Question about Orion1934 19" TV
Orion tv 1333
Can only get one chanel with my digital coverter box.
  • 6,784 Answers
Try to use the add a channel tool or, search for digital channel tool. this should pull up most of your available channels in your area. if you've done this then, you may have only one active dtv channel available at this time.
Posted on Feb 04, 2009
How do i connect Orion DVD Player to LG Television with out a remote control.
The best option would be the HDMI-to-HDMI connection between your player and your TV. But because you mentioned that your TV is an old model, probably it does not have an HDMI port, in which case you have to use the RCA A/V connection. I understand you do not have a remote control for your TV, but you do not program a TV channel to watch DVD movies; you just switch between your TV and the DVD player as your audio/video sources. Here is what you have to do: check on your TV box for a button labeled 'Source' or 'Input'. Press on the button and it will alternate between TV and DVD (assuming you do not have any other device hooked up to your TV).
Dec 17, 2014 | Orion BDP3959 Player
I have Sony TV analog, I used Zenith Coverter Box now. Yesterday, I entered the MENU, Scan All, Scan update, then go lower, chanel 3, 4 ..... and suddenly my TV NO signal, just see lines on screen of TV. I...
Converter box issue - look for a reset to factory defaults .If that does not take care of the issue you will need a new converter. Fortunately they are not expensive.
Sep 20, 2017 | Zenith Dtt901 Digital Tv Tuner Converter...
Orion tv model 1933 only 34 and aux
change your memory ic ( 8 pin ic ) or" reprogram your memory ic.channel store problem solve 100%.
May 29, 2012 | Orion1934 19" TV
I need a 3 digit code for RCA converter box for a Orion tv.
Hello
You haven't given a clear problem post ebefore me. You have only give the model number and brand name of your TV only. Not give the model number of your RCA converter box. Yet i posts a solution to your problem, assuming that your RCA Converter box model number is " DTA 800B1 " The three digit setup codes for Orion TV with this RCA converter box are: 029, 189, 200
ok
gopakumarg43
Oct 04, 2011 | Orion STV2763 27" TV
Are my Orion tv's purchased in 2002 digital ready
Your TV does not have a digital tuner. You'll need a converter box for digital broadcast reception. Remember that if you're on a cable system or using a satellite receiver, your TV doesn't need to have digital tuning. It's only if you want to watch off-the-air broadcasts that you'll need the converter.
May 12, 2009 | Orion STV2763 27" TV
Converter box
put your tv on channel 3 , and make sure the back of the "converter boxes switch" is set to channel 3 not 4 if using the coaxial antenna connection to the tv
if using the video and audio jacks then the switch on the box will not matter
Mar 14, 2009 | Televison & Video
Black box appears on tv screen
Check to see that you don't have any channel locks or parental parental permission measures deployed. If so remove them, this includes V-Chip, and Parental lock out on the remote, and check your TVs menu items. What channel are being affected by this problem? Give channel number and channel type.
Thank you,
Shuttle83
Aug 17, 2008 | Orion1934 19" TV
Sylvania 27" TV Model# SST-4272
BULL IT NEEDS A COVERTER BOX
Aug 01, 2008 | Orion STV2763 27" TV
ORION TV 1926A
lost the remote?... try a different universal remote. i have a orion 27" but i think it has a menu button on the front of the set. im at work.. when i get home ill check and repost....if you dont want to buy another universal.. barrow a friends and give it a try... sometimes the manufacture puts updated CODE's for the remote on the website.. might check that as well. good luck.. more to come.
Jan 22, 2008 | Orion1934 19" TV
Orion tv32RN10D Digital problems
factory reset hold volume button on tv down all the way while holding it down hold number 1 on your remote goes to stanby turn back on..
Jan 08, 2008 | Orion HDLCDVD225 22 in. LCD TV
Orion1934 19" TV Logo
194 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
