Question about Apple iPhone 3G Black Smartphone
CANT SEEM TO ACESS MY I PHONE DIALING PAD
I CANT DIAL ANY NUMBER OR END ANY CALLS MY KEY BOARD IS TOTALLY NOT WORKING. CANT SEEM TO ACESS IT
  • 1 more comment
  • Anonymous Feb 20, 2009
    i can hang up a call and answer a call but thats it
  • anpasan2001 Mar 16, 2009
    After upgrading my 2G iPhone I can receive calls, my Contancts contain contacts but I can't use it in Phone mode and I can't dial (type) any number.
  • doobie420 May 11, 2010
    Does your touch screen work at all? I mean can you operate anything else? If none of your touchscreen works you need to replace the digitizer.
5 Suggested Answers
SOURCE: Iphone Call Ended
GUYS - GOT THE SOLUTION
Very Simple. Just goto Settings - Phone - Show My Caller ID
And
Switch it to ON
It solved my problem and shall do yours too. It is caused by the carrier not allowing calls with the Caller ID not provided by the calling device.
imranhr73
Posted on Jan 02, 2008
SOURCE: iPhone dialing keypad problem, 2g , 2.2 firmware
I just found the answer on another website. Go onto installer or cydia and uninstall Mobile Enhancer. Restart your phone and it will work. Thank god!
Posted on Dec 16, 2008
  • 42 Answers
SOURCE: iphone number pad not working after jailbreak cydia with unlock
I have seen that on older firmwares. Are you running 2.2? I would recommend upgrading to 2.2 (not 2.2.1) and installing yellowsn0w for unlocking.
Posted on Feb 12, 2009
ipodslinger
  • 688 Answers
SOURCE: Numbers won't stay that i dial
did you by chance update to the iPhone 3.0 Beta?
if so your issue is a bug in the software.
if you didn;t update yet,
press and hold the home and the sleep button until the iPhone reboots.
then give it a try.
Posted on Jun 05, 2009
Sometimes my dial pad doesn't work can't end calls
If you have memory card into your phone remove then try if it work,insert low memory....touch problem so,go cervicing center.
Nov 08, 2011 | HTC Cell Phones
Why does vtech not have a speed dial? my son is
Programming Speed Dial Numbers
The handset must be OFF.
1. Press PROG. The IN USE LED will blink to indicate that you are in the programming mode.
2. Press the number of the memory location you wish to store the number in (0-9).
3. Using the dial pad, dial the number you want to store. The number can be up to 16 digits long. The number can be entered manually or by using REDIAL.
4. Press MEM to store the phone number
to the key you selected.
The phone now exits PROG mode and emits a tone.
Speed Number Dialing
1. Press PHONE to get a dial tone.
2. Press MEM and the memory location number key (0-9). For example, to dial the number you assigned to key '8', you would press PHONE, MEM, 8
May 27, 2011 | Vtech 9009111 Cordless Phone
How can I set speed dial if my phone is not the main telephone
If you have a USB port on the side of the cabinet, you can program it from the maintenance console. You can also program "personal" speed dial number in the 12 feature buttons on the right side of the phone, and/or under the dial pad on certain systems. To program the buttons, press PROGRAM the button and dial the number with an access code in front (usually 9) then STORE. So, to call 555-1212 you'd dial 9555-1212 STORE. and pick up the handset and drop it back down to end programming.
If you figure out how to program numbers under the dial pad buttons 1-0 keep in mind that it overwrites the F1-F10 keys.
Carl
Sep 15, 2010 | Panasonic KX-T7730 Corded Phone
I cant figure out how to set up speed dial?
Go to your phone call settings and activate speed dials feature.
Then come back to your phone in normal display mode,press and hold any desired digit e.g 2,3,4,5,6,7 on the key pad and follow the prompt for assigning of phone nos for speed dialing.
Sep 14, 2009 | Lands Phones
My screen freezes when I dial
Decided to try running a magnet over the phone front & back horizontally and vertically, like I had read other people did to fix other freezing problems. IT WORKED!!! :D
Aug 14, 2009 | LG Xenon GR500 Cell Phone
My samsung instinct is stuck on dial pad,i cant acess any other menu but my speed dial and dial pad.cant dial any number cos if i try to dial one it shows im pushing nine instead.
do what is called a "hard reset". take the battery out while the phone is still on and leave it sit for about a minute, then return the battery to the phone and turn it on. see if this helps. if not, back up your phone and try doing a full reset.
Jul 11, 2009 | Samsung Instinct Cell Phone
Cannot dial a number..
you might need to eneter area code along with the number.
Jun 02, 2009 | HTC G1 Smartphone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Keyboard works but cannot dial
I think key pad must be removed to clean contact surfaces.
Sep 08, 2008 | RIM BlackBerry Pearl 8100
Apple iPhone 3G Black  Smartphone Logo
60 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
