Question about Garmin GPS
Garmin GPS 45 XL internal battery
I can start up my Garmin 45 XL GPS and aquire then I get an alarm my internal bettery life is low and it shuts off. Is this battery replaceable and what do I need to fix it?
Thanks
Bob
5 Suggested Answers
SOURCE: getting a fix status.
Did you try setting the time precisely for your location - then wait a minute?
Posted on May 13, 2007
SOURCE: Garmin GPS problem
I have a 276C that has the same problem. Garmin has a unit with this problem and is working on a solution. The problem is that the real time clock loses time when the unit is turned off and disconnected from a power source. As a result when you turn on the unit it thinks the satelites are in a different orbit than where they actually are. The unit will continue trying to aquire forever and not find the satelites. You have to select "New Location" from the menu and select "Autolocate" and the unit will start to look for any satelites in view. The unit should get a fix within 15 minutes. This is a very frustrating problem having to reset it every day. There is a new version of firmware (5.3). I don't know if the problem has been fixed with this release.
Posted on Jul 06, 2008
KingDWS
  • 1606 Answers
SOURCE: Replacement Memory Battery
The Garmin GPS III and III plus use a tabbed lithium coin battery. Its is a Panasonic BR-2032. You can buy these for about $2 from larger electronic suppliers. The problem is that the shipping or minimum order will make that $2 battery cost you about $25. For you cheap guys there is a solution. You buy a CP-2032 and a coin holder. $2-3 for the battery and $1-$2 for the holder. 6 screws to open the case, cut the wires close to the battery as possible. Solder the wires to the coin holder (good idea to heat shrink or cover the solder joints), put in the new battery and you are done the easy bit. You will most likely have to trim away some of the plastic on the holder such as legs or other things sticking out. Unfortunately you can't really do this with out fitting it in the case and you don't want to do that until you have the holder on the wires so it will be in the right place. Once you get that, simply play with it until you can put the screws back in. And tighten gently. Not too much or the gasket will be squeezed too far out. Put tAA'sx AA's back in, take it outside so it has an unobstructed view of the sky, set it down and go for a long coffee or three. It will now download the almanac and any other data which can take 15 minutes or more depending on the satellites. You should see a low battery error and other errors such as saved data lost. Ignore these. You can put it on a external power plug or just leave it off with the AA's and in 5-7 days it will have reset the error as it figures it it now charged. You get the battery error even with a new fresh charged battery. I think there is a Garmin reset code to force this but none of the codes I have tried have worked.
Posted on Nov 13, 2008
SOURCE: garmin 45-xl price
Yeh about £20-£35
Posted on Jan 22, 2009
SOURCE: garmin gps III / internal
March 2009 I replaced the solder type battery of my GPS III Plus with a battery holder (clip) that a “Basic CR or BR2032 Coin type battery”, without solder connections, that is, they simply clip into place. Replacement batteries can be purchased at less than a $1.00 of E-Bay.
Posted on Mar 09, 2009
My Garmin GPS 12 XL will not power up. Is that an internal battery problem or is the unit shot as Garmin technicians tell me?
try swapping out the batteries, no harm in opening it up with a screw driver (will void the "warranty" that expired 12 years ago) check if there is an internal battery (usually a coin cell battery like cr 2025 or CR2020) otherwise it is dead and time to get an e-trex 30... great simple little unit with lots more features
Jul 09, 2014 | Garmin GPS 12XL GPS Receiver
Garmin 45 no position.
did you use the select country, or autolocate
Nov 29, 2007 | Garmin GPS 48 GPS Receiver
When I start my garmin nuvi 765t. it will try to start but just before finishing loading the maps it shuts down and keeps trying to start until I turn it off. also my computer does not recognize it when I...
Download the Garmin Communicator Plugin and Web Updater software from Garmin's website - both tools are free and will load the proper USB drivers for your 765T.
Ensure that the battery is fully charged via the battery strength icon, prior to aquiring satellites.
To reset the 765T: Hold finger or thumb on lower right hand corner of screen while powering the unit on from the off position. This will erase all user data.
Nov 16, 2009 | Garmin nuvi 765T GPS Receiver
Showing low battery
the battery is failing, the life span of the garmin battery is around 2 years, contact garmin for a replacement battery.
Aug 25, 2009 | Garmin StreetPilot c310 GPS Receiver
5yr old Garmin 76s shuts off
KUDOS! Others with the same problem informed me that it is a softwear problem and to download the 4.0 version free on the Garmin web site....l'll do it ASAP and write again if it doesn't work...RG
Jul 19, 2009 | Garmin GPSMAP 76 GPS Receiver
Battery life
yes take your garmin to any radioshack store as they have devices that allow you to add an exterior battery source
Apr 16, 2009 | Garmin iQue 3600 GPS Receiver
Garmin nuvi 310 satellite aquire problem
I have a Garmin Nuvi 350. I solved the problem by purchasing a Glisson GPS antenna that plugs into the external GPS connector on the Garmin antenna.
Apr 04, 2008 | Garmin GPS
Garmin gps 45xl
To bring your Garmin 45 XL back to life ( reset ) hold down page and start untill the screen comes on. It will take up to twenty minutes to locate your available satelites..
Good luck
Vic
Mar 20, 2008 | GPS
Garmin GPS 45
It is probably one of the following:
1)Old Software
In 1999 the GPS satellites were reset and the new almanac data had to be loaded into the GPS 45 for it to continue to work. It was not uncommon for that model to quicly kill a set of batteries when it is having difficulty acquiring, which would cause it to shut down in order to save the batteries for its internal memory.
I just did a quick search of the Garmin website and it appears they no longer support that model. If you go to their support page and send a request for a software update they can probably e mail it to you. The update is free but to down load it, you need a PC interface cable (RS232 serial port connector) Part Number: 010-10141-00 Suggested Retail Price: $ 38.09.
2)Bad antenna
To rule this one out, borrow an antenna from another Garmin 45 or Garmin 48, or plug the unit into an external antenna and see if the unit still shuts down. The drawback to this method is that you can buy a new GPS that is superior to the one you have for about the same price as an external antenna.
3)Bad batteries
If your batteries are low, the unit will automatically shut off to protect its internal memory. I tried a lot of different batteries in my 45 and I found that Eveready alkaline batteries worked best. Rechargeable nicad batteries don't work very well because they fool the battery meter. Newer models have a setting to specify that you are using rechargeable batteries.
Ultimately the best advice I can give you is buy a new GPS. For less than $150 you can buy a new model that is more accurate, more reliable, stores more waypoints, has a better display, is easier to use, and gives you more valuable information.
Please rate this information as helpful.
Jan 23, 2008 | Garmin GPS 48 GPS Receiver
Garmin 48 memory loss
I have fixed several Memory battery low for the Garmin 48 .
May 30, 2007 | Garmin GPS 48 GPS Receiver
GPS Logo
176 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
