Question about Sony Playstation 3 (PS3) Console
No power I was playing my PS3 when the system turned off. Now it will not turn on anymore.
  • moneyg Feb 06, 2009
    Same things happen to me. I was playing a game when it switch off and won't start again. It doesn't seem to matter what I do it won't start up again.
  • 39 Answers
UNplug console for a minute, and reconnect. Make sure switch in back is on. also make sure you don't have it locked up in a an entertainment center. Hopefully you had the PS3 plugged into a surge protector. If none of this works contact sony at 800-345-sony!!
Posted on Feb 06, 2009
When playing COD Black Ops yesterday my system froze. The screen seems to have a lot of red pixels. I reset it 4 or 5 times and the game played for 5-10 mins before freezing again. This evening I can't...
i got the same problem only with my ps3 it froze while i was playing black ops online so i turned off the power n after i restarted my ps3 he could not read any game discs anymore, im now busy with reformatting my ps3 i dont know about the xbox but maybe u also have the abbility to reformat ur system if so do it but put ur saved files on a usb stick or on somthing els cus u will loose everything but ur system gets a clean start and it checks for system errors wich come by shutting off the power wile it was not ment to and fixes them
Jan 31, 2011 | Microsoft Xbox 360 Console
Will not play any ps3 games or movies
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Thank you
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 power issue
Your system has overheated. If it doesn't get on at all anymore, you should get it fixed in the place you bought it from. That happened to me.
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
A problem has occurred the last time the ps3 system was last used, and the system did not turn off correctly. after that thing pops up after i turn it on i press yes send to ps3 place and then it sends in...
Try a video reset first.
While the PS3 is off (red led)
Hold down the power button until you hear the second beep, quickly release.
Let me know if that solves your problem otherwise it's a corrupt file system.
Nov 20, 2009 | Sony Playstation 3 (PS3) Console
Downloaded latest update to the ps3. played
well, what you have here is a serious problem.. you need to take that in to the repair people to get that fixed
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
PS3 not turn on anymore
HI, this is the result of a weak and, failing power supply unit. you will need to contact Sony for a power supply unit replacement procedure.
To clarify. Your power unit has failed.
Overheating is a big cause of power unit failure. To prevent this in the future. i recommend purchasing a aftermarket cooling device.
Jul 08, 2009 | Sony Playstation 3 (PS3) Console
PS3 plays game wont load XMB
What I did?
1).Shut down the system from the switch on the back.
2).Place and hold your finger down the on/off power button.
3).Turn the switch on the back “ON”, while still holding down the on/off power button.
4).Release your finger from the on/off power button, after you hear 2 beeps.
Apr 02, 2009 | Sony PlayStation® 3 (80GB) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
My ps3 won't turn on anymore....
Try holding the power button on the ps3 for about 10seconds. It should beep as it normally would turning on, carry on holding the button until it restarts. This should restart the ps3 in standard mode and you should be able to play again.
Jun 08, 2008 | Sony Playstation 3 (PS3) Console
Screen froze,now wont read any discs
if your system is only 5 weeks old PS3 factory warranty covers all defects in materials and workmanship for 1 year from purchase date. there are some inclusions and exclusions which can be accessed at
but if you have any implied warranties from the store you purchased it at you should hit them up first to see what they'll do for you
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
16 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
