNED ON, THEN YOU HAVE A POWER LOSS PROBLEM WITH A FUSE OR BREAKER OUT TO THE SUPPLY WIRE TO THE DISHWASHER. CHECK YOUR ELECTRICAL FUSE BOX OR FUSE THAT SAYS DISHWASHER IN THE ELECTRICAL BOX IN YOUR HOUSE. RE-SET THE BREAKER OR CHANGE THE FUSE. IF IT STILL DOSE NOT START UP THEN YOU MAY HAVE AN ELECTRICAL CONNECTION UNDER THE DISHWASHER THAT IS NOT CORRECT OR NEEDS TO BE LOOKED AT BY AN ELECTRICIAN. DO NOT TRY TO CHECK THIS AREA UNLESS YOU HAVE THE FUSE OR BREAKER OFF. THEN LOOK TO SEE IF YOU HAVE A LOOSE CONNECTION. RE-TIGHTEN THE LOSE CONNECTION FOUND, TURN ON THE FUSE OR BREAKER AGAIN, AND SEE IF THE LIGHTED PANEL LIGHTS UP. IF IT STILL DOSE NOT START UP, THEN NEXT CHECK THE DOOR TO MAKE SURE IT IS CLOSING ALL THE WAY, THERE IS A SWITCHON THE DOOR THE SENCES FULL CLOSED AND WON'T START UP IF THE SWITCH IS NOT CLOSING. IF THIS DOES NOT FIX IT THEN YOU WILL NEED TO CALL YOUR LOCAL DISHWASHER FIX IT MAN. DISHWASHER HAS A PROBLEM HE MUST FIX.
Feb 20, 2011 | KitchenAid Dishwashers
Kitchen aide dishwasher won't start. Water left in bottom after last cycle. No lights will come on along the panel. KUDI01FL
I had this and the thermal fuse needed to be replaced ($14 part).
If the lights won't come on on the controller and you are sure you have power to the dishwasher, then check the thermal fuse.
1. turn off the power to the machine
2. open the door and unscrew all the screws along the inner edge
3. gently split apart the layers of the door and access the controller; it is inside the door and just below the buttons that are supposed to light up.
4. the thermal fuse is white and clipped onto the side of the control box close to the top of the door.
5. unplug the leads going into it and check it with a multimeter - if no current goes through it then it needs to be replaced
relatively easy fix - good luck!
Aug 07, 2010 | KitchenAid 24 in. KUDI01FL - Multiple...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
897 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
