Question about Samsung HCL4715W 47" Rear Projection Television
Horizontal Output transistor
Hey, I am going to be replacing the horizontal output transistor but I am wondering if I could sub something else in. I am wondering if someone could tell me the base drive that the transistor has on it. I was looking at an IGBT that would work great if there is at least 10V of drive on the gate. If I could even get the schematic on that portion of the circuit that would be even better. Thanks
  • Andrew Hawkins
    Andrew Hawkins Feb 04, 2009
    This one is very fast though, and the one I just found needs around 6 volts of drive.
  • 27 Answers
IGBTs do not work well at high frequencies. They are not very linear, either. Even if it works, you'll likely wind up with a compressed and distorted picture.
Just put in an equivalent output transistor and call it a day.
Peace.
Marco
Posted on Feb 04, 2009
A sansui tv switches on and off by itself. What could the problem?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Desolder out the horizontal output transistor, and now power on the set. If the set now powers ON, replace the horizontal output transistor. It is faulty. [Collector to emitter or collector to base leak]
Jun 26, 2015 | Sansui Televison & Video
Sansui sv29276
Replace all the capacitors connected to the horizontal output section. Especially capacitors connected to the collector of the horizontal output transistor.
Oct 16, 2012 | Sansui Televison & Video
I loss the horisontal regulator of my philips tv with 25pt463a/7ir model
Hello
You are talking about the horizontal output transistor damage I assumes and post this solution. If LOT has internal winding short, the horizontal output transistor will get shorted. It will be best to replace the horizontal output transistor, alongwith the LOT
Mar 03, 2012 | Televison & Video
When i turn on horizontal output tripping. B+ and low voltage ok
Hello
Check the LOT and Horizontal Output Transistor. If horizontal output transistor get shorted [collector to emitter or collector to base], this kind of fault will occur. Here there is nocollector to emitter short as B+ is ok. Check for collector to base leak. It is best to repalce the horizontal transistor with a new one, and switch on the Tv for a short while, say 10 seconds or so, and feel the heat of the replaced transistor. If it gets overheated, of LOT makes a whisiling of hissing sound, LOT is faulty, and shoul be replaced sith same type and number. OK.
Apr 17, 2011 | Sony PVM-14N6U TV
My china tv horezantal transister heatup
Hello
If horizontal output transistor heats up rapidly within seconds after the TV is switched on, surely there is some fault in the horizontal output section. It may be either with deflection yoke or horizontal output transformer. Deflection yoke fault is very rare, about 1% or so. but the horizontal output transformer fault is common. The winding in the horizontal output trnsformer, otherwise called as line output trnasformer [LOT] also. can be shorted inside it, and is irrepairable. It should be replaced with same type and number. Number and type is mor important, and should be insist on. Replace the horizontal output transformer. OK.
Feb 12, 2011 | Sanyo Televison & Video
H out transistor defetive & number missing plz solve
Hello
The horizontal output transistor number for Sony KV-ES34M61
Horizontal output - [Q6807] == 2SC5480-01
Pin output - [Q6808] == 2SC5480-01 Again
Please replace bothe the transistor at the same time. Check horizontal output transformer [LOT of HOT], for any defects.. Ok
Jan 06, 2011 | Sony KV-ES34M61 34" TV
Aiwa tv-14ST3 horizontal output always shorted
Hello
If horizontal output gets shorted always, something may be wrong with Line Output Transformer [LOT], or deflection yoke. If LOT windings inside is short, hrozontal output transistor will get overheated, and will be get shorted soon. If there is winding short in the Deflection yoke, even a sinlgle winding gets shorted, it puts a great load on LOT, which in turn effect horizontal output transistor. The third main reason for horizontal output transistor failure is due to an open or dry solder at the capacitor connected to its collector to negative It will be usually 2500pf to 3500pf, according to the TVs screen size. You just check these three and be sure about the fault.
Ok.
Oct 26, 2010 | Aiwa Televison & Video
Hi My toshiba CX36H60 has a problem -- no picture but sound is good. what could be the issue and how to rectify it. Please suggest.
As sound output is ok, main board is correct with respect to sound output, video IF and ther stages. The fault lies on the horizontal output section. It may be LOT fault. Check it further for horizontal oscillator stage, and horizontal output stage. Check the collector voltage at the horizontal driver transistor. If you have a frequency meter, check the frequency of that point. It should be somewhere near 15625Hz. If the frequency there is Ok, then proceed to horizontal output stage. Check the horizontal output transistor. If it seems to be faulty, replace it with similar type and number. If the replaced horizontal output transistor heats abnormally within seconds after swich on the set, surely LOT has troubel. Replace it also with same model mumber and type.
Oct 16, 2010 | Toshiba CX36H60 TV
My sony KV32 FX65B trinitron stopped working.. i took it to a technician and he said i needed to replace the FBT (fly back transformer) along with two transistors. I just replaced them and when i start...
When it is shifted to right vice versa, it indicates a distortion on the horizontal output. Try replacing all the capacitors around the horizontal output area with the same original value. Make sure the horizontal output transistors you replace hasn't started going gone bad already if you know how to check them. Them dimness in the picture is caused by the horizontal output not putting enough high voltage to the CRT. Look for leaking capacitors too. Also replace the resistors around the horizontal output, they may have burnt out or changed in value from overloading cause by the malfunction of the flyback, and the transistor.
Jun 27, 2009 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Replacing horizontal output transistor
Many times, the only problem is hte transistor itself. There is really no way to determine whether or not additiona parts are required until the known defective one is replaced. If there are other symptoms once the transistor is replaced, post them here and we'll guide you to the defective parts.
Dan
Feb 05, 2009 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
99 people viewed this question
Henry  Thomas
Henry Thomas
