Question about Acer 4220-2346 Notebook
Factory settings what keys do i press to restore to factory settings,im sure f10 is one but cant remember the other
    President:
  • 2,110 Answers
Ou have to press f10 and shift
Posted on Feb 04, 2009
1720 s.m.a.r.t HDD detects imminent failure the computer cant boot-up.
if you haven't got a good back up, external to the hard drive, it may be too late
dead hard drives are mostly un recoverable
take it to a computer repair shop to make sure that it is not a boot problem
if the hard drive is failing, replace it with a solid state hard drive that has no spinning discs to fail
Jan 13, 2017 | Computers & Internet
How do you clean to factory settings a fujitsu laptop
You must do a full system recovery. Go to the manufacturers website to see how to do that on your model and operating system.
Jan 12, 2017 | Fujitsu Computers & Internet
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
How to hard reset a WM8880 laptop
Power the unit off (holding power buttom) and selecting Power off, then simultaneously hold the "back" button and on button for about 8 seconds. When the android icon appears, press back buttom, in the menu select wipe data/factory reset pressing the home buttom and then press the back buttom, in the next screen select "yes delete all user data" pressing back buttom, and in the next screen select "reboot system now" with the back buttom and wait.
Nov 29, 2014 | Computers & Internet
Ibm thinkpad 2374 manuals
Does it actually have a wireless network adapter? Check the network adapter settings. Does it show both LAN and wireless? If it does you may need to use one of the Function keys to launch the interface to turn on the wireless.
Aug 19, 2014 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
Http go acer com id 17883
I remember my password I wrote it down and even then it won't let me in. If I cannot get into this computer I will return it.
Mar 13, 2014 | Computers & Internet
Have forgoten my password for my computer
Download a password recovery program from the net and run that on your laptop.
Sep 22, 2012 | Panasonic Toughbook 19 Laptop Convertible...
How do i reset my computer to an earlier date?
Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
Jul 27, 2011 | Computers & Internet
Acer 4220-2346 Notebook Logo
111 people viewed this question
Brian Sullivan
Brian Sullivan
