Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
How do I set up this modem as a secured network .
I have been using this modem ( WA3002G4 supplied by Data One) for surfing the internet as an 'unsecured' network.
Recently I suspect it is being accessed by the neighbours .
How does one create a 'secured' network with this modem ??
  • Wilfred Desouza
    Wilfred Desouza Feb 05, 2009
    Thanks Vedhick,
    I got the IP address from 'ipconfig' (which happened to be the Linksys address 192.168.1.100) and typed it into the browser address window -
    . However I got the Google page for this address with other links instead of the User Name /Password windows.
    The router is a UTstarcom (Made in China) wireless, model No. WA30002G4
    Thanks for your help in advance
    desouzawm
    I am using the UTstarcom
    Scholar:
  • 54 Answers
Is your modem wired or wireless?
if it is wired you donot have to worry but if it is wireless and the network is unsecured you need to perform the following steps.
if your computer is using the same wireless connection then you will loose the internet connection wirelessly as you will need to setup the configuration with the computer again..
1st u need to find the ip address of the computer..
click on start,then click on run in the box type in cmd and hit enter
now you will see a black box in that box type in ipconfig and hit enter
out of all the results you will see something which says default gateway there will be numbers beside it make a note of those number(eg it will be something like 192.168.1.125..this is just an example)
go to the browser page and type those numbers in the addres box,
it should open a user name and password box,type in admin/admin as the user name and password,
there you will see a tab for wireless under that tab you will see the option for security and then you need to make it secured..
YOU CAN TELL ME WHO IS THE MANUFACTURER OF THE MODEM SO THAT I CAN EXACTLY TELL YOU WHAT YOU NEED TO DO....
vedhick
Posted on Feb 05, 2009
  • Ved Pradhan Feb 06, 2009
    thanks...
    i think you were typing in the ip address we need to type the default gateway in the address box,
    when you do ipconfig you will get default gateway as well,
    once you type now you should get the ustar page which will tell you to put the username and password,
    the default user name and password is admin/admin,
    once you are in the router page,on the left side you will see an option that says wireless,
    click on wireless and you will see on the right hand side which will say authentication type it might be disabled click on the drop down list and choose enable....
    after that choose wep and then put in the security key.usually it will be 10 or 21 alphanumber character or just numbers i suggest you to sure 10 keys...then save the settings and your network will be secured...
    make sure the computer is wired to the router while you make the network secured after that if you have any laptop
    that is wireless you need to configure the new settings to connect to it...
    im sure will get it this time....
    vedhick..
I have just bought an acer iconia w3-810. When starting the set up process I can't connect to the Internet. It says I have no connection to internet. Tried setting up a network and it can't find my...
try connecting to another location like the public library. it could be that your router security setting may be set too high.
http://brandzone.bz/files/catalog/upload/5/8/planshet-acer-iconia-w3-en.pdf
Wireless networks - 29
Installation speed and simplicity Installing a wireless LAN system can be fast and easy and eliminates the need to pull cables through walls and ceilings. Components of a wireless LAN To set up your Wireless network at home you need to have the following:
Access point (router)
Access points (routers) are two-way transceivers that broadcast data into the surrounding environment. Access points act as a mediator between wired and wireless network. Most routers have a built-in DSL modem that will allow you access to a high speed DSL internet connection. The ISP (Internet Service Provider) you have chosen normally supplies a modem/router with the subscription to their services. Read carefully the documentation supplied
with your Access point/router for detailed setup instructions
Feb 03, 2015 | Tablets & eReaders
Tip
Use the iPhone as a modem
Internet exchange, if you're wondering what this application. Just connect the <b>USB cable</b> while in the same way when you want to transfer files from iTunes. Then go to <b>Settings</b>,<i> Network General</i>, <b>Internet Tethering</b>.Will turn and you can surf the net on a <b>computer</b>. Make sure you have a data plan for <i>broadband</i>.Surfing on a <b>phone</b> without a data limit of at least 10 Gig can make you bankrupt.
on Dec 12, 2010 | Cell Phones
My dataone WA3002G4 (BSNL) modem is not connecting to internet
You need to configure the pppoe connection in the modem.
Jul 08, 2009 | Computers & Internet
This sounds like you need to set up your main gateway or WAN port settings on the datatone to match what your ISP provides? Is it possible to get suggested settings from the ISP?
