Question about Toshiba TLP 260 Multimedia Projector
Toshiba with Colour fail , red colour
Someone who can help? to reset colour on this projektor ? the red colour is too bright , have try to reset in menu , but no luck . is there an key combination. how to reset factory settings ?? on this Projektor
Toshiba TLP 260
  • 21 Answers
The filter lense of color red had discolored
Posted on Feb 18, 2010
What are perfect settings for colour on my Toshiba 22KV500B?
It will depend upon individual viewing taste. Yet, contrast 65%; Brightness 50 to 60% and color 30 to 45% will give a satisfactory picture. https://electronicshelponline.blogspot.com/
Jun 30, 2016 | Toshiba Televison & Video
How can I get my printer to print in color rather than brown? more info
Hi Harold
I have a feeling that this is a problem that you will only be able to resolve by changing the colour cartridge for a new one and then doing multiple head cleaning operations.
It sounds as if the three tanks in the colour cartridge have become severely contaminated with ink from the others, thus giving this overall brown colour on the page, whichever colour the computer tells the printer to print.
To check this you may be able to use something like a Word document and using the font properties, change the colour of the font on the screen for a number of different lines (eg one line - bright yellow, another - bright red, a third - bright blue, a fourth - black) print this out and see what colours you get.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 21, 2014 | Canon MP280 All-In-One InkJet Printer
Red blinking light after colour wheel replacement on 62hm85 toshiba
You really need to look to see if the color wheel cables are connected or not.
Dec 15, 2012 | Toshiba Televison & Video
The bulb blew and I replaced it. Now the colour is all messed up. There isn't enough red, and way too much yellow/green. I do not have the original remote for the TV. How do I reset the colour??
the problem is that you bought a Toshiba. i have a customer who we di the same thing with. spent hundreds on a bulb and toshiba had a little surprise for us. messed colors. Tried resets etc with no luck. i've been told that is is the nice expencive colour wheel or coloor board also costing a lot. The word on the street is that this is very common and people say that thier customer care doesn't care. I think that when the bulb blows it can sometimes spike the color wheel or color board vibrates the color wheel when it blows.Perhaps all of these angry customers could dynabolt their tvs to the toshiba staffs carpark, go the the higher people in the toshiba food chain
Jan 03, 2011 | Toshiba 56HMX195 52" HDTV DLP Projection...
Red colour appearing on screen
Your tv could have one of several faults. None of which are to be tackled by anyone except a qualified engineer due to the electric shock hazard.the first problem could be the crt (tube) the second could be the componets on crt base circuit board ie resistors or ic.
With a tv 9 years old it may not be economical to carry out a reair.
Jun 01, 2010 | Thomson 21DC320 21" TV
Acer projector
A DMD has no inherent colour capability - it's just a configurable mirror array. If you want to do full-colour projection, then, you'd expect that you'd have to use three DMDs and three coloured filters - red, green and blue.
But if a single DMD's switched in synchrony with a rotating "colour wheel" - a spinning tri-colour filter that lets through red, green and blue light in turn - then the very rapid switching speed of the DMD lets it lay down red, green and blue images in such fast succession that the result is a perfect colour image.
You can do the same trick with a single LCD panel, but it's not a good idea; LCDs are transmissive, rather than reflective, devices, and block something like half of the light that tries to get through them. To maximise brightness in LCD projectors, a three-panel design works better. If you try to pump the entire output of a super-bright lamp through one LCD, keeping it cool becomes rather challenging.
The extreme smallness of the moving parts on a DMD mean that it behaves like a solid state device, not a mechanical one. For all their complexity, DMDs have very high Mean Time Between Failures (MTBF), and well-made projectors based on DMDs can be expected to last easily as long as LCD units, and probably longer. If a DLP projector fails, it's not at all likely to be because there's something wrong with the DMD.
Sep 06, 2008 | Acer PD100 Multimedia Projector
Bright screen with very low contrast
I fixed it myself, it seems that the monitor have some problems remembering it's settings and sometimes it automatically set its settings to crazy values that are out of the range that we are allowed to input. For my case, the setting that was crazy was the gamma setting since it was set so high. I wasn't able to bring it back to a normal setting so I found a way to do it by resetting the monitor. So to reset these display settings such as colour, contrast, brightness and gama, you need to turn on the monitor and unplug the monitor without turning it off and plug it back in again. It will automatically power on and the correct default settings will be present.
This forum isn't very helpful is it?
Dec 09, 2007 | LG Flatron L1811S 18.1" LCD Monitor
Green colour flashes
I have a42hds52a and someone threw something at the screen and broke it. so I am looking for someone who is willing to get rid of thier tv1.gif or looking to buy one for parts.
call Richard At916-308-9272
raystockett@inbox.com
Oct 29, 2007 | Hitachi 42HDT52 42 in. Plasma HDTV
Colour problem
I have default settings I normally use for most sets before I begin any kind of alingment. Contrast: 90% Brightness: 45% Color: 45% Tint: 50% If the brightness is to high or the contrast to low the color is off. Check your connections, there probably OK, but, it never hurts. If the settings don't help call a local authorized servicer in your area. Hope this helps.
Jun 23, 2007 | LG 42PX3DCV 42 in. Plasma EDTV
Toshiba TLP 260 Multimedia Projector Logo
468 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
