Question about Stoves Kitchen Ranges
Gas range, can't remove bottom oven panel - frigidaire FGFB55ASD
I have a frigidaire crown gas range FGFB55ASD. I'm pretty sure I have a problem with the igniter for the lower burner. However, I cannot get the oven bottom panel out! All it has are two screws in the back, easily removed. You can then tilt the oven bottom up from the back, but the front edge will not disengage from whatever it is hooked on. No matter how I push, pull, pry or yank (note I started with gentle pushing and pulling and progressed to yank as I got more frustrated...lol) at whatever angle, no dice.
Is there some trick to this I'm missing?
  • 135 Answers
It pulls out toward the back or the oven. I usually lift it up as high as I can before yanking on it. If it is stuck, try sliding 2 small screwdrivers in the screw holes for more yanking leverage. As a lats resort, pry it out from the front; you may damage the finish this way. Hope this helps!
Posted on Feb 05, 2009
Is replacing an electronic oven control on a Frigidaire ES330 this easy?
Yup...It's that easy. You can get the parts from a local appliance parts store or from any of the many sources online... Sit down when you ask how much the panel costs.
Nov 20, 2014 | Frigidaire Kitchen Ranges
Gas oven not getting hot - glow bar works but no gas to burner
This happens when an oven igniter (glow bar) is bad. The igniter must draw enough amps to turn on the gas to ignite the flame. If you have a square shaped igniter use this part#5303935066 If your have a round shaped igniter use part#wb2x9154. These igniter will pretty much work universally for most gas ranges or ovens.
  1. Remove the racks
  2. Unplug unit
  3. Take out the screw holding the bottom pan
  4. Remove screws holding manifold where igniter is attached
  5. Remove manifold cut wires about 2in link from igniter and clean leads.
  6. Unscrew and remove igniter
  7. Replace Igniter with new one and fasten onto manifold
  8. Clean wires and screw on ceramic nuts to wires
  9. Tuck wires back and Reinstall all components
Test your new igniter. You might notice it taking a little longer to light up but that is okay.
Please let me know if this was helpful by rating me a 4.
Thanks so much have a great weekend.
Dec 12, 2010 | Frigidaire Gallery 30" Self-Cleaning...
Burners abruptly stooped working on top of the stove
check electrical panel of your house and make sure both breakers are in the on possition ..
Jan 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
My frigidaire ES400 gas range is giving off a sooty smell and high levels of CO that fluctuate from 23ppm - 118ppm (FD CO METER). what is the possible cause and how can it be repaired?
Air intake needs adjustment. Remove bottom drawer, there is a gas valve and the burner attached to it. Loosen small screw on the burner and turn the air baffle to let more/less air in. If not sure what you're doing - call a repairman.
Also make sure not to cover any vents on the oven bottom with foil, as some usually do.
It also can be that the burner holes need cleaning
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I need to change my oven ignitor and I need a diagram to show where it is located. I have a Frigidaire model FGF353BADB. Free standing gas stove/oven.
Here's a diagram of the oven along with the Oven Ignitor (Part #19 on the diagram) and the Broiler Ignitor, (Part #26 on the diagram). They are located behind the gas deflectors located at the top and bottom inside the oven compartment, accessible from inside the oven, but you'll need to remove the rear panel at the outside back of the stove to disconnect the terminals tha supply voltage to the ignitors.
Be sure to turn the breaker off and/or unplug the range from the 220V-AC outlet first.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FGF353BADB&productCategoryId=0124002&brandId=1428&modelName=FRIGIDAIRE-GAS-RANGE---5995274411&diagramPageId=00003&componentDescription=BURNER&documentId=Y2702738&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you complete your repair. Best Regards!
Jul 31, 2009 | Frigidaire FGB24S5A Gas Single Oven
Compact 30 Frigidaire Model rbe539n range/oven. I am looking for the switch to turn on oven light.
Be sure the timer (right most knob) is set back to MAN (manual) after cleaning in order for the oven to work.
Jan 14, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Hello, I have a Frigidaire freestanding crown series gas range that has two problems. The most important being that the oven does not light. The stovetop lights, except one burner that you hav to light...
I figured it was the ignitor given the burners work fine and I could smell gas from the oven when I would try to turn it on. So I found a local parts store and bought the replacement ignitor. I cut the wires of the old ignitor close to the ceramic and spliced the new one on with porcelain nuts and voila my oven now works again!
Nov 18, 2008 | Frigidaire Kitchen Ranges
Oven not working but burners are...
replace the glowbar just because it glowes doesnt mean its good the one you want to replace is the bottom one take the racks out and remove the bottom panel there are two screws remove the then under that will be a flame spreader remove that under that will be the burner bar and ignighter
May 22, 2008 | Frigidaire TGF317 Gas Kitchen Range
Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Dec 13, 2007 | Frigidaire FES367 Electric Kitchen Range
Kitchen Ranges Logo
707 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
