Question about Gateway 7330GZ Notebook
My Gateway 7330 works now, but the power button doesn't
I got an old Gateway 7330 from a friend, and it didn't work. Well I took it apart and found out that the 3.06 GHz processor was faulty, so I replaced it with a 1.8 GHz processor that I had lying around. Well it works now, and I put it all back together just fine, but the power button doesn't work right... When I press the button, it does nothing. It is not the button itself, but I think rather the thing that holds the cable on the motherboard's end that is faulty. When I put pressure on it, it sometimes works. When there is no pressure, it never works. Would unsoldering it and resoldering it fix my problem? Please help, I would like to be able to use this. Is there a part I could buy, or some way that I would know for exactly where the problem lies so I can replace the part?
    President:
  • 2,692 Answers
If you go to where the start button connects to the computer mother board and disconnect it. YOu can put a screwdriver across the two spikes coming from the board and it should start. That wil confirm that it is not a board problem.Next get a small battery test light ,or ohm meter and  hook to the two wires from the switch. Press the switch.If it lights that everything is ok. If not you are down to the wires or the switch. Disconnect the wires for the bvack of the switch and test the switch with the light again w/o the wires. Works now=bad wires or connection. Does not work=bad switch.
Posted on Feb 04, 2009
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Flickering power light on gateway 7330 laptop
Return the laptop to the place of purchase, this is a manufacture issue.
Jun 20, 2012 | Gateway 7330GZ Notebook
The back button is not functioning.
I will not be very helpful but I have the same problem. I took it apart, fiddled with the ribbon flex and then it worked for a while if I squeezed it hard. Then it stopped working again, I took it apart, cleaned the ribbon flex and the sockets with alcohol but it didn't help...
Jan 05, 2011 | Sony Ericsson P1i
I need to replace the CMOS battery in my Gateway 7330 laptop and I cannot find out where it is
It is just below the keyboard under the palm rest. Remove all of the screws from the bottom of the unit, carefully - from the left side, pry up the trim panel that has the power button (careful since the power button board is screwed into this panel), then remove the screws for the keyboard, slide it up towards the LCD to release it, remove its ribbon cable, you should be able to gently pry the upper and lower case halves apart enough to see the battery. The cases will NOT seperate!!!!!!!!! I then used a small straight blade screw driver to pop the battery out. It was a CR 1220 3v lithium coin type battery in my 7330GZ. I had to go to a specialty battery store to get one! Hope that this helps!
Nov 05, 2010 | Gateway 7330GZ (890552601318) PC Notebook
Clean install of Windows 7 on Gateway 7330. Cannot get sound or wireless working. Help?
go to the gateway 7330 page of the gateway official website. download the vista drivers for the system. when you want to install, right click and select "install with troubleshooting". then follow the instruction from there.
Jan 23, 2010 | Gateway 7330GZ Notebook
Gateway 7330, locker upper
Have you updated your BIOS to the most current for your laptop? What diagnostics have you run? Have you defragged your hard drive? These are both solutions and request for clarification. There are a number of solutions but you have to really be specific about your problem.
Jul 25, 2009 | Gateway 7330GZ Notebook
Dissassemble a gateway 7330 gz
well power button on the plastic or the real power button on the board??? have ya taken out the top plate off over the power button???
Nov 15, 2008 | Gateway 7330GZ Notebook
Keyboard bezel removal steps
take a small flat tip screwdriver under the plastic hinges near the screen and flip them up, the plastic hinge guards house the top bezel.
Oct 18, 2008 | Gateway Solo 9100/9150 Series Laptop...
Won't turn on at all
Hello, I just fixed a friend of mine's mp-c7085. Same situation. Kid just got it for christmas, dropped it and it stopped working. I took it apart and found that the on switch broke it's soider connection to the board. I carefully resoidered the switch and it works. You can tell for sure if you take it apart and squeeze the on switch to the board while you try turning it on.
Feb 01, 2008 | Coby MP-C7085 MP3 Player
Gateway 7330GZ Notebook Logo
692 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
