Question about Sony SLV-N71 VCR
Sony SLV-N71 VCR makes a rattling sound (ff, rew)
Sony SLV-N71 vcr makes a rattling sound during ff and rew. The ff and rew speeds are also too slow. The tape (as seen through the cassette window) also looses tention and the "tape tentioning post" jump and **** about during ff and rew.
    Problem Solver:
  • 19 Answers
I make no claim to being any kind of an expert techie but it sounds to me like there are one or more loose or badly worn parts inside your machine. If you haven't had a look at the innards, try that. Loose things can usually be re-secured and, sometimes, worn parts can be replaced.
Rod
srives@shaw.ca
Posted on Feb 06, 2009
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Have a Sony SLV-N71 VCR with error code ASC or AC5...not sure. Can you explain?
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 16, 2011 | Sony SLV-N71 VCR
How do u get off apc on the display from a sony slv-n71 vcr
Press MENU on the remote for the Sony VCR. Go into the ADVANCED OPTIONS. Next scroll down to the line that says NEXT for next page because its on the second page of advanced options. Press enter or execute to see the second page. On this second page look for APC (adaptive picture control) and you can set it ON or OFF. Set to OFF to remove APC from the front panel display. Note: it is recommended to have APC set to ON.
Aug 30, 2010 | Sony SLV-N71 VCR
I have a new digital tv in which i use an antenna to watch it. i hooked up the vcr to it but i cant get it to record the tv show i want recorded.
Your VCR most likely does not have a digital TV tuner. Therefore you must supply a digital TV input signal so you can record it. Unless your TV has a composite video output, you would need another box, namely a digital TV tuner/converter which would connect to the VCR's input. Select the channel to record on the tuner/converter and select on the VCR the input where the tuner is connected.
Aug 14, 2010 | Sony SLV-N71 VCR
Does anyone know the universal remote code for the Sony SLV-N71 VCR? Neither 0000 or 0111 work. Please Help?
Loads of them, you might have to try several or all just to make certain all functions work:
1029, 1030, 1071, 1073, 1074, 1075, 1098, 1102, 1113, 1114, 1115, 1116, 1117, 1118, 1119, 1120, 1121, 1122, 1123, 1182, 1183, 1184, 1247.
Feb 28, 2010 | Sony SLV-N71 VCR
Sony SlV-SE730 VCR video inserted wrong way
Unplug the VCR.
Take the cover off by taking out the small screws on the sides and on the back that hold the cover on.
With the cover off you should be able to gently move the tape back out.
Things could be damaged......after the tape is out, you should try it first with a tape that could possibly be damaged during testing and do not touch anything inside while plugged in to power during testing with the cover off!
Now......if it is not a working VCR anymore......you are in luck.
There are garage sales every weekend...and almost every one has a VCR for almost nothing....some like new.....and boxes and boxes of tapes/movies for very little money too.
Sep 06, 2009 | Sony SLV-SE730 VHS VCR
Sony SLV-940HF VCR Problem: clicking noise when tape fully rewinds
It is normal. Sony is trying to get your tapes last longer.
Mar 27, 2008 | Sony SLV-940HF VCR
Sony SLV-N750 sound problem
befor i give u answer of this Q.i m gona ask u some think to make sure u regulur tape is orignal recoding from company is not that means u recrder vcr out of alighnment on audio head ..so chack that ....and hi fi system very sensetive about it,s audio head alighment ....or might u notice movie runs slow some time or fast ......if that kind problem u can't do much about it only u can do use the orignal record tape or alighment a audio head ...good luk...oh yaa clean head first ..
Dec 21, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Aiwa vcr HV-FX 7800k
If you are asking 'why ' does this VCR have 2 speeds, it is to help you locate a certain portion of the movie fast. If you are asking 'Does' this VCR have 2 speeds, the answer is YES.
Mar 29, 2007 | Aiwa HV-FX7000 VHS VCR
Sony SLV-N71 VCR Logo
349 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
