Question about JVC HR-A592U S-VHS VCR
Ejects tape as requested, then pulls it back into unit
Otherwise, works perfectly!
  • 48 Answers
Its not fully ejecting the tape. Return it or get it repaired, you can try to do it yourself but isn't recommended.
Posted on Feb 04, 2009
I have a 1998 mercury sable and the tape deck doesn't work when I put a tape in it flips from side 1 to side 2 a few times then it ejects. how can I fix this?
May have to remove the unit & take to a car radio
shop to have it repaired
Those shops are very hard to find, but will fix it
If you don't pull it out yourself it will get costly &
no repair shop fixes radios & tape deck,so forget
that approach
Aug 11, 2013 | 1999 Mercury Sable
The VCR accepts the tape and starts to play; then stops and shuts off; when you turn the power back on the tape ejects
You have a transport problem, the mechanism the plays, FF or rewinds is not working.
Someone is going to have to open and look at the unit---as simple as a belt off or broken to the idler (rubber or geared) that doe the actual work, finding a shop that will work on a VCR unit is getting hard as most of the current techs have never seen this type of unit.
What I used to do when I opened one was have a old cassette with the tape removed! but the reels inside of it still there--tape off both sides of the cassette where it opens so the sensors on either side do not try to stop the unit from allowing this.
This way with the unit open and the dummy cassette in you can see thru its top to see if the reels are moving or not and not have the tape get in the way.
Dec 06, 2012 | Magnavox DV220MW9 DVD Player VCR
Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Aug 31, 2009 | Sony SLV-640HF VHS VCR
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
JVC HR S5700AM S-VHS video recorder - won't accept tapes
Hey Lindsay
Yes the ejector is probably damaged inside maybe a bent arm or something mine is like that 2 and I didnt even bother fixing it I will be finding one very soon and I suggest you should 2 so just throw out the old and come in the new with your new vcr or dvd vcr combo..
Jul 23, 2008 | Televison & Video
Tape ejects immdediately when I load tape.
I own a Sharp VL-Z1 DV video camera. I had this same problem and thought it was from using the ME Maxell tapes. I took the battery out of the unit and let it reset. Worked fine after that.
May 05, 2008 | Canon ZR85 Mini DV Digital Camcorder
Vcr eating and/or ejects tape
Tape heads should be cleaned first and gears lubricated. This job can be done at home if you purchase lithium grease and are very careful not to get it on the heads or spools. Greasing should only be done if you are confident in opening it up. Otherwise, seek a cheap professional.
Oct 26, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
May 13, 2007 | Philips MWD2205 DVD Player/VCR
76 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
