Question about Kenmore 46462 Front Load Washer
Error F-28 Washer power on and add a garment lights but nothing occurs, the a fault error 28 is displayed. We have tried what the manual says
  • 15,935 Answers
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Washer will not run or complete a diagnostic.
    1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
    2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
    3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
    4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
    5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
    Back to Top
    Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
    Mar 14, 2015 | Kenmore Washing Machines
    Hi I have Panasonic camcorder hoc-hs700 when turn on camra after few second later message on screen hdd error occurred please turn off unit and on again I have done that several time .but not luck pl
    Hello there .
    Well according to a manual,
    Sounds like the Hard Drive is faulty.
    "ERROR OCCURRED. PLEASE TURN UNIT OFF, THEN TURN ON AGAIN." is displayed.
    The unit has automatically detected an error. Restart
    the unit by turning the power off and on.
    The power will be turned off in about 1 minute if the
    power is not turned off and on.
    Repair is needed if it is repeatedly displayed even if it is restarted. Detach the power connected, contact consumer support. ( Do not attempt to repair the unit by yourself
    So......why not try a FORMAT of the Hard disk drive which seems to be at fault....nothing to lose friend Worth a try !!!!
    Page 142 of this manual http://service.us.panasonic.com/OPERMANPDF/HDCHS700-MUL.PDF
    Sep 16, 2014 | Lands Phones
    My dryer is displaying F70, and will not work, other than drum light. The dryer is a kenmore smartheat quietpak 9 model 11087081601
    The F70 error indicates a heartbeat failure of the central control.
    If the error occurs while the washer is running then likely it is a problem with the interface. If the error occurs while nothing is running then the central control is most likely at fault.
    If the error occurs while the motor is running then the console/membrane is most likely at fault.
    This problem can be caused by a short in the low voltage circuit.
    It is a difficult problem to pin down and the parts are to expensive just to replace so I suggest a technician check and repair this problem.
    Jan 01, 2011 | Kenmore Dryers
    My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
    What does the Sd code mean?
    This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
    Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
    Use only HE High Efficiency detergent for BravosTM washers.
    Is "Sd" displayed and the wash cycle dial is flashing?
    This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
    Is "Sd" displayed and the wash cycle dial is not flashing?
    If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
    Is the drain hose kinked or clogged?
    Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
    To remove the error display, press Power/Cancel or Pause/Cancel once.
    If Power/Cancel or Pause/Cancel does not work:
    1. Unplug the washer or disconnect the power for one minute.
    2. Plug in the washer or reconnect the power.
    3. Re-select the cycle and press Start/Pause.
    NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
    Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
    Whirlpool washer duet is flashing after adding garmet. Will not return to washing
    April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
    MODELS: See additional page for Kenmore model numbers
    COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
    CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
    PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
    MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
    Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
    Kenmore h2 error code
    Jan 11, 2010 | Kenmore 46462 Front Load Washer
    Control lock light will not go off.
    Do you have any error codes?
    Does water remain in the washer after the final spin?
    If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
    Is the door locked and the Add A Garment light on?
    If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
    Is the door locked and the Add A Garment light off?
    If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    I have a whirlpool front load washing machine model WFW8300SW00
    Hay Crab.
    what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
    replace the pressure switch and it will solve your f21 error.
    It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
    Apr 05, 2008 | Washing Machines
    Kenmore 46462 Front Load Washer Logo
    100 people viewed this question
    Sal De
    fordexpert
    Robert Rankin
