Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
2002 gmc envoy slt possible over heating
On my 2002 envoy while drining on normal highway or streets the temperature in at 190 or 195 but when I go up on steep hills or roads the temperature hits 210 but when I'm back on normal road it goes back to 190 or 195 is this normal or do I have a problem I need to check out.Also it does not over heat at all.This temperature only changes on steep hill or roads.Any hints
  • josemin180 Feb 10, 2009
    Hey thanks for the tip.Just thought I check before it got worse.
    Problem Solver:
  • 5 Answers
Sounds normal. The harder the engine and transmission work the warmer they get. The fact that it cools back down during normal driving conditions is great. If it didn't, you'd have a problem.
Posted on Feb 09, 2009
Why doesn't the air conditioning work?
New owner of 03 Envoy XL SLT - AC not working - Chevy TrailBlazer ...
forums.trailvoy.com > ... > OEM Issues
Apr 12, 2011 - 11 posts - ‎5 authors 2003 GMC Envoy SLT XL Summit White ... My Envoy XL SLT has the I6 engine, digital driver/passenger, and rear heat/AC controls. When I looked at it, .... There have been reports of failed sensors in the compressor. Can you ... [SOLVED] Rear A/C blower 03 Envoy XL
May 22, 2011
XL rear a/c problem - Chevy TrailBlazer, TrailBlazer ...
Jul 31, 2009
Air Conditioner Problem - Chevy TrailBlazer ...
Aug 17, 2008
Blower Motor/Module? Problem - Chevy TrailBlazer ...
Mar 9, 2007
More results from forums.trailvoy.com
Jul 18, 2015 | GMC 2003 Envoy XL SLT
I'm getting code PO300. Drove fine to work, going home it ran horrible.
P0300 GMC - Engine-Codes.com
engine-codes.com/p0300_gmc.html
OBD-II Trouble Codes Definition, Description and Repair Information ' Engine-Codes. Engine- ... 2000-2008 GMC Yukon XL ... 2002 Chevrolet Blazer P0300 Misfire Diagnostics ... 2008 GMC ENVOY Engine And Engine Cooling:engine Details.
Jul 14, 2015 | GMC 2002 Envoy XL SLT
Locate temperature sensor on 2007 gmc Envoy SLT
on top of motor in front by where radiator hose is.
Oct 07, 2014 | 2007 GMC Envoy SLT
Why does my2004 gmc envoy xl slt idle high at startup?
This is normal. All vehicles idle high at start up to get the engine to operating temperature. This is known as open loop. The computer ignores signals from O2 sensors to keep your engine running safely. Once it has warmed up, it will enter closed loop, and you will see a decrease in idle.
Jul 05, 2014 | 2004 GMC Envoy XL
2002 gmc envoy is over heating have changed the thermostate and the put new radiator but its still over heating any suggestions
Have the FAN CLUTCH checked. they are a common failure. Get a AC DELCO or the part from the dealer. Why was the radiator replaced? Heater work OK? A/C works OK?
Sep 22, 2011 | 2002 GMC Envoy
Can the ac compressor come out bottom with 4X4 2002 slt model gmc envoy???????????? with out lifting engine or pulling sub engine cradel???????
Removing from bottom is not possible, too many things in the way. If you remove the alternator, the belt pulley and the engine hoist bracket, the compressor should come out the top.
Aug 02, 2011 | 2002 GMC Envoy
Envoy is running on highway and suddently turn off & wont start
This could be a bad key. Expensive but if necassary to replace to check on the symptom of the car since no codes are being thrown. I would also say check your Idle Air Control valve and your EGR valve to make sure they are working proplery
Apr 17, 2009 | 2002 GMC Envoy
2002 gmc envoy bose 6cd player does not play, shows player error
how to remove a bose cd/radio from dash of a GMC envoy slt cd's are stuck inside
MOTOR TEMPERATURE
the a/c will run based on the pressure switch adn has nothing to do with the temp of the vehicle and or the engine.
If the freon is low initial stages you will hear the clutch clicking on and off and when it becomes extreemly low will not engage the a/c clutch at all/.
Jul 27, 2008 | 2002 GMC Envoy
Heating & Cooling Logo
138 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
