1990 Peugeot 405 Logo
Posted on Feb 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cigarette lighter fuse peugeot 406
I have a peugeot 406 hdi estate and i think the cigarette lighter fuse has gone. Cant find the manual, does anyone know which is the fuse for this or have a diagram so i can find out!
  • 1 more comment
  • mabbass Mar 13, 2009
    cig lighter not working need?
  • Anonymous Mar 16, 2014
    im not sure where the lighter fuse is on my Peugeot 607 can anybody help me thanks.
  • Anonymous Mar 22, 2014
    no power getting to heater fan
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
10617
Points
27
Fuse box under the steering wheel .. check fuse F23!
Q4SteveB
Level 2:
Novelist:
  • Expert 159 Answers
  • Posted on Feb 10, 2009
Q4SteveB
Expert
Level 2:
Novelist:
Answers
159
Questions
0
Helped
113938
Points
250
The 406 has 2 fuse boxes.
One is just under the steering wheel .. the steering wheel adjustment arm goes through the flap which is held up by 3x 15mm head plastic screw caps (it hinges downwards). I know because I've been into it :-)
The other box is under the bonnet, a 'small black box' that is 'next to' the Battery .. I know the washer pump fuse can be found here (because it's not in the other one) but I only discovered it's existence when I gave up and asked the garage to fix the pump :-)
Gordon Richard MacLean
Level 2:
Champion:
  • Expert 253 Answers
  • Posted on Mar 17, 2013
Expert
Level 2:
Champion:
Answers
253
Questions
Helped
77450
Points
481
Normally Inside The Lid Of The Fuse Box Is The Fuse Key
If Not Get A Light And Test Each Fuse To See Which One Is Blown The Lighter Probably Has A 15-20 Amp Fuse
  • Gordon Richard MacLean Mar 17, 2013
    By Removing Each Fuse You Can Fissualy Se If It Is BlownIt Will Be Discolored And You Will Be Able To See the Break In The Fuse Wire
1helpful
Peugeot 406 hdi estate x reg when I sound the horn abs light comes on.
possibles
1: horn scars car, or abs, niece said. so....
2: horn is bad causing huge overload on he electrics.
3:low car battery, not charging fully. 12.6vdc rested, 13.3 to 15vdc running.
4: gawd forbid, bad ABS. (i dont believe it)
5: corroded fuses, wires and power feeds to abs , sure.
Where is the engine number not code on a peugeot 406 2.0 hdi 2003
it will be stamped on a flat surface of the engine , different makers use different positions, it will be below the head as its the engine block that is numbered just have to clean it off and have a good look around , usually on one of the sides , good searching, or contact Peugeot with the rest of the vehicle details
Peugeot faults washers dont work
you have to check the fuse box under the wheel
1helpful
Peugeot 406 hdi 90 2003 problem bsi
have heating in my peugeot 406 hdi when car is ticking over but when i drive for few mins the heater goes cold
Cigarette lighter wiring diagram 406 estate 1.7
ask for repair manual from the manufactural
3helpful
The cigarette lighter connection no longer works in my Peugeot Estate 406. Now I need it for my new satnav. Any suggestions?
  • There are two fuses that go to the cigarette lighter. Look for the blown one or replace one and then the other just to make sure.
  • In the passenger compartment fuse box look for -
  1. Fuse F1 - 10Amp - ACC+
  2. Fuse F1A - 10Amp - Batt+
  • Hope this helps and thank you for using FixYa
Regards, Tony
3helpful
2answers
Peugeot 406 estate 2l hdi, anti polution light on
it would never be 1000 euros!!!!!!!!!!!! it will be part of the exhaust system it cuts out because its causing pollution
3answers
Cigarette lighter
Pull the cig lighter out and see if the wires all wired up to it. If not that then you mite need a new one
2answers
My car heating does not work & I need a fuse box diagram
i do not have a diagram for the fuse layout however
looking at your fuse box pull ONE fuse out at a time and check that they are not blown they should have a link in the plastic if there is no link then it is blown most cars have the radio and cigarette lighter linked together and this is normally about 10-15 amps.
there is also a fuse for you heater controls however this normally stops the fan "blower" from operating if your temperature control is electric then the motor that moves the arm to mix cool and hot air flow may be damaged
hope this has helped
ricky
Top Peugeot Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Arnie Burke
Arnie Burke
Are you a Peugeot Expert? Answer questions, earn points and help others
