Question about GE WBSE2090A Top Load Washer
GE top load Washer won't stop filling or spinning
My GE Washer model No. WBSE2090A2WW is overfilling - it would have flooded my basement if I hadn't manually switched it to make it drain - at which time the second problem occurred, which is that it just kept spinning and spinning. What could be causing these two problems together? I've ruled out the fill valve for the filling problem by unplugging the washer while it was filling, and the water stopped coming in. Please help if you can. (Could the timer be the problem or something else?) Thanks.
  • GE Master
  • 3,361 Answers
Remove the plastic hose from the water level switch and blow through it until it flows freely.
If it does not clear this way. Remove the front panel.putty knife needed.
Remove the water level tube from the tub and clean out the gunk.
Reconnect it to the water level switch.
Set the machine to spin and run it.
Reset water level control and try your machine.
Posted on Feb 21, 2009
Will not spin or agitate
did the washer cause the flood? you could have got water into the motor if it was above a few inches deep. do you hear the motor working, and no agitator movement? will it fill ? or is it just dead?
Nov 10, 2013 | GE Profile WPRE6100G Top Load Washer
Ge load size selector broken
You can buy this part, suggest you go online and purchase it. Contact this website: Appliance Parts Accessories Repair Help
May 19, 2017 | GE Profile WPRE6100G Top Load Washer
When loading the machine the water will not stop and overfills flooding the basement
2 causes for this problem. 1)your valve is contaminated and stuck open. To check this, turn power off and see if iwater still flows in. 2)check pressure switch pipe is not blocked or damaged in any way.
Sep 16, 2009 | GE WBSR3140DW Top Load Washer
Water will not stop filling wash basket, even when off
Your water fill (mixer) valve is failed in the open position.
CLICK HERE for the part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 20, 2009 | GE WBSE2090A Top Load Washer
Washer just started on fill cycle to start and continued filling
you have a hose that came loose to the pressure switch or the tub or you have a bad pressure switch
or the fill cup is blocked
Apr 22, 2009 | GE WJSR2070B Top Load Washer
Wo'nt stop filling with water and overflows.
If it fills with water while the machine is off replace the water inlet valve.
It is only overfills while machine is on, check the water level switch and the plastic tube going to the water level switch. The tube may be pinched or have a hole it it.
Apr 05, 2009 | Kenmore 23822 Top Load Washer
GE-WBSE2090A2WW
your main control board is bad ( Electronic Timer) if you need one let me know I can sell you one at whole sale but i would need model number to get the right 1
May 22, 2008 | GE WBSE2090A Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
GE Washer overfilled, now won't spin
Could possibly be that the water level switch in the console has gone bad.  Sometimes the small hose that connects the basket and the switch can come off, causing the overfill.  Sounds like maybe the water switch has gone bad though if I were to guess at it.  If it goes bad, it will send the timer a signal that its full, when its not.  Could also be a bad timer, but that only happens on rare occasions, but it does happen.  Let me know how it goes or if you need break down instructions, etc.  Jim
Oct 16, 2007 | GE WJSR4160D Top Load Washer
GE Model WBSE2090A2WW - shut off intermittenly
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE WBSE2090A Top Load Washer Logo
355 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
