Question about GE JVM1640 Microwave Oven
GE JVM1640 micro wave oven
I believe the oven was installed improperly. i have owned two of these in the past and when i turned the fan on it would circulate the air out the top front of the oven. Or it may be vented out of the bldg. In this case there is a black cover of some sort where the fan blades would normally blow out the top front. But there is no air movement. I suspct it was originally going to be vented out of the bldg but it was not and the covers were left in place, So, the vent does not blow air even though you can hear the motor turining at both speeds. How do i remove the covers so that air will circulate?
  • GE Master
  • 9,098 Answers
You can check and / or correct your installation with help from the installation instructions.
You can download GE owner's manuals and installation instructions here.
Posted on Feb 08, 2009
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Micro wave oven stopped working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Aug 09, 2011 | GE JVM1640 Microwave Oven
Microwave runs but not heating
magnatron may be faulty.............
cheaper to replace micro.................
cheers
Mar 27, 2011 | GE JVM1640 Microwave Oven
MY GE JVM1640 microwave in not heating.
BAD CONTROL BORD OR BAD TRANFORMER ,IF THIS MICROWAVE IS LESS THEN A YEAR PROBLEM CAN BE COVER FROM FACTORY WARRANTY. IF NOT CALL SEARS TO GET YOU STIMATION FOR REPAIR..1800-4MY-HOME..
Feb 18, 2011 | GE JVM1640 Microwave Oven
Why would my microwave no longer heat or cook?
micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Does it have a fuse in it It make a pop sound while in use and now all power is off on micro wave Lights fan etc
When this happens, it is usually, the magnetron, or the High Power Diode, or both, There is sometimes an internal fuse, however if this is b;own,that indicates a very serious fault, the unit is shutting down, to avoid, fire or explosion. You need to obtain a "Quote" for repair from a professional. MW's are very very dangerous to service.
Apr 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
GE space maker JVM1640. Does not heat food.
with out a proper diagnosis, i would have to believe your magnetron is gone
Oct 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Will the template for JVM1790 be the same as earlier GE models?
Make your own template of the holes in the top of your cabinet and lay it over the new unit and see if they align. As long as your replacing GE with GE it probably will work.
Oct 04, 2017 | GE JVM1790 1000 Watts Convection /...
GE JVM1640 Microwave Oven Logo
177 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
