Question about AMD Asus A7V-ML Socket A MicroATX Motherboard - A7V-ML
Need to change mother board
I have an old asus a7v socket a motherboard 200mhz fsb pc133/vc133 in my daughters computer(my old one) which is very slow increased ram but still no good also miss bois driver for xp and can not find the right driver. Anyway any ideas what mother board I could replace it with as the rest of it works well.
  • tvangstr0ye May 11, 2010
    Hi Paul.
    Changing motherboard won't to much for speed I'm afraid, adding the RAM was a good move, but that system is so outdated even surfing will be annoying.
    I don't think you'll be able to get a socket a board from any dealers, its simply too old. Ebay is always an option but keep in mind thats most likely second hand goods.
    Have you considerer replacing the whole system? You dont need to spend much to compete with what you have now.
  • 1,602 Answers
WRONG ON THAT I HAVE ALL THE BOIS INFO YOU NEED.
WWW.lemig.umontreal.ca/bois/bois_sg.htm
www.ping.be/bois/numbers.shtml
www.allelec.com
email: mike@ttitech.com
www.unicore.com
go on line type in
update bois or upgrade bois
enter
typing in the bois name and date will tell you about any update or chacges and how to get the updates for free'
bois download drives my work also
rod
ps if you want mother information buy the new cpu magizine [ computer powers issue march 2009}
give you mother boards cpu cooling options cpu venders and option and more info check it out
rod
Posted on Feb 04, 2009
How many extra usb circuits are there on my ibm 09k9982-011 mother board
IBM 09k9982 011 ATX MOTHERBOARD P3 11s19k5609z 1N0Z9131W3C Netvista Socket 370
Condition: Used - pulled - working
Content: 1 Motherboard only
Compatible part # 06P2525 01
FRU 09K9982 , 89P8010
Chipset Intel 815 - FSB 100/133 - 2x Dimm PC100/PC133 - Agp 4x - 3 PCI - 2 USB
IBM 09K9982 Netvista Pentium III Moederbord.
Socket 370 Mini-ATX.
Intel 815 chipset.
2x Dimm pc-100/pc-133
Agp-slot (4x)
3x PCI
2x USB
Sound and Video on-board.
To use with : FOR IBM Netvista Socket 370 , 6648-TAU
hope this helps
Dec 11, 2010 | IBM (09N5424) Motherboard
Looking to get new mother board because it went on fire, old mother bd was asus P5VD1-X HAVE INTERL P-4 CHIP AND DDR 400 MEMORY THAT I WOULD LIKE TO KEEP USING WHAT MOTHER BOARD DO YOU SUGGEST
Better to purchase new mobo, cpu n memory. Bcoz the compatible Motherboard for your CPU/Memory is no longer available. If it is available, only from the dead stock or refurbished. Better to purchase new motherboard/cpu/memory
Sep 17, 2010 | VIA Asus P5VD1-X PT880 Ultra Chipset 1066...
HP has two BIOS updates on their website for this computer. How can I know which BIOS update I need? One says Moorea Congo Mocha and the other is Montana Mocha. All I can find on my motherboard info is...
There is probably a serial number point after which the name was changed. I would try Asus customer support with all the data you can find on your board and ask them which you need. Flashing a BIOS can be daunting because if done wrong, you can disable the board and then you may be really sunk.
Nov 23, 2009 | AMD Asus A7V-ML Socket A MicroATX...
BIOS update for Asus A7V-ML
For branded computers like HP, Compaq, Dell the only place you can get the correct bios updates would be your computer manufacturer website under the support link. These companies do not use industry standard motherboards so it could corrupt your system to update from any other source. Hope this helps.
Apr 27, 2009 | AMD Asus A7V-ML Socket A MicroATX...
Processor for P5VDC-MX
Hey there alcouto, your motherboard supports Intel Celeron, Intel Pentium 4, and Intel Pentium D processors. The socket set is LGA775. The FSB should be no higher than 800Mhz. It appears you have purchased the wrong CPU for your board. I hope the rest of the info helps you on your next purchase. Good Luck!
Jan 29, 2008 | ASUS P5VDC-MX Motherboard
Pc 100 and pc 133
that is their frequency, pc133 has a higher frequency than pc100
Jan 10, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I want down load A mother Board Driver
type in your model number on the left.
A7V400 it will come up with 2 options.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Dec 01, 2007 | ASUS A7V400-MX Motherboard
MicroATX motherboard work but the monitor shows a black screen.
I assume the monitor is turned on? Try the monitor with a known good computer to verify it's OK. I believe this board has AGP video. Verify that it's properly seated, or try another board.
Sep 13, 2007 | AMD Asus A7V-ML Socket A MicroATX...
AMD Asus A7V-ML Socket A MicroATX Motherboard - A7V-ML Logo
188 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
