U.S. Robotics USR9600 IP Phone Logo
Posted on Feb 04, 2009
No sound when phone disconnected
When I unplug my 9600 phone from my computer my computer has NO sound! I've tried changing all kinds of settings, but nothing brings back the sound except to shut down and restart my computer! How can I get both computer sound AND sound on the phone at the same time, so I don't have to disconnect the phone? I did not have this problem with my XP, but am now with Vista.
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on Feb 07, 2009
Anonymous
Contributor
Level 1:
Answers
33
Questions
0
Helped
17189
Points
84
Hello!
in sound settings (in control panel) you shold find the computers sound card and set that as default soundcard.
And in the settings (preferences) menu in the software you use to perform calls you just specify your computer phone as sound device.
1helpful
Problem getting my bose soundlink to play blue tooth audio from my laptop.
Hi Sirtuan.
Go to the system panel, there choose "sound" . a list with all available sound devices appear. search for your bose soundlink and make it your "standard device".
had the same prob. with my BT headset and this works for me.
if your bose get disconnected the sound should automatically switch to pc speakers.
Regards
Gue.
2answers
" Set Ink Cartridge "
Did you try disconnecting from the power for a few hours to reset the printer? Also, did you try a waste tank reset?
Dead nokia 2700 classic usb connection disconnects automatically ?
1. Please make sure your USB cable is working fine. better to connect your phone using another USB cable.
2. Change the phone's battery, or make sure its more than 80% charged and in good condition.
3. Try to connect with different USB Port on your PC.
Hope your problem will be solved.
thanks
I have a ati radoen 9600 pro 256mb but its shown 16mb sis315 in xp plz help what can i do
It sounds like you are using the onboard graphics card. You will need to restart your computer and going into the BIOS to check the primary graphics device.
  • Make sure it is not set to onboard first, change it to PCI Express.
  • Make sure you disconnect from the onboard VGA socket and connect to the card.
This should resolve your problem.
Logitech Z5500 5.1 speaker system Hi, Any suggestions on how to troubleshoot this problem? there is no sound coming from the subwoofer or the speakers, but when I connect my mp3 player to the pod...
Try pulling the power from the unit for a few minutes, the reconnect. Make sure you've got the surround settings correct. If that doesn't do it, you've likely popped the amp or the amp's power supply in the sub box.
6helpful
Need to the baud rate how do you do it
Enter Maintenance Mode:
1. Unplug power from rear of Fax machine, hold the Menu button while plugging power back in. Continue to hold the Menu button until "Maintenance" appears in the LCD window.
2. There are no helps for the Maintenance mode. Follow parameter change procedures to the letter.
Changing Baud Rate from Automatic to 9600:
1. Enter 10 (one, zero). This will bring up WSW00 on the LCD window.
2. Change the 00 to 19. If the baud rate is set to automatic, the numbers that appear will be 11100010.
3. Change the 11100010 to 01100010. This sets the baud rate to 9600.
4. Press the "Set" button just below the LCD window.
5. Press "Stop".
6. Enter 99. This will exit Maintenance mode and make the fax ready to use again.
My 9600 just prints pages and pages of numbers and symbols when I send anything to print
Sounds to me like you are using an incorrect printer driver, or corrupted settings. Please disconnect the printer USB or LPT cable the under control panel >>Printers , uninstall your printers. Surf to the brother website and download a new driver for your printer and Operating system version Vista / XP ect. then install the new driver software and reconnect the printer. Kind of a pain, but it will fix it. Take care
Moto rokr e8
To drag and drop music, photos, and videos between your PC and phone
Select Settings (or Office Tools > Settings) > Connections > USB Setting > Memory Card. Connect the USB cable to phone and PC. Open phone or memory card removable disk (PC: My Computer; Mac: desktop). Drag and drop files between PC and phone or memory card. When finished, safely disconnect disk (PC: use Safely Remove Hardware; Mac: drag removable disk to trash). Unplug USB cable.
These are the steps. You just drag & drop. If you need clarification on any of the steps don't hesitate to ask me. If this helps plz rate this for me. Thank you kindly.
How do you change the transmitting speed from 14,400 to 9600 ?
Fax machines are ANALOG devices, your fax will not work reliably on a DIGITAL phone line. There are no analog packets.
1helpful
2answers
Top U.S. Robotics Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
