Question about Kenmore 73262 / 73264 / 73269 Top Freezer Refrigerator
Kenmore Coldspot Model # 78167990
I have a 8 yr old Kenmore Coldspot refrigerator with an icemaker inside top freezer. It stopped processing ice cubes. It doesnt appear to have ice in tubes. Is there a quick fix? If not, is it easy to remove so I dont get complaints from tenants that ice maker doesnt work. Rather not have an icemaker since once a few years ago the tube on back of refrigerator got pinched and causd a flood down to first floor .......thanks
fridgetech
  • 473 Answers
SOURCE: Ice is not ejecting
Sounds like the icemaker thermostat is opening too soon which turns the heater off.  The easiest thing to do is replace the whole ice maker which I have seen pretty cheap on ebay.  If you want you can test these part with an ohm meter.  Check the heater for resistance.  If it is ok then replace the module and thermostat.
Posted on Oct 26, 2007
the dr
  • 447 Answers
SOURCE: Ice maker not making ice.
These Icemakers have plastic gears on the modules that are breaking, also some have thermostats that are malfunctioning. I recommend haveing an experianced tech look at the unit to see if you need the new upgraded indoor ice maker.
Posted on Jan 15, 2008
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
woodchuck789
  • 4059 Answers
SOURCE: Ice maker is working very slowly
This is usually caused by low water pressure from the water supply or a clogged strainer in the water inlet valve where the water supply comes in. OR
look for an adjustment behind the plastic endcover with a +/- on it. + is more water.
Posted on Aug 14, 2009
  • 106 Answers
SOURCE: Kenmore Coldspot #106.9750610. Icemaker does not
restricted water flow or pressure from house water where your taped into. your shut off or Tap a line may be cloged or if you have a water filter its cloged. It could also be a bad water valve in rear of refrig. start at the sourse of water and work back to frig. A rare thing could be that the timing gear on the ice maker is burnt and not trigering valve long enough to fill icemaker
Posted on Oct 30, 2009
Ice maker in kenmore coldspot refrigerator quit making ice, nowater flow
There are several causes of no ice maker operation. First, is the freezer cold enough? It must be below 32F to operate the icemaker. 2nd: Is the bale or metal rod that runs along the side of the ice maker in the down position? 3rd: You may have a failed water solenoid valve, located on the back of the unit. The plastic or copper water line from your house's water supply is attached to this valve.
Apr 11, 2015 | Kenmore Refrigerators
I have a Kenmore 55602400 Coldspot and the icemaker has stopped making ice. What do I need to do to fix it?
The model number you listed is for an air conditioner. Please check inside the refrigerator for the model number?
Oct 15, 2012 | Kenmore Refrigerators
I have a Kenmore Coldspot refrigerator with top freezer. The icemaker is "leaking" if it is the right word into the ice tray bin that it is building a chunk of ice along with the regular ice...
What that sounds like is the water valve isnt fully closing. This tipi wrote is about that issue,
http://www.fixya.com/support/r10343350-icemaker_drips_causing_all_ice_freeze
Reply with your exact model number as found on a label usually on the ceiling of the refrig. compartment and i will give you the part number for that water valve.
GENE
Sep 05, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore 52552100 refrigerator not working
Hello.... do you still have the parts??
I can use Part 921526 PC Board kit, emitter & reciever icemaker - $30.
You can email me at durangoboy@xemaps.com
Thanks,
Paul
Oct 09, 2009 | Refrigerators
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Model 78182891 Coldspot with excessive water Collecting in Refrig
Most likely whats happening is you have a frozen drain for the defrost cycle. here are step by step instrutions for repair:
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Post bak if you have any questions and I'll gladly help you out Thanks Peyton
Mar 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
hi LOP7,
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kemore coldspot no ice?
no you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Mar 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 73262 / 73264 / 73269 Top Freezer Refrigerator Logo
78 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
