The problem you have is there is either something inside the closer keeping it from closing or the closer is worn out and has tightened up. You can take the closer off and see if you can get it to work without being attached to the door to determine what is causing the problem. Also if your door is in a windy area then that could cause it to stay open. If you can't figure out what's causing the problem then you can replace the closer with a new one. If i'm not mistaken they run somewhere between 10 to 20 dollars depending on where you go to buy one.
