Question about Kenmore Ovens
Kenmore wall mount oven 30129/30221/30229 wont stay ignited
This is the second time the problem has occurred. I replaced teh control unit partWB27K5201R and it worked once for 10 munites. now it won't stay ignited, if at all.
the dr
  • 447 Answers
SOURCE: Jenn-Air w156 Single Wall Oven Problem
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Posted on Sep 28, 2007
textonor
  • 130 Answers
SOURCE: Kemore Gas oven - trouble igniting
Depending on the age of the oven, it is possible that your ignitor is now weak and it is taking longer to ignite.
Posted on Feb 03, 2008
SOURCE: Cleaning cycle stuck whirlpool rbd245pdb1
whirlpool self-cleaning electric built-in oven #RC8400XAB serial # XD1301008. Self-cleaning lever locked. How can I release it???????
Posted on Jun 20, 2008
  • 1214 Answers
SOURCE: Kenmore propane range/oven tripping GFI
My bad, yours is an oven.
I found the Owner Manual, but could not find the Installation Manual. Do you have it, and does it say to hook the oven to a GFI protected power source?
Just because of the way the electronics work in the oven, and the way the electronics work in the GFI, I don't think that they work together. The oven is a permanent appliance, so I don't know of any reason it would need it.
How long have you had this oven installed, and connected to the GFI? Has anything changed, like you washed the oven down and got water inside it. Is a non GFI circuit available nearby where you could wire the oven?
Let me know what you find. It's been awhile since I looked at a new Electrical Code (NEC) book, and even with that, you local ordinances can over ride the NEC.
Posted on Jan 30, 2009
  • 14 Answers
SOURCE: Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Posted on Feb 14, 2009
Kenmore wall oven 3052
most likely the igniter is not working at 100% and the gas valve won't open unless it is at 100%. Replace the igniter first.
Aug 12, 2014 | Kenmore 24" Manual Clean Wall Oven 3052
Kenmore digital oven model 79095321303 temperature is wrong. Digital display on oven says 350 degrees but oven thermometer placed in center of oven (middle rack) shows 200 degrees. When I up the...
It could be one of two things either the control board or the temperature probe and I suspect the probe and that is a do it yourself job.
The oven temperature sensor on your Kenmore range is a one-piece unit that mounts to the rear oven wall with a mounting plate. The sensor is not difficult to change. You will need to dismantle the rear panel from the oven to access the mounting plate. Most appliance repair shops will have replacement sensors. It is a good idea to take the old sensor with you along with the model number of your oven. This way you will be sure to get the correct replacement sensor for your oven.
  • Unplug the Kenmore oven power cord from the wall outlet. Move the oven range away from the wall so that you can access the back of the unit. (Ask a friend to assist you to move the oven. if necessary.) The oven may use an anti-tip bracket on one of the rear legs. Push the oven toward the back wall to release the leg from the bracket in the floor. Tilt the back of the oven toward you, and pull the oven forward.
  • Remove the screws that secure the back panel to the oven with a Phillips-head screwdriver. Pull the back panel away from the unit and set the panel out of the work area.
  • 3
    Locate the mounting plate for the oven temperature sensor on the upper right side of the back of the oven. There will be a single wire coming from the back of the mounting plate and the wire mounts to a clip.
  • 4
    Follow the wire to the connector on the other end. Pull the connector on the wire to disconnect the wire from the wiring harness.
  • 5
    Remove the two screws that secure the mounting plate to the rear of the oven with a Phillips-head screwdriver. Pull the temperature sensor straight out of the oven. Unclip the sensor wire from the mounting clip.
  • 6
    Take the oven temperature sensor to an appliance repair facility to purchase a replacement. Insert the sensor end of the temperature sensor through the hole in the back of the oven. Slide the sensor all the way until the sensor mounting plate is flush against the oven. Secure the sensor with the two mounting screws.
  • 7
    Connect the sensor wire to the connector by pushing the connector until it locks in place. Snap the wire inside the retaining clip.
  • 8
    Place the back panel back over the rear of the oven and secure the panel with the retaining screws. Slide the Kenmore oven back into its working position and plug the power cord into the wall outlet.
  • Oct 09, 2011 | Ovens
    30 " Convection wall oven
    F2 During BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
    If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
    Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2 During CLEAN C ontrol senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
    If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
    Nov 26, 2010 | GE 27" Built-In Double Electric Convection...
    I have a Kenmore Wall electric oven unit that the heat element at the top is working only and F2 is what comes up and continues to beep. The heat is extreme. WE are wondering if we should just get a new...
    F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
    Select the 'cancel' function and wait 60 seconds.
    If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Jul 19, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
    I was using self clean and now the oven is beeping and displaying F2 and I cannot stop it from beeping.
    HI. This error code will occur when the control board senses an oven temperature above 915F-935F
    Once this type of temperatures occur, this will generally weld the relay contacts on the main board. This will damage the board, and it will require you to have it replaced, asap. If these temperatures never reached the sated thresholds, i would advise to Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace the sensor if found to be defective. Check door lock switches for damage, as well.
    In most cases, this will be a failed control board. To confirm, simply preform a resistance test on the sensor. The normal ohm readings should be 1100 ohms at room temperature. if the sensor registers the correct ohms at room temperature, the control will be the culprit.
    The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
    Dec 29, 2009 | GE Profile JTP18 Electric Single Oven
    Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
    oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
    Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
    Touch pad does not work and flashed FO
    FO- the touch pad is faulty. replace the eoc(electronic oven control)
    May 17, 2009 | Kenmore Ovens
    Double Oven says "F0" and beeps continuously
    The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
    Determine if the problem is with the key panel or the oven control board by:
    1. Pushing Clear/Off pad.
    2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
    If the code recurs, problem is in the control. Replace control.
    If the code does not recur the problem is the Key panel and it would need replaced.
    This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
    I recommend calling a service technician to diagnose and repair your oven.
    Jun 13, 2008 | Kenmore 47732 / 47734 / 47739 Electric...
    Beeping sound and f8 displayed
    F8 means to replace the elctronice range control board. Evidently the power failure caused damage to the board.
    May 24, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Kenmore 911.30464, 30465, 30469.....Wont ignite at all
    there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
    Jan 15, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
    Ovens Logo
    179 people viewed this question
    Top Kenmore Ovens Experts
    Dan Webster
    Dan Webster
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
