Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
PC Grounding Problem
I have a very frustrating situation. Which is, I have been unable to resolve a grounding problem which results in a low-pitch humm when I connect my pc to my stereo system using an audio cable. It does NOT occur when I connect my iPod to the stereo using the same cable. There is no humm when I normally play audio on my pc. I have an HP Pavilion (Media edition) and a Pioneer stereo. I connect to the “CD” bank on the stereo since that is (presumably) “digital”. I have sent the signal from the PC to a radio via a wireless FM transmitter and then connected it to the stereo and there is no humm. Therefore, I believe it’s a ground fault from the “hard-wire” connection. I have done the following:
  • Swapped out sound cards
  • Connected a grounding wire from the pc tower to the stereo
  • Connected a grounding wire from the pc to the AC outlet
  • Connected both the pc and stereo to the same AC outlet
I am at my wits end. How do I diagnose/solve this issue.
  • 9 more comments
  • noknees438 Feb 04, 2009
    The audio cable is solid and is not loose
    headphones are fine-no hum
    I've used line out (back panel) and headphone jack (front panel)- no diff- still hums
    Have tried PC vol at all levels- only chnages the volume of the hum
  • noknees438 Feb 05, 2009
    I have an LCD monitor and yes the cable rises up through a drop ceiling near fluorescent lights but I already thought of that issue.  I dropped the cable to the floor away from the lights and still got the hum anyway.
  • Chris May 11, 2010
    Bear with me... I'm grasping a little here...
    Do you have a CRT or LCD monitor? When you hook it to the stereo, does the cable pass by any other electronic devices? (especially fluorescent lights, electric motors)
    When you plug the audio cable into the computer, is it going all of the way in? If you slowly pull it out slightly, does it go away?
    Is it loose in any way?
    If you plug in a set of headphones to the audio output on the computer, do you get the hum?
    Are you using the "speaker out" or the "line out" jack?
    Do you have the computer's volume all the way up?
  • 70 Answers
This ground loop isolator from Radio Shack was suggested when I did a search:
http://www.radioshack.com/product/index.jsp?productId=2062214
It says it has the 1/8 jack adapter, so it should plug right in!
I'd be curious to hear about the results if you try it.
Good Luck!
Posted on Feb 05, 2009
How to solve the issue when fautly grounding point casuing ADSL ports failed of ADLE board.
1- Service boards found normal, only the ADSL ports are appearing as Failed and found on almost all ADLE boards of the Huawei MA5616.2- Control Board found normal and there is no communication lost alarm between control board and service board.3- There are chances of some exceptional surge from outside coming through MDF towards system causing Huawei ADSL ports failure. Initially we reset the chipset of board to restore the services and move to step 4.4- We check the grounding point of system and MDF, it was not working and test result is as mentioned in snapshoot. The device was installed in switch room, we check the grounding values of MDF and switch room it was not according to standard and resistance values were too high. We also check the grounding point of other room (Transmission Room) in same building where SDH system was installed, its value was 1.31 ohm which is normal.On investigating we found that the grounding supply of MDF and switch room is different from transmission room and grounding supply of MDF and switch room was actually not working. We connect the grounding cable of MDF and switch room to transmission room's grouding plate and issue resolved after that.
Root Cause
1- Service Board faulty.2- Control Board faulty.3- Exceptional surge from outside lines.4- Grounding / Earthing point faulty.
Suggestions
For such kind of issues specially for Huawei Access Network, must check the grounding of the equipment and MDF. The equipment and MDF should be properly grounded and tested regularly the resistance value of grounding must be in the range around 1 to 5 Ohm.
Mar 22, 2017 | The Computers & Internet
Cricut explore one. Downloaded program,but get error message,wont install
Frustrated!!! [Driver installation problems][Resolved] - Make The ...
forum.make-the-cut.com/.../frustrated-driver-installation-problems-resol...
May 11, 2010 - 29 posts - ‎10 authors
I cannot get the Cricut firmaware to update. ... I just got a new computer with Windows 7, I tried to cut with the cricut but I get two error messages. RESOLVED Problem getting computer to recognize Cricut
Dec 15, 2010
RESOLVED!!!Help Sending Cuts to Cricut
Jul 24, 2010
Cricut Error: Unable to load drivers
Jan 28, 2010
cannot get program to cut
Jan 14, 2010
More results from forum.make-the-cut.com
Dec 28, 2015 | Computers & Internet
Chevy 3)4 ton vortex truck 199 has no power going to the starter amps are low, the starter will not. Engage electrical problem even when I jump it, voltage low, what is it
The first check is for proper grounding...If you have a multi-meter digital or with an analog meter, set it on the lowest scale...Place one lead on the clean top of the negative battery post and the other on bare metal of the chassis (fender bolt is proper)...meter must read less than 50 ohms...Continue holding lead on battery - post...Place the other on clean metal of engine...Same results; less than 50 ohms...If reading is high (1500 ohms;example) The vehicle needs 2 ground straps, one between - battery post and clean metal of chassis the other from chassis too engine...Without knowing if grounding is OK truck will have symptoms as you described...saailer
Jun 18, 2015 | Chevrolet Cars & Trucks
Pitch bend issues
Hi, try to find how to reset it or go to default mode,find out in the users manual.Hope it will solve your problem,
Oct 17, 2017 | Akai Ewi4000s Electronic Wind Instrument
My amplifier is cutting out 30secs after I turn on the power why?
depending on the model number...sony had a bad run of amps that would exhibit the problem you are having...the fix was that it had a grounding issue with the various circuits within...there is a method we used to repair these sets where we would "bond" all of the grounding connections on the pc board with lengths of wire to one main grounding point...another possibility is that there are cold solder connections that are causing the unit to shut down. A cold solder connection may have conductivity when the unit is off, but when the unit heats up then the connection is lost resulting in shut down....I would recommend taking the set to your nearest service shop and get an estimate
Feb 24, 2011 | Sony Audio Players & Recorders
Passinger side tail light and tag light don't work. I replaced both bulbs and checked all fuses.
For easy testing, purchase a low voltage test light. It resembles a screwdriver with a wire pigtail. Clip the aligator clip on the pigtail to a grounding point on the car and use the probe to test for power in your light sockets. If there's power, your problem could be loss of grounding. You need both a power wire and a grounding wire to complete the ciruit. Look for a damaged or severed grounding wire.
Nov 18, 2009 | 2004 GMC Sierra
Technika FM In-Car Transmitter loud low frequency hum
This humming noise is the cause of a bad ground. try a new grounding location. The shorter the ground wire the better. Make sure the connection is metal to metal. I have had the same problem out of competition systems. Good Luck
Jul 20, 2008 | Car Audio & Video
Avic n2 help
That is just a ground problem....u can buy a noise isulator from the store for prob 20
Mar 29, 2008 | Pioneer AVIC-N1 Car DVD Player
Sound Interference coming throught the Amplifier
On many occasions high pitch interference is a result of bad wiring and grounding problems. Check to make sure that you followed the manufacturer's instructions concerning grounding and installation of the amp, and if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local Yamaha dealer. If you're out of warranty I suggest locating a professional repair person.
Jan 17, 2006 | Yamaha DVX-S120 System
Computers & Internet Logo
115 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
