Question about Boston Acoustics BA790 Computer Speakers
Looking for connection instructions to PC and subwoofer
System appears to be connected but the power light does not come on for the speakers. Wondering if all components are connected properly.
  • 258 Answers
Ou can download a manual under product detail on this page.
http://www.amazon.com/Boston-Acoustics-BA790-Multimedia-Computer/dp/B00005AR7N
Check power supply is plugged in correctly and switched on at the socket, then turn or push the button usually on the right speaker to turn it on,
good luck HPC
Posted on Feb 04, 2009
IWave. Why don't they work?
Make sure the power is on by looking for a LED light on the front of the speakers. If still nothing, make sure all connectors are plugged in to their respective connections (subwoofer, PC/sound card speaker input)
Apr 16, 2016 | Audio Players & Recorders
I plugged in my Altec AP3 Speakers to my computer running windows 7. It does not play. i get sound directly from my PC (it had sound prior to plugging in speakers) however the Altec speakers have no sound
Hello
You haven't specified from which computer source you connects this device with. If it is from the audio out socket of the PC, your PC's audio card [or onboard audio] dirive hasn't been installed yet. Unlike WinXP, Win-7 haven't all driver software in its driver cab when it is installed. If onboard sound should energize, the mother board CD should be loaded. There is audio and video drive [normally NVIDIA] drive should be installed. Anyway, you have to install the dirve. Now it disabled. Go to the hardware confujuration of your system, and look whether onboard audio is disabled. If it is disabled, inable it. If there is no driver installed to it, the system will ask CD. Then insert the CD into the CD tray, and follow the instructions. If your Win-7 is registered, you can get diretly into Microsoft site, and can download the driver needed. OK.
Jun 03, 2011 | Altec Lansing ATP 3W Computer Speakers
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
Dear Sir, I hav dell vostro 1015 laptop with windows Xp Operating system. I have purchased 4.1 subwoofer system. When i am connecting subwoofer to pc audio output & all 4 speakers to back of...
Recheck your wiring and instructions. If your woofer is self powered perhaps the amp is no good. Actually it better have amps since the laptop output will not power those speakers.
Mar 31, 2017 | Computers & Internet
How do i connect my 5.1 speakers to my desktop computer
Know Your Speaker SystemGenerally in systems all the cables from the speakers are connected to the subwoofer which comes with a set of wires to connect, that includes : a power cord to connect the system to the AC outlet, a power connector to feed the subwoofer and the subwoofer wires. Your system should come with at least three set of cables for connecting your speaker system to your PC. These cables are usually colored to help with the installation.imageview-thumb.jpg
Start ConnectingYou should connect the cables matching the colors on the jacks located on the subwoofer. After connecting all these cable, its time to connect the rest of the cables like power, subwoofer and speakers. This is very easy if you pay attention to the subwoofer connection then you’d be able to follow the polarity that is written on the connectors. In the end, all your cables would be connected perfectly.
The above pic shows you all the ports to connect the wires to with all the color coded mannerism.
Knowing Your ComputerAll computers have atleast three connectors
  • Line-In.
  • Line-out.
  • Mic.
Computers with six channel audio systems have two more connectors, i.e
  • rear out.
  • center/subwoofer out.
You’ll need to make sure if you have these extra connecters by checking the back side of your computer.
If your computer doesn’t have these two extra outputs: rear out and center/subwoofer out, it’s a disadvantage, you’d be able to connect your 5.1 anyway but you would require to use the line in and mic-in plugs as an alternative. Of course there is a really big disadvantage in using this configuration: you cannot use your microphone or line in inputs and your 5.1 speaker system at the same time. This is the reason that you should buy a motherboard with 5.1 system built in.
Configuration Of Computers With 5.1 Supporting Motherboards
  • Front cable: To Line out.
  • Rear cable: To the Rear-Out
  • Center/Subwoofer cable : To Center/Subwoofer Out.
Configuration Of Computers Without 5.1 Supporting Motherboards
  • Front cable: To Line-out.
  • Rear cable: To Line in.
  • Center/Subwoofer cable: To Mic-in.
Software ConfigurationAfter every single connection has been made, its time to setup audio configuration in operating system. Since we had Realtec drivers on our PC, Double clicking it opened up Speaker Configuration tab. In various options you should select 6 channel mode for 5.1 speaker output and check Only surround-kit if your PC has the separated rear and center/subwoofer outputs and leave it if you don’t.
Now everything is done, you are completely ready to enjoy surround sound experience and don’t forget to leave comments if you find this post useful.
Apr 14, 2010 | Computers & Internet
Hi, our family is attempting to hook up and install a frisby 5.1 digital surround sound home theater system to our spectroniq pltv3250 32 lcd tv without success. As instructed, we are using all the correct...
Pl check all speaker connection is ok after that take AV out of your LCD Tv & connect with your home theater system for audio input in your home theater system
Jan 21, 2010 | Spectroniq PLTV3250 32 in. LCD TV
Power Light, Pulsating Level Control, Blows Fuses
you may of caused a short in the connections or it got moisture why in storge if so the hole subwoofer is screwed
Jun 07, 2009 | Infinity BASSLINK Car Subwoofer
I've just bought a desktop from Cube (the Polaris ST12) which comes with Creative Inspire T6100 5.1 speaker system. The connection instructions which come with the speakers show 3 cables from the subwoofer...
The blue is for a audio in and pink is the mic. Green is the audio out.
You will need to buy a new video card that has all 4-5 colors (green,,black,orange,blue,pink,white)
That way you can plug in all your connections and it'll work correctly.
Oct 23, 2008 | Computers & Internet
Missing lead
typically i would say connect it in parallel to the right or left channel..assuming your system dosent have a sub woofer output and your subwoofer is powered
Mar 05, 2008 | JVC TH-S3 System
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Boston Acoustics BA790 Computer Speakers Logo
237 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
