Question about Brother MFC-8840D All-In-One Laser Printer
Putting out extra sheets
My Brother MFC 8440D shoots out a blank sheet of paper in between every sheet that it prints. If I stick this paper back into my tray then it seems to jam it up. Also, the ADF is not working properly, I have to manually lift the lid to it to get it to pull paper through and half the time it doesn't work. Also, my row of numbers, 3, 6, 9, and the # symbol do not work at all. I press them and nothing shows up on the screen.
Do you "fan" your paper when you fill the machine? paper will adhere together, unless you " grab any corner of the fill, pull towards that same corner to allow air to get between the sheets.
Posted on Jun 23, 2009
How can i make double sided copies on a brother mfc 7420 printer???
The manual doesn't say it will do double sided copies. it will copy two pages to one sheet of paper or 4 pages to one sheet of paper. you will probably have to make a copy of the document and then reload the paper back into the tray. experiment with it like put it in face down or face up then which is the top of the page. you can use a marker on a blank sheet of paper to see how it prints out.
hope this helps
Jan 28, 2011 | Brother MFC 7420 All-In-One Laser Printer
My Brother HL-5740 Is jamming after every print jog. It's pulling two sheets through, the first sheet with the print job and the second sheet clear, Its like every job has two sheets. The second sheet...
You probably need to clean the paper pickup roller above the paper tray. A clean cloth dipped in diluted kitchen detergent and a couple of drops of alcohol, will clean the rubber rollers. Stroke the cleaning cloth firmly from side to side all the way around all the rollers. Also clean the paper separation shoe (rubber pad) at the front of the paper tray. The last thing is to make sure your paper is dry. Damp paper sticks together
Oct 16, 2017 | Brother HL 5140 Laser Printer
Brother MFC 4420C prints plain sheets of paper.
To start ensure that is not a software problem.
Go to Control Panel >> Installed Printers. Remove the printer. Install the printer again using the software disk or downloading the driver software from Brother website.
If that does not fix the problem, and the printer prints blank sheets, then it is usually a clogged printhead.
The printheads can be cleaned removing the ink carriage and soaking it in isopropyl alcohol overnight. If that does not work, then the printhead must be replaced.
Regards
Jun 17, 2009 | Brother MFC 4420C All-In-One InkJet...
Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Apr 30, 2009 | HP Photosmart D7160 InkJet Printer
Extra paper pulled
Some rubber lining or rollers is out of line, if you can fix that it may work properly.
Oct 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
Will not print
Did you do a testprinting after cleaning? Do you have all blocks in bk, c, m and y?
Sep 13, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-8840D All-In-One Laser Printer Logo
107 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
