My machine is now about 9 years old and has only been used infrequently. Recently the pump seems to be faulty as will initially start to pump water through the coffee with usual noise but then stop and hum after about 15 secs with no further water being passed. Is it a pump problem or a build up of pressure due to blockage of the sieve?
-   Just realised that the pump can't be 'blown' because I do still get some output (however slow). Have gone at the sieve with a pin and cleaned all round, and taken apart - same slow dripping - so maybe it's a blockage more at the water end..
-   siminaus
Feb 21, 2009
-   My problem is very similar I think. Had the machine for about the same amount of time - infrequent use. Makes the normal buzz sound, then calms down to a hum after a second or two. I'm making a coffee now and have comfortably been able to write this in the time it's putting out a normal shot's worth.
Presume the pump's blown it! The forthing's also lost a bit of 'oomph' :(
Actually solved this myself today. It actually was a buildup of scale as I tried a standard descaling sachet, followed the instructions and once enough scale had come out it burst back into life!!!
If you get 'any' flow at all the pump's fine so it just needs a really good cleanout - even if (like me) you think your local water doesn't tend to scale up your kettle.
I had a similar problem with my machine but discovered it was due to a build up of scale in the internal pipes which couldn't be shifted by normal de-scaling - solution was to dismantle and clean plastic pipes manually.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dualit Espresso 889 Espresso &
I have a Dualit coffee machine model 889 that is about 6 years old. No steam is coming out of the...
(More)
I have a Dualit coffee machine model 889 that is about 6 years old. No steam is coming out of the milk frother instead it bellows out of the main coffee outlet. I have cleaned the frother and it seems clear have you got any solutions. Thanks
Please help, my machine steamer seemed 'blocked' but otherwise worked fine. I descaled it and ever...
(More)
Please help, my machine steamer seemed 'blocked' but otherwise worked fine. I descaled it and ever since the reservoir leaks when the machine is switched on. When the reservoir is full and machine switched off there is no leak. It must be to do with the way the water flows from reservoir to machine when machine in use. thanks,
