Back to:
Tags:
National Optical 131 Monocular Microscope
Bacteria?
posted by JohnSilver on Aug 01, 2007
What's a good magnification if I wanna see bacteria?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 16, 2007
FixYa! (100)
sluggard
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
1000x or greater as long as a clear focus can be acheived, many bacteria would be too small at 400x.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Bacteria?:
I don't want to Accept this solution
Solution #2
posted on Aug 01, 2007
Helpful (85)
jk24
Rating: 80%, 5 votes
I personally think it should be x400. You can probably view it with less, but if you really wanna see it, the higher the better!
Thank You!
Solution #3
posted on May 14, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Realistically I would suggest 1000x, bacteria is visible at 400x but can be hard to recognize from debris.
Thank You!
Solution #4
posted on Apr 28, 2008
Not Rated (0)
endospores
Rank:Guide Guide
Rating: 85%, 6 votes
The eyepiece offers 10x magnification. Depending on the type of bacteria, looking at them with the 40x objective (for 400x magnification) or the 100x objective with immersin oil (for 1000x) should give you enough magnification for even the smallest prokaryotes and protozoans.
The proper way to do it however is to find your target with the 10x objective and focus it first with the coarse adjustment and then with the fine adjustment knob. Then switch the objective to the 40x and focus it again with the fine adjustment knob. If the cells are still too small, move the objective away, add a drop of immersion oil to the coverslip and then move the 100x objective into place.
Oh, and almost forgo, it always works best if you have your cells stained to spot them easily and to enhance the cell contents, otherwise they can be tricky to spot or on the move, but it'll depend on the application really.
Thank You!
Solution #5
posted on Mar 10, 2008
Not Rated (0)
Dave Duff
Rank:Master Master
Rating: 90%, 15 votes
Seing bacteria isn't just about magnification, many
are transparent and need to be stained. Even at X1000, you will see little detail, but can make approximations of shape etc. Here is a good starting point for staining bacteria.
With a toothpick scrape a little plaque from your teeth (size of a pinhead is plenty). Put this in the centre of a slide with 1 drop of water and mix thoroughly. Allow this to dry then pass the sample through a flame three or four times (hot, but not hot enough to burn fingers) Stain for five mins using either Methylene Blue or Eosin. If you don’t have these, Blue or Red fountain pen ink will do for starters. Rinse off excess stain with very slow running water. Blot dry and observe at X400. If you have an oil immersion lens, you must use a cover slip and mount your specimen in balsam first.
If I can be of any further help, please don’t hesitate to ask.
Cheers…..Dave
Thank You!
Solution #6
posted on Jan 10, 2008
Not Rated (0)
KevinTheMan
Rating: 70%, 1 votes
bacteria or any single cell creature. pond water is great because it contains protozoa that can be quite large, and are fascinating to watch. easily see them a 200x to 400x
Thank You!
Can you Help with these Microscopes problems?
Microscopes
I replaced an old (failed - hours used up ?) mercury arc...
Microscopes
field does not change as mechanical stage is moved
Microscopes
I have lost the processing software CD for Galileo Mars...
Microscopes
My Vivitar 900x 28-piece microscope set (WIC#552844...
Microscopes
I bought this rifle and it came with BSA scope. Its worked...
Loading problems.
Repair Service
Find Microscope Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
