Question about Hitachi 46F510 46" Projection HDTV
Tv shuts off on its own
I have an Hitachi 46" projection TV, we have been having problems with it shutting down on its own. If you run the Tv with no inputs (dish or DVD) it will run fine. As soon as you change to say input 3 for the dish it will shut down anywhere from a few minutes later to half an hour later. It will continue to do this more frequently. We have had the repair man look at it in their shop. They had it hooked up to cable and it never shut down. We brought it home and are having the same problems. When the power goes out, you can use the remote and change the channel or increase the volume and when you turn it back on the channel will be different and the volum adjusted. I have no idea why the TV is turning off when we are trying to use the dish or DVD player, any ideas?
Thanks
Donnie
  • drussett Feb 05, 2009
    Would it still be the tuner if it is working at their shop on straight cable? I have no idea. Do you know how much a a new tuner is for this model?
    Thanks again
    Donnie
    Problem Solver:
  • 7 Answers
Sounds like tuner isuues could be worng but thats what it sounds like to me or in that general curcuit somwhere...
Posted on Feb 04, 2009
  • mottsy Feb 05, 2009
    hello there well to answer your question would it still work if it worked in the shop on cable....im my experiences with sets and customers i have learned that how many times have people taken things for repair just to find out that the problem did not exist.....sometimes shops do not leave things running long enough to anylyze the problem ......anyhow the answer to your question would be yes cause the tuning section in a tv has many curcuits and thus making some of them work and some not........may be that its only working iin a specific area and not in the other.....and the cost for such a part would cost in a range between 100 TO 300 ..sometimes when it becomes to costly depending on what the cost of the set is people have found out it would be wiser just to buy a new set...and have a warranty on it then to just replace a defective costly part just top find out that the part was just as expensive as a brand new set.....ive seen people say na its cheaper just to go out and but a new one ....i know walmart sell,s sets pretty cheap and there not too too bad........hope this helps ya
My hitachi prjection tv does not come on. It flashes the temp and lamp lights and then shuts down. Is my lamp burned out?
Chances are real good the lamp is bad. Open the lamp door, remove the lamp and see if it is shattered or scorched on the inside. If so, replacing the lamp will fix it. Only replace it with a genuine Hitachi part. The part number should be on the lamp cage.
Good luck,
Skyassoc
Dec 14, 2010 | Hitachi 46F500 46" Rear Projection...
Yellow and blue ghost warped top and bottom. shut it off it was fine , turned tv on 5 minutes later had problem
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Oct 15, 2010 | Hitachi 46F500 46" Rear Projection...
I have a RCA HD52W59 TV. Shuts off automatically.
Power supply is my initial thoughts, but then again it could be that one of the three CRT's tubes has an issue.
My thoughts is that it would be best to bring it to a good TV repair shop.
Why spend money on a power supply and then find out it's a CRT.
Blessings,
A/V Media Guy
Nov 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My TV shuts off seconds after turning it on. I hear clicks and shuts off. Please help. Hitachi 43fdx15B rear projection tv.
I have a very similar issue. Problem seems to go away after the TV has been on a bit and warms up. Did you find a solution for this? Thanks.
Oct 30, 2009 | Hitachi 65SWX20B 65" Rear Projection...
Hitachi 50ex20b shuts of
Hi, you need to stop running the set , call a tech and have him do some solder re-work, this is a cheap, easy fix, keep running it that way and it will become an expensive fix, gl, video-tek
Jun 06, 2009 | Hitachi 50EX20B 50" Rear Projection...
HITACHI 50DX01B IT SHUT OFF AND WON'T POWER BACK ON
Yours is not a fuse problem replace Both of your STK ICs they are big black ics will have part number on them If they are 392-110s use 180s.Also 6 resistors to replace with them RK42-46-50-54-58-62.
Feb 16, 2009 | Hitachi 53UDX10B 53" Rear Projection...
TV keeps shutting
Had the same problem. My son said the lamp door switch was too sensitive and proceeded to put a pad on the bottom left corner of the door to push the switch down further. Problem solved for me!
Nov 01, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Tv shuts itself off
Look for the computer processor inside the TV. It needs to be cleaned. A can of compressed air will work. The processor is overheating and causing the tv to shut off. Look for the small fan that is supposed to keep the processor cool then remove the dust.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Hitachi 46 in. projection tv - no power
Off the cuff it's about time for a new Tv... But give me the model number and I'll try my best.
Bill
Apr 20, 2008 | Televison & Video
Hitachi 46F510 46" Projection HDTV Logo
74 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
