Question about Nokia N70 Cellular Phone
Auto open of any folder and continuously hang problem
Automaticallly open music files on rcvng d phone softwares problem
  • 35 Answers
D best solution is repormat your mobile using *#7370# then click yes then enter the phone lock code like12345 then yes.... after a few second your mobile phone is succesfully formated .....
Posted on Feb 06, 2009
Start music player hang my mobile
Hi first reduce the memory of mmc and phone.Actually only 512mb is supported in this 6300 model.If you are using mmc of more than 512 mb several problem might caused.So, to get rid from this delete all the unnecessary files whether the files are in the phone memory or mmc.Restart your phone without inserting mmc...and follow this.Download and install Oxygen Software :: Download .open Oxygen Software :: Download interface ,connect your phone via USB and browse C drive,select "Hidden folder" and delete all the "music db".....this is the only way,Otherwise contact mobile repairing shop.Good luck.Thanks for visiting fixya
Jul 13, 2012 | Nokia 6300 Cellular Phone
Music player shows always "no music files found"
I thought that you have not try with Oxycube.Download and install this software.Run oxycube and connect your phone via USB in normal mode by selecting PC Suit when prompt.After connecting the phone browse C of phone and open "Hidden folders" again select "Music dp" and delete it.Remove the USB and restore the phone, now you can enjoy music.good luck.Thanks for visiting fixya
Oct 13, 2011 | Nokia 3110 Cellular Phone
How do you download music into the pantech c740 music player?
Before answering this, keep the following in mind about uploading files to your phone:
MP3 would be my personal choice for the phone you have. Since you are using Windows Media Player (WMP) on your PC, I assume that any music you have ripped with it would be in WMA format, or maybe WAV. WAV is compatible with your phone, but I haven't tried WMA.
Get into the folder the files for the player are stored in (usually My Music), and look at the format by right clicking and selecting properties. If the file format is not compatible with your phone, you can try changing the file extension by opening any folder, selecting tools>folder options>view, and then unclick "hide known file extensions." Then go back to the file and rename it, but only change the file extension. Example: if the file is named "music.wma", the you would change it to "music.mp3." This usually works with common audio files.
To answer your main question, the easiest way is to bypass all the media player ****, and go straight to the file folder where you music is stored in your "My Music" folder.
The following will work with a mini SD card too.
First connect your phone to your computer via a USB cable. A folder options box should come up. Choose to open the folder and explore files. It may not say exactly that, but you'll sort it out I'm sure. Find the "audio" folder inside the phone, and open it.
Then in your computer's music files, find the folder containing the music you want to put on your phone (usually "My Music"), right click the music file you want and select "copy". Go back to the folder for your phone or card, and copy the file into it. That's it.
There are many ways to copy the files with this method, but this one is the easiest to explain. You can copy entire folders to your phone, if you have enough memory. Also, ripped CD folders often contain album art, so I recommend selecting the files you want to copy, rather than the whole folder. Holding Ctrl while highlighting the files you want to copy will enable you to select multiple files and copy them all at once.
Dec 10, 2009 | Pantech Matrix Cell Phone
What to do when my iphone is hang? plz reply it
Connect your i phone to pc through folder option show hidden files alongwith system files and known file types you will get folder option in tools menu of any open folder. Check for any exe file delete it. If your phone hangs and unable to restart then simply take out the battery of your i phone.
Jun 19, 2009 | Apple iPhone Smartphone
Cant play the music
Add music to I9
Connect your i9 to your PC via the USB cable.
On the phone select "Mass Storage Device".
On the PC you will see 2 new drives appear.
One will be the SD card. The other is the Phones internal memory.
Now just simply copy your MP3 files to the Memory card folder "My Music".
Do not use the phones internal memory as it just is not big enough.
The Audio player will only play music from a folder called "My Music" or "MP3"
depending on which firmware version you have on your i9. If one doesn't work try naming it the other!
Also make sure you are selecting the right storage area in the Audio player options, either the phone
or the memory card, because there can be identical music folders on both, and if you don't choose the
correct storage location, your music files still won't show in the Audio player!
Make sure the audio file is in a format the i9 can play. Known music file types are mp3, wav, amr, m4a, & mp4.
DO NOT place music in sub folders within either of the My Music or MP3 main folders, the Audio player
will not find them unless the music files are directly within the proper My Music or MP3 folders!
Every time you add new music to your i9 you will need to refresh the List in order for the audio
player to see all the newly added songs. To do this open the player. Tap "List" at the bottom of
the screen. Tap "Options". Tap "Refresh list". You can also go into the audio player settings &
turn ON the "List auto gen." option. If the option is ON, then after you add new music, the new
music should be added to the entire list of music already showing. If you have problems with the
music list showing up empty, or new music you have just added not showing up in the current list
of songs, then try turning OFF the List auto gen option and refresh the list manually again by using
the Refresh list option as described earlier. Manually refreshing the music list must be done every
time you add new music files to the phone if the List auto gen option is OFF.
You get to the List auto gen option by two ways with the Audio player open and onscreen
for most i9 firmware (some firmware might not have it, or may be in another area);
1.) Tap the little wrench icon to the far right on the black option panel,
then scroll down to the List auto gen. option!
2.) Tap the List option at the bottom of the screen, tap the Options button
screen, tap the Settings button, scroll down to List auto gen.
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Nokia 3110c music player not working
my nokia 3110c music player updates continuously but does not start
Feb 09, 2009 | Nokia 3110 Cellular Phone
Memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
Nov 13, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Motorola i880
if your computer has flash card readers, you would need to use a micro sd card to be able to use in on your computer. if your computer/laptop does not have a card reader, you would need to buy a data cable for your phone. if you use your pc/laptop's card reader, open your MY COMPUTER folder and it will be drive E. if you use a data cable, your phone should've came with a software cd when you bought it. you have to install your phone's software on your pc/laptop for transferring files using the data cable.
to put songs on the card for your phone to use, you just drag and drop the mp3 file to the MUSIC folder of the card. a lot of people make the mistake of putting it in the AUDIO folder. the phones music player CANNOT read files in the AUDIO folder. it only reads the music files if it's in the MUSIC FOLDER.
Aug 14, 2008 | Motorola Mobility i880 Cellular Phone
Copying musics from pc to my Motorola L6 Cellular Phone
convert all music to .mp3 then connect your usb cable and open the MObile phone tools software and open the music file folder and just drag or copy and paste the music file.
Jun 02, 2008 | Motorola Mobility L6 Cellular Phone
Nokia N70 Cellular Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
