Question about Epson Stylus C42UX InkJet Printer
The yellow caable for the c42ux will not fit baack on properly
Hi i bought a new epson and i need help the yellow part has came loosie and as it is very tight cant get back on any suggestions
Thanks
Mazdepan
  • Gerry Millward
    Gerry Millward May 11, 2010
    Hi there - if you don't respond it's a bit difficult for me to help. If the problem is that the drive belt has come off, I can certainly help you fix it!
  • Gerry Millward
    Can you explain more clearly what you mean by the "yellow part". The only item I can think is the print head drive belt (which is more orange than yellow).
  • 353 Answers
OK - since you won't respond, we'll assume that the problem is a loose drive belt. To check this and repair it you will need to remove the printer top cover. Once you have done this, check that the spring assembly is intact on the left end of the drive belt. If it isn't you will need professional help to fix this. If it's OK, then look at the drive motor end on the right. If the belt has come off the drive pinion, you must loosen the two screws holding the drive motor. This will permit you to get the drive belt back on the pinion. Make sure the drive motor is held in the correct position when you re-tighten the two screws. Test the printer before replacing the cover.
Posted on Feb 27, 2009
Epson stylus c42ux how do I put in new ink? I can't get to the print cartridges
Power up the printer and open the lid. The print head should come to the center. When you close the lid, it will go back to it's park position. Don't pull it over with the power off.
Jun 01, 2011 | Epson Stylus C42UX InkJet Printer
After the refiling the cartage & install in the printer. The Printer Red light is on. Why it is so?
The only reason behind that is the Cartridge that you have installed is not properly fit in the Printer.
Remove it again and check and see if there is anything stuck there that is stopping the cartridge to fit properly.
Install it again the way it should fit completely in the printer and should not move a bit.
Thanks
Jimmy
Jul 23, 2010 | Epson Stylus C42UX InkJet Printer
Epsn C42 No Yellow
The ink path is probably plugged. Try getting some ink cleaner and a squeeze bulb to purge the path IN the printer by forcing cleaning fluid into the yellow channel (cartridge removed). After it flows, it will likely take a bit to get the yellow flowing. If you have a refill kit, you could "encourage" the flow with it. Nothing you can fix by cartridge, the problem is in the printhead.
Aug 21, 2009 | Epson Stylus C42UX InkJet Printer
Iam looking for softwere epson c42ux
Hi sharifjaafar, Below is a link to the Epson website that has drivers for your printer. Just click on the link, or if it doesn't work, copy and paste it into your browser window. Select your operating system and download the driver. There are also other support links on this page. Hope this helps! Halhttp://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14403&infoType=Downloads
Jun 10, 2009 | Epson Stylus C42UX InkJet Printer
Epson c42ux cartidge stuck, won't feed
Hi Sunny Shine
It's very difficult to help you if you don't respond to our questions! If you continue to maintain a mysterious silence, we will presume you no longer have a problem - Problem Solved!
Feb 18, 2009 | Epson Stylus C42UX InkJet Printer
Replace ink cartridge
The Reference Manual provides clear instructions on this in the "How to" section. If you don't have a copy, download it from:
http://esupport.epson-europe.com/FileDetails.aspx?lng=en-GB&data=FGQ8MBMpKlt3LcQmNeQVzwoYgQ5dO95G&id=8985
If I can clarify anything, report back
Dec 01, 2008 | Epson Stylus C42UX InkJet Printer
Cabling problem??
perhaps that the cable isn't put in the way it should , but it could also well be that you need a chip resetter for epson cartridges to let it recognize the cartridges correctly
Apr 30, 2008 | Epson Stylus C42UX InkJet Printer
Printer cartridges
Hi:
I solved this problem; there was a white plastic "piece" stuck upwards and all I did was push it back down. Now the cartridges are able to go all the way to the right and the printer is working properly. Looks like I need to replace the cartridges now, that's all.
Thanks.
Lori
Feb 18, 2008 | Epson Stylus C42UX InkJet Printer
EPSON STYLUS C42UX PRINTER.
I have had the same problem, my solution was taking a hammer to the stupid thing and buying a lexmark!
Dec 10, 2007 | Epson Stylus C42UX InkJet Printer
Epson Stylus C42UX InkJet Printer Logo
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
