Question about Reddy Heater-30-55,000 BTU Variable
Runs for about 15 minutes then shuts off .
Unplug and plug back in will run 15 more minutes.what are the adjustment settings? i tried to adjust. may have them wrong. unit is a155000 btu
  • 35 Answers
I believe the pump setting is 6.0 for the 155 BTU model. I will know more after tonight, we are using a Reddy Heater 155 unit tonight at church. I will look on the side panel and see what the PSI should be for the pump pressure and respond either tonight or tomorrow.
Posted on Feb 04, 2009
My Visio vp50 hdtv20 will shut down after about 10 minutes then after about 10 minute you can power it back up
Do a reset to this TV, and then check. Check whether the timer function is set to On, and it is set to 10 minutes. If it is ON, set it OFF. Refer its user manual for details.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Mar 05, 2017 | Televison & Video
What is default fuel screw setting turn outside of pulsar model 2014
If it's running well, I'd put in fresh plugs and then try to "tune" it.
With the engine running at low to mid RPM lean it out until the revs increase, and then drop. Back off on the adjust until the RPM peak, then another 1/3 turn. Run for 5 to 10 minutes. Let lool, check spark plug for desired colour.
May 28, 2015 | Bajaj Pulsar 150 Motorcycles
Reset after power outage
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 18, 2014 | Televison & Video
Lt1050 black smoke after 15 minutes
The black smoke and black spark plugs indicate that the engine is running very rich (ie too much fuel). This could be caused by the choke not opening fully after the engine starts and the fuel mixture is too rich OR the fuel mixture setting is opened too far.
Check the choke lever, make sure the choke is fully open when the choke is in the running position.
When the engine is running with the throttle is in the 3/4 rev position then adjust the fuel mixture to get the highest RPM.
Apr 19, 2012 | Cub Cadet Garden
The green light is on the power plug but i get no power on the machine, no lights no air nothing
Press the reset button on the power plug and wait 3 minutes before restarting the unit.If that fails to work. Turn the ON/OFF Switch on the unit to OFF & unplug the unit for 15 minutes. Then plug the unit back in, turn the ON/OFF Switch to ON. During that 15 minute time out, the unit should have reverted back to it's original factory settings. From there you can adjust the settings as you like.
Hope this helped you and thanks for choosing FixYa.
Jul 29, 2011 | Royal Sovereign ARP9009TL Air Conditioner
I cannot get this thing to stay on. The fan runs for about a minute then shuts off. I have tried unplugging it and plugging it back n and I have tried adjusting the percentage on the unit but it will not...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 11, 2011 | GE ADER65LN Dehumidifier
Laptop shuts off after 15 minutes, even when plugged into wall outlet. fan runs quieter than normal
Most likely the system is going into standby or hibernating.
Check the Control Panel for Power Options, And adjust these accordingly.
If it is a Dell system, you may want to check your QuickSet options as well for these will often take precedence over your OS settings.
Let us know
Good Luck
Apr 14, 2009 | Computers & Internet
Gas log will not stay lit for more than 5 minutes
Sounds like the gas regulator has failed.
There will be sufficient gas flow to light the pilot and get a flame prove, then the main burner lights, you will probably see the pilot flame reduce somewhat, and no longer fully surround the flame prove sensor.
When the unit is relighted, the complete sequence starts all over again.
Have the gas regulator checked and adjusted (if adjustable) or replaced by a qualified technician.
Jan 20, 2009 | Heating & Cooling
Rca 27v414t shut off by it self after a feww seconds.
Most likely the TV is detecting an internal problem with it's circuitry and is shutting itself off to prevent further damage. You'll need to have a professional look at your set to determine exacly what's going on. Aside from leaving the power cord unplugged for five minutes, then pluggin back in and trying it again, there's nothing anyone can do from here. It may work, but it's a long shot.
Hope this helps, and please rate my advice, good OR bad.
Feb 04, 2008 | RCA 32V524T TV
Sony KP-57HW40
Have a Tech. replace the focus/screen block if the problem continues you have a bad red CRT.
Sep 21, 2007 | Sony KP-57WS500 57" Rear Projection...
Reddy Heater-30-55,000 BTU Variable Logo
169 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
