Question about Paxar Monarch 9855 Thermal Printer
9855 ribbon take up reel not working
Ribbon take up reel does not operate when batch is sent to printer, but labels print, but ribbon is not taken up by reel. when feed button is pushed the take up reel works.
what gives?
  • Anonymous Mar 20, 2014
    Gear for journal not advancing
  • 257 Answers
When you're sending data to the printer you're sending a command that is telling the printer you're NOT using a ribbon. When the printer receives the data it's shutting off the ribbon. Check your software.
You should be set for THERMAL TRANSFER.(RIBBON)
THERMAL DIRECT Means NO RIBBON
Posted on Apr 15, 2009
We have a 9855 Monarch barcode Printer. We are
If the printer display just shows Ready, but doesn't print, there could be a few things wrong.
1 - no data is going to the printer
2 - data is going to the printer, but it is not the printer's native language
3 - cable connectivity issues
4 - wrong cable is being used
5 - if wireless, data is not going to the correct IP
If using a 3rd party application, make sure that you've chosen the correct Monarch printer, as well as printing to the correct port. Sometime people print to LPT instead of Serial, as an example.
If using 3rd party drivers, make sure of the same thing.
To see if the printer actually works, press both of the arrows on the display, at the same time, after the printer is at the ready screen. As long as have the printer configured correctly (ribbon, supply type, etc.), the printer should print out a couple of labels.
Oct 26, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Different Crystal output from model 9835 and 9855 Monarchs
Your software wouldn't care whether it's a 9835 or a 9855. It can't even tell the difference. Are your supply settings and communications settings the same for both printers? Any error messages on the display when you print?
Jul 08, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Attempting to print labels from a Monarch 9855 printer and receiving error message: "Print Head error 768." Printer was working fine as of last Friday. We have other Monarch 9855 printers that are on other...
the problem is your printhead is bad . do a print test by presing both arrow buttons at tah esame time for two seconds, look fo rthe line that reads bad dots. if the value i sgreater than 000 yu have a bad printhead
jay
Jun 08, 2009 | Monarch Paxar? 9855 Label Printer
Paxar 9855 print error
You have a format problem. Something isn't correct in your mpcl code.
Error 400 - "The character immediately following { is invalid or not an ASCII character."
Jun 01, 2009 | Monarch 9855 Thermal Printer
Problem to print label when Monarch is installed on network
101 : The format referenced by batch isn't in memory. (Try rebooting printer or closing/opening software)
005: Supply width is invalid. (Check your format data)
May 29, 2009 | Monarch 9855 Thermal Printer
Z4M printer suddenly running in reverse
The problem is in the power supply board and must be replaced. What fails is the chip stepper motor driver.
Mar 10, 2009 | Zebra Z4M Printer
Zebra S600 printer
  1. Try just storing your labels in a cool dry place before using them. Peeling labels are usually a sign the glue is poor or weak.
  2. When tearing you labels off, feed them out before tearing them off, then hit the auto-align. See if that helps it.
  3. Try pushing a normal playing card under the metal cutter that tears the labels and pull it up and through the front to bend the blade slightly outward. This will hopefully allow the labels to pass underneath.
Jul 30, 2008 | Zebra Stripe S600 Thermal Label Printer
Paxar 9855
If you have not found an answer to your issue, you may wish to call their tech support at monarch.com.
Labels are supposed to come off the liner, but if you have the supplies or ribbon loaded incorrectly, or if you have adhesive coming in contact with the ribbon before the media indexes to the next label, I can see where the ribbon can get attached to the labels.
You shouldn't have any slack in your ribbon when the printer prints, and if you do, you may need to make minor adjustments to take up that slack.
As for a heating adjustment, I'm not sure what you mean, but there is an adjustment to increase the printhead temperature, but that is only to increase the contrast on your labels, and should have zero effect on your reported issue.
Contact monarch.com's tech support line if you find that the data in this response isn't able to guide you to the culprit.
Feb 13, 2008 | Paxar Monarch 9855 Thermal Printer
Ribbon error 754
Your printer is not correctly configured for ribbon. Download the manual located at ftp://www.servisource1.com/user_documentation/9855/9855oh-ae.pdf
Go to chapter 4-1 to see the map of the menu system and change your printer to ribbon yes.
Make sure that your printer is loaded with supplies and the ribbon is set up correctly, as well as slack taken out.
You may see a couple of labels not print well, but after that, you shold have proper tension and good print. If you notice a lot of ribbon wrinkle, you probably need to reload your ribbon or adjust the tension bars.
This should resolve any issue you have with the ribbon.
Ohiotech
Sep 14, 2007 | Monarch 9855 Thermal Printer
Monarch 8055
Yes, it does require a take up reel or core. It should look the same as the one that is in the core of the ribbon spool.
You can order these from the manufacturer. Please note the width of your ribbon, as there may be more than one core width for sale for this model.
Their number is 1-800-543-6650
Ohiotech
Sep 03, 2007 | Monarch 9855 Thermal Printer
Paxar Monarch 9855 Thermal Printer Logo
244 people viewed this question
Top Paxar Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Paxar Office Equipment and Supply Expert? Answer questions, earn points and help others
