I can not figure out how to open the stapler.
HI, take a look at this video:
Also if you need staples, you can find them on amazon, here: Amazon com 5 000 No 10 Tot Mini Staples for Swingline Tot Staplers. I hope this was helpful. Cheers
The Markwell L3 Tacker is nothing like the ones in the above video.
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
SOURCE: LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
SOURCE: there's a jammed staple but I can't figure out how to open it to fix the problem and refill it
This is how it works on the Arrow staple gun. On the back bottom, opposite end from where the staples come out, there is a little plate. Push it in and it unhooks and pops out. attached to a rod. When you refill with staples, just push them in, then put the rod back in and the spring applies the pressure.
SOURCE: How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy
Instructions
The Markwell L3 loads from the front. There is a small black piece that lifts up and then swings out to allow access to the staple slot. Just slide the new L3 series (it only works with Markwell Staples) in and press the latch closed.
