Question about Nikon Coolpix L11 Digital Camera
EVERYTIME I CUT MY CAMERA ON IT CUTS RIGHT BACK OFF
PLUS THE BATTERY HATCH IS BROKEN
  • 423 Answers
Your camera continually shutting off (added with the fact that the battery cover is broken) probably means that your batteries are not making good contact with the hatch lid. You need to strap that battery cover down tight after your sure the batteries are installed correctly. Keep in mind, your going to have to strap that puppy back down every time you change batts. Let me know if this will help you.
Posted on Feb 18, 2009
Otside temp 102,after car is shut a fan cuts back on and drains my battery?
should not come on after you turn off the key sounds like you may have a problem with your ingnition switch
Jul 02, 2012 | Cooling System for Volvo XC70 Cross...
The battery door catch has broken
On most cameras you can hold the catch closed with an elastic band around the body of the camera, if necessary with a small square of cardboard over the hatch itself, or several bands, if the hatch actually holds the batteries in place. At least you will be able to use the camera, even if it does look a bit untidy!
Dec 26, 2010 | Cameras
How to remove Canon A570is broken battery door
I had the same problem and found nothing online to fix it so based on what little I could find and some common sense I got it done fairly easily. Here's what I did...if you need more detail on any step either re-read it to see if you missed something or let me know 'cause maybe I missed something.
Standard warning - you are dealing with small screws, small parts and things that might break. If you damage your camera trying this repair - please don't blame me! <G>
1) remove batteries and memory card
2) carefully remove screws around the outside.
There are: 3 on the bottom, 1 under the plastic usb cover on the left side, 3 on the right side. Once those are out, remove the clip that holds the wrist strap and you'll find 1 more on the top of the camera under the wrist strap clip.
3) starting at the bottom of the camera, gently separate the back cover from the camera body. YOU DON'T NEED TO TOTALLY REMOVE THE COVER!
4) (note the small spring on the battery hatch - when you complete the next step that spring will come out so look at where it is, which way it is and don't lose it!) While holding the cover and camera body apart slightly, use a pair of fine needlenose pliers or possibly tweezers & slide the pin that holds the hatch in place toward the back of the camera until the spring and door come off. You don't need to totally remove the pin.
5) take your new door assembly and put it in place. the fun part is the little spring - the shorter end of it has to go through a small hole at the back of the hinge area, the longer end puts pressure against the hatch. Once the spring is in place, hold it there and slide the pin back into place (I found that just allowing the cover and body to come back together moved it into place).
6) try the hatch to make sure it opens/closes freely and latches
7) put the screws back in place - note that one of them is shorter than all the others - that one goes on the top of the camera under the wrist strap clip
Hope this helps!
Please note - this is the only digital I've taken apart so I'm not likely to be able to help with other makes and models but feel free to ask!
Jun 14, 2010 | Canon PowerShot A570 IS Digital Camera
My amp is working but everytime it cuts off and i got to cut off my car and cut it back on. Also when i have the car off and i have my radio on it stays on. But when i am driving like 1 or 2 mins it cuts...
Check your ground wire and make sure it is bolted down into a solid ground. Do not use a factory ground make your own. Every system that has subwoofers has a little blue wire called a remote wire. The deck sends a signal to the amp thru this wire letting it know it has been powered on. It could be that there is a short in this wire, either from the deck side (where the wires are connected) or it could be also be detiorated insulation on the wire. pretty inexpensive to replace. In my opinion it sounds like you have a shotty ground wire. If you don't have this grab yourself a nice foot of 4 guage wire at your local HI-Fi shop. This should fix your issue if not let me know and we will keep troubleshooting
May 20, 2010 | Lanzar MXA232 Car Audio Amplifier
2005 Kia Spectra - brake lights on tail lights are not working but the brake light above the hatch is working. Have checked fuses. Any ideas?
Check around in that trunk for loose wires. Especially a grounding wire at the taillights. Sometimes in our hurry to shove stuff in the trunk it's possible to disconnect, or cut a wire... If you've got the 'cyclops" light working on the hatch, then there's power back there, just look around and I'm sure you locate a loose or damaged wire... trace them back from the taillights and look close for cuts, frays, damage, loose connection..
Nov 23, 2009 | 2003 Kia Spectra
I have 1993 nissain altima that is could cut off and is having a hard time getting it start back up while in the process of doing that it began to drain my battery and i have to jump it off. replaced the...
ijust had the same problem with my 93 it was the distributer itself.Once the new one was put on it fired right up/Make sure who ever does your work also cleans or replaces your plus they get fouled real quick from trying to start.
Jan 23, 2009 | 1994 Nissan Altima
My camarea wont turn on!
There are two types of batteries that are suitable for your camera: Alkaline and NiMH
make sure that your batteries are made for a digital camera these seem to fit a bit differently into the digital camera then standard AA batteries.
but what you are saying is ushally the cause of the batteries and nothing to do with the camera, when the unit does power up make sure in the menu the right battery is selected for the camera as well.
Nov 28, 2008 | Polaroid i735 Digital Camera
Set up settings won't stick after camera is turned off
yes on the ex-z75 Casio camera there is a internal battery right under the front cover by the speaker wires this battery is a 3.6 volt battery that is soldered on the board. the only what is to make a make shift battery pack and solder it on to the prongs. I do this with out any guarantee that because it is not factory default and they do not sell the battery to any one. most of the time they will tell you the main board has to be replaced. if the main board has to be replaced it is 85.00 plus shipping from my shop but if soldering a 3.6 battery pack works then it would be 40.00 to replace the battery.
May 29, 2008 | Casio Exilim EXZ75 Digital Camera
Camera cuts off when I take a picture
same here, i thought that the camera was going into sleep mode to save batteries, the light turning red dosent inspire confidence
Sep 02, 2006 | Fuji FinePix A205 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
