Question about Philips Magnavox 51MP392H Rear Projection Television
Magnavox 51" Projection TV Red Convergence
My TV had red alongside the normal color on my TV -like a shadow. I tried to fix by using my remote to align the cross hairs - now my TV has no picture - when I try to turn it on, it just makes a clicking sound. A TV repair person said I need to replace both "boards" and wants to charge $450 to fix, is this reasonable and what are the boards?
  • 1 more comment
  • mosier Apr 02, 2009
    You said this kit is for the MAG01 chasis, is that the same as MAG1_AA? I have the same issue.
  • bells777 Apr 03, 2009
    I had purchased the IC's and he supposedly installed them - now the TV has a purple color - no picture and goes off after about 5 seconds - he claims the TV is unrepairable because the acs module is no longer a manufactured part and I have it back at my house - unfortunately, I am not TV savy so I have no idea how to install one - I wrote a letter to Philips - I am not ready to just junk the TV but don't know what else to do - hoping Philips has a solution since they don't make the part that will supposedly fix the TV.
  • bells777 Apr 06, 2009
    I bought the IC's and he supposedly installed those - so do I just need the resistors or do I have to start all over again?
  • Philips Master
  • 8,617 Answers
He is most likely trying to rip you off. You need to replace the convergence ICs. Theres a kit at the following link for your model that has both ICs and the 12 feed resistors plus step by step instructions to do the repair. Heres the link. this is the kit your model uses. http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
A convergence problem such as your describing can blow a fuse if you try adjusting it when the ICs fail. and its all centerd on the SSM panel the LSB panel wont be affected. Alot of TV repair men dont have a clue they just try to sell you some boards instead of repair the issue.
Posted on Feb 04, 2009
  • Sonny Berry
    Sonny Berry Apr 03, 2009
    To mosier yes the kit is the same for your chassis.
    To Bells 777 its true that some parts are no longer available from phillips, however the set should still operate wvwn with defective ICs its more probable that the tech didnt replace the Resistors that should be replaced when the ICs are. I would check at the link I posted as they will most likely have the Boards you nheed and the ACS board is strictly poped in after unplugging the old one.
  • Philips Master
  • 3,459 Answers
I agree with Slinteriors...that is a ripoff...you need a convergence kit.
Posted on Apr 03, 2009
Ghost image in red and alot of red color. This occurs all the time. I have tried magic focus and manuel focus. No change
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv have a dead convergence board.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixing the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 09, 2011 | Hitachi 51F500 51" Rear Projection...
The red color seems to be sperating itself from the actual picture. The logos on screen are showing up as double image. pls advise what could be the problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 14, 2010 | Sony KP-51HW40 51" Rear Projection...
Currently, the red and blue color alignment is off and I am unable to adjust this. There is a red shadow with a blue hue. Have tried to realign the colors but can not get the red to move.
Ur tv have a convergence problems,it dead.The convergence board the 2 STK convergence ICS and some or all it resistors are dead.All these parts must be change to get ur convergence back to normal.The shop will u $300-350 for parts and labors.
May 25, 2010 | Philips Magnavox 51MP392H Rear Projection...
Shadows or doubleoverlay
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Apr 18, 2010 | Sony KP-51HW40 51" Rear Projection...
Magnavox 51 mp392H, red is out, what can we do?
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Philips Magnavox 51MP392H Rear Projection...
My big screen tv looks 3d and red green blue are off
  • Screen looks 3D
Mar 06, 2010 | Sony KP-51WS500 51" Rear Projection...
Picture has red and blue shadow images
thats a fairly easy fix. You need the DPTV305-DPTV345 convergence repair kit available at the following link.
The kit contains the parts and the CD with instructions
Sep 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Green shadowing
  • Screen looks 3D
Jan 06, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi projection tv
  • Screen looks 3D
Oct 14, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
777 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