Jul 08, 2009 | Linksys Wireless-G WRT54G Router
Network sharing
go into the TCP/IP protocol properties where we have option to obtain IP address automatically. have only one system with IP address and the remaining 3 systems select obtain IP address automatically. It will work.
Mar 09, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Can;t use intent on mobile
Here is what you should do step by step:
I.Configure your Computer
1.Install Bluetooth Adapter
2. Bluetooth Configuration->Local Services-> Add Serial Services ->Bluetooth Serial Port->Properties
Check – Startup Automatically
Check – Secure Connection
COM Port: COMx( mine is COM6)
3.Control Panel -> Phone and Modem Options->Modems->Add-> Check Don’t detect my modem->Next->(Standard Modem Types)->Communication cable between two computers->Next-> on witch port do you want to install it ? -> Selected ports -> COMx ( in my case COM6)->Next->Finished
Now in phone and modem options->Modems you should have : Communications cable between two computers : Attached to : COMx ( COM6 my case)
Select Communications cable between two computers -> Properties->Modem-> Maximum Port Speed : 115200 -> ok ->ok.
4.Control Panel ->Network Connections ->Create a new connection-> Next->Set up an advanced Connection-> Next-> Accept incoming connections->Next-> Check : Communications cable between two computers ->Next-> Check: Do not allow virtual private connections->next->next->select: Internet Protocol(TCP/IP)->Properties:
Network access : Check Allow callers to access my local area network
TCP/IP address assignment : Specify TCP/IP addresses:
To: 192.168.0.y (y=52 in my case)
->OK->Next->Finish
5.Network Connections
Bluetooth Network -> Enable
Internet Connection ( your internet connection ) -> properties->Advanced->Check:Allow other network users to connect trought this computer’s Internet Connection->OK
If all goes well : Bluetooth Network-> Properties-> Internet Protocol ( TCP/IP)->Properties Should have the following setting:
Checked Use the followind IP address:
IP address: 192.168.0.1
Subnet mask: 255.255.255.0
->OK.
6.Start->Control Panel->Administrative Tools->Services->Routing and remote access->Properties->General: Startup type : Automatic - this service MUST be started
**7.Install AnalogX Proxy http://www.analogx.com:80/files/proxyi.exe (for the latest version)
Proxy->Configure-> Proxy Binding: 192.168.0.x ( for me x=50 )->ok.
! If you use a proxy, remember to start it .
II. Configure Phone:
1.Install GnuBox - http://gnubox.dnsalias.org/gnubox/ ( for the latest version)
2.Configure Access point
Tool->Settings->Connection->Accces Points-> New Access point->Use Default Settings
Connection name: Bt
Data Bearer: Packet data
Access point name : Bt
User name: none
Promt Password: NO
Password: ****
Authentication: Secure
Homepage: none
Option->Advanced settings
Network Type: IPv4
Phone IP address: Automatic
Name Servers: Automatic
**Proxy serv. Address: 192.168.0.x ( for me x=50)
**Proxy port number: 6588
3.Configure all the applications from your phone witch require internet acces to use Bt Access Point
4.Configure GnuBox
Options->Install Set to GPRS
Options->Install Create Records
Options->Install->Copy settings from GPRS
Options->Install->set RAS login script
Exit GnuBox
Open Gnubox
Options->2box Bluetooth->Serial Port
Select – your computer
Do you want to require encryption? Yes
Options-> Install->change default AP
** Configure NetFront
Options->Settings->Connection
Enable Proxy : Yes
Proxy Host : 192.168.0.x ( in my case x=50)
Now you can browse the internet from your phone.
NOTE: First Configure the phone and your pc without the ** settings, and if you can’t browse the Internet form your phone then use the ** settings.
Hope this works fine.Thank you.
Nov 25, 2008 | Computers & Internet
How to activate wifi 802.11g;ADSL2+Router
switch on modem, computer. launch internet explorer. type http://192.168.1.1 in tool bar. You will get prompt for log in. log on id is admin, password is 0000. now, you will get connected to modem. On left side list, you will see "Wireless". Click on this. you will get to Modem wireless basic page. Tick "enable wireless",change country to India,click save/apply. Now open control panel on your laptop. You will be having wireless network tool / wizard. Click on this, follow the prompts to connect to the wireless network that gets detected automatically.
Nov 08, 2008 | D-Link DI 514 Wireless Router (DI-514)
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
513 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
