Question about Ricoh Aficio CL3500N Laser Printer
Smudge on left side of paper
It moves, from about 1/4 of the side down the left side of page, to center of left side of page to 3/4 of the side down left side of page. The smudge is printed, i.e. it cannot be smudged more with your finger after it prints.
  • AdamZapple Feb 04, 2009
    Replacing the Intermediate Transfer Unit solved the problem.
  • 9 Answers
It seems like your PCU's are dirty and are picking up extra toner. Take them out and look at the green rollers, any extra finger prints or dirt on them? Clean them with a clean paper towel.
Also, check your transfer unit below the PCU's, that may need cleaning or replacing. You can pull that out after removing both PCUs, turn the little screww and look at it. That can also be cleaned with a cleaning wipe or a damp paper towel. There's a little tab that you can turn to free the rollers (they'll still be a little tight) bu then you can turn the rollers to expose more surface area.
Good luck. Be sure to rate the post if it works for you.
Posted on Apr 06, 2009
Smudge marks on left side of paper?
If you use new original toner, this should not happen, nevertheless, clean the drum first.
Sep 04, 2014 | Brother Laser Printers HL5450DN HL-5450DN...
My HP 6500 Printer jammed and now everything it prints has a line running down the side. Each segment is about 1/2 inch long and runs down the whole page.
This type of line is cause by a scratch or smudge on the toner cartridge's image drum. You will need to replace the toner cartridge.
Nov 01, 2017 | HP Officejet 6500 Wireless All-in-One...
Odd shaped smudge every 2 1/4 inches on left side of every copy about 3/4" in from left side of paper. Replaced cartridge and still have problem.
A repetitive defect at 2.2 inches indicates a bad fuser hot roller film. This is the teflon coated plastic film that covers the heating element and assists in bonding toner to the page. It will require replacement, unless you can see that something is stuck on the film., however in most cases based on the age of the printer you will likely need to replace the film.
May 06, 2011 | HP LaserJet 1300 Printer
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
1 inch ink smudge down right side of paper
try going on ur computer that the printer is contected to and have the printer align itself
Mar 17, 2009 | HP LaserJet 1020 Printer
Printer is creating a crease and smudge down center of page.
There sounds like there is somthing in the path of the printhead. Using a flash light, remove back cover of machine and look for a small piece of paper,etc. Be careful not to jam anything in to th machine. It may take running a thick piece of paper through manually with your hands to remove the object.
Feb 12, 2009 | HP LaserJet 1012 Printer
Smudges down left side of paper
Maybe something attached (corrector fluid or adhesive)on drum (green cylinder - don't touch it!) or more probably the fixing film on the fusing unit is damaged (probably some paper clip left over input bin, or trying to remove a paper jam with some sharp-pointed thing) If you have some other printer like this around, try with another print cartridge, if error persist , the fuser film is damaged...
Sep 07, 2007 | HP LaserJet 2420 Printer
Ricoh Aficio CL3500N Laser Printer Logo
620 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
