Question about Nintendo DS Lite Console
Need to replace the power jack
To charge my ds, you need to push the cord down and hold it there somehow. I bought a new power jack and now I need instructions on how to replace it.
I am replaceing the housing shell so I figured to do both while I had it opened up.
  • Beth Deuel
    Beth Deuel Feb 05, 2009
    thank you very much
  • 48 Answers
I dont know but this is as close as i can find:
http://consolepimps.com/Nintendo_DS/DS_Disassembly.php
Posted on Feb 04, 2009
Asus UL50VT always shows charging
Either your battery or the power cord has an issue. Does the battery ever fully charge and make the charging light disappear or turn green? If not the battery could be bad.
Try running the computer off the battery by removing the power cord. if the battery starts losing charging strength real quick then your battery is bad. I've see bad batteries that say they are 100% charged but as soon as you remove the power cord it gets down to 5% i a matter of minutes.
Try running the computer on just the power cord. If it stays on and lets you operate without any problem then the power cord is good. A good power cord will not charge a bad battery.
If the laptop does not let you stay on long with the power cord, then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of them is bad they will not charge a good battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | Computers & Internet
I always get plugged in not charging when i charge my laptop even when it is not fully charged
If the laptop works fine off the power cord without any problems then your power cord is ok, but if the battery is not charging then the battery is probably dead and needs to be replaced. Batteries only have a useful life, and when it's over they have to be replaced.
If the laptop does not work with the power cord then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop. If either of them is bad the battery will not charge.
Check your DC Power Jack which is where the power cord plugs into the computer. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Computers & Internet
Inspiron 1525: "plugged in, not charging"
Not charging means the battery is not being charged. Batteries only have a useful life of so long, then they die and will not take a charge so you have to replace them.
If the laptop works fine when the power cord is plugged in, then just replace the battery. if the laptop does not work on the power cord, then you need to either replace the power cord or look to see if the DC Jack where the power cord plugs into the laptop is broken or wiggles. When the DC Jack it bad the battery will not charge and eventually the laptop will not turn on if the power cord can't make the connection correctly.
May 22, 2012 | Dell Inspiron 1525 Notebook
Laptop crashes and wont keep charged battery
Crashes when? What are you doing when it crashes? When it crashes does it boot right back up or do you have to wait a while then it will boot back up?
The laptop might be running hot or has a virus, but you'll need to answer the questions above to really isolate what is going on.
As for the battery not charging, either the Power Cord is bad or the battery is bad. If the power cord is good, it would normally charge the battery unless the battery is dead. Batteries only have a useful life and last for so long, then they have to be replaced.
Maybe your DC Power Jack where the Power Cord plugs into the laptop is bad. That would cause the laptop to crash (shut down) and it would also keep the battery from charging.
May 18, 2012 | Computers & Internet
My new laptop battery is not charging
Maybe the battery is bad. Just because it's new does not mean it will work.
Does your laptop power on and work with the AC Adapter and Power Cord? If not, that is why your battery is not charging. You need a New AC Adapter & Power Cord or the DC Jack where the Power Cord plugs into the laptop is bad or broken.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
May 15, 2012 | HP Compaq nx7300 Notebook
Bought a new power cord because I had to keep moving cord around to get battery to charge, move and would lose charge received new power cord and still have to move cord around to keep getting a charge...
First thing you need to do is STOP trying to wiggle the cord to make it work. You could damage the motherboard.
The power jack needs to be replaced. It's a pretty standard repair. You can try finding a local laptop tech from Craigslist or visit your local shop.
This type of repair usually runs 70-100 out the door (depending on where you live)
I don't recommend you trying to fix it yourself.
Apr 03, 2010 | Dell Inspiron B130 Notebook
My cord to my adapter got bent. I bought a new
Full breakdown and replacement of the power jack should be no more than $125 - you can find places on eBay for that.
Nov 12, 2009 | Acer Aspire 3680 Laptop
I have a gateway 3250GZ laptop, the DC in jack
http://forums.whatthetech.com/DC_Jack_Laptop_t105164.html
double check your power cord! i just went thru 3 days of troubleshooting my Gateway M6318. Thought it was my dc jack.... after tearing down my laptop... finding the jack in tact, soldering in tact. testing my power cord... off and on for 3 days.. it was reading 19v.. which is what it should... but as of today began zero reading on tester. Tomorrow I will buy a new power cord to see if this was the correct problem... wish i would have found the above reference site before all the other troubleshooting i had done... tearing down my lap top, pulling, tugging, twisting my power cord to get a good charge.... etc. hope this helps!
Jul 12, 2009 | Gateway MX3228 Notebook
Power cord won't stay connected
hi,
the very first thing what u need to check is the condidtion of the power cord of the lpatop which is connecting to the laptop and as u said that it is not connecting properly and u have to push it in..what u can try is that u can try is if someone is having the same laptop try with the another power cord and still if it does the same thing that means u have to replace the motherboard of the laptop and if it doesnt happen then definately u need to change the power cord....
Jan 24, 2009 | HP Compaq nx6110 PC Laptop
Nintendo DS Will Not Charge
Try if the battery is charged right, when batter is fully charged disconnect from AC adapter. Hold the power button for 5 seconds. If it does not work that means that you need a replacement battery for the Nintendo DS. When you receive the replacement batter, follow the steps again.
Sep 11, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
257 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Troy Gorman
Troy Gorman
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
