Question about Weather King 10AJA3601AH Air Conditioner
Goodman heat pump not heating
I have an older heat pump ( Goodman model PGB036100-1A REV A). This morning it would come on for about 1 minute then shut off. There is a LED light that blinks 4 times when it shuts off. According to the back of the panel this is indicating that its a problem with the open limit switch. I called a service technician and was told to shut the heat off for a few minutes and then turn it back on. After doing so the heat has not came back on at all, only blowing out cold air. Any suggestions on what the culprit is and what I can do to fix it? The service tech wants $75.00 to come out and look at it plus $75.00 an hour plus parts to fix it, money that I do not have right now.
  • 2 more comments
  • alan030264 Feb 04, 2009
    Are you refering to a thermostat thats inside the unit itself? The only thing that I have seen behind the panel that I removed is the main circuit board. Thats where I seen the LED light that was blinking 4 times and the back of that panel had the trouble shooter codes and said that 4 blinks indicated the open limit switch. How would I check the thermostat ( assuming that I can find it...lol! )?
  • Anonymous Feb 05, 2009
    I HAVE THE SAME PROBLEM. MY REPAIRMAN CHARGED $190,00, AND STILL DOESN'T WORK RIGHT. HEATS FOR A MINUTE, BUT MOSTLY JUSTS BLOWS LIGHTLY WARM AIR. STAYS COOL ON ONE SIDE OF THE HOUSE, WHILE THE OTHER HEAT PUMP WILL RUN YOU OUT OF THE HOUSE.
  • Michael Fisher
    Michael Fisher May 11, 2010
    Have You Located The Igniter Or Anything?
  • Michael Fisher
    Have You Checked The Thermostat? It Will Be Right Next To Where The Unit Fires.
Just wanted to post an update and let everyone know that I had a technician come out to look it over and he says that it is the open limit switch thats gone bad. He was supposed to return this morning to replace it but instead he called and said that no one has that particular one in stock and that it will be tomorrow before he can get it ( just my luck! lol ). I would like to thank everyone and hope all of you have a great day!
Posted on Feb 05, 2009
Goodman model PGB060125-1 REV wont run
whats not running i may be of further assistance with more info
Jan 28, 2017 | Goodman Heating & Cooling
I need to know where 3 wires connect on a goodman pc036-1b rev e package unit air condtioner and central heat system.
Contact Goodman directly to request a wiring diagram for model pc036-1b, rev. e. It is important to specify rev. e.
Nov 01, 2017 | Heating & Cooling
I have a goodman GMP10-5 REV that the blower will not shut off, i think it may be the fan limit switch, can I test it and where is it located?
the older units have the limit mounted on the heat exchanger straight in front as u look at unit. try taping on unit . newer units are on a circuit board . just for the heck of it unhook the green t-stat wire on termal bloc on unit. if the blower stops then replace t-stat.
Dec 27, 2011 | Goodman GMS90703BXA Heater
We live in SC, have a Goodman 4 ton split system w
First of all is this unit a heat pump i'm not up on goodman model #'s if it is a heat pump reversing valves do go not a real common problem 1000.00 is excessive i would be inclined to get a 2nd opinion. plastic over the sand could create a condensation mold problem. Good luck. Tom
Jun 23, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions hillbuck29@aol.com Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
Goodman furnace model #GPO 125_4 REV 8 Installed 6/2/2002
Have you measured the temperature in the suppy plenum? Should be 140 to 160 max. If hotter, you have a blockage in the ductwork or vents closed. If within spec, bad circuit board.
Jun 05, 2008 | Goodman GMS90703BXA Heater
Weather King 10AJA3601AH Air Conditioner Logo
334 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
